bigblue Samba Member
Joined: July 20, 2006 Posts: 451 Location: where the c-130s fly!
Posted: Sun Oct 02, 2016 6:32 pm Post subject: horn button help |
bought a new 'wood' steering wheel and im trying to find out how to wire up the horn button on it rather than having a button below the dash where the guy who partly restored my car. the button has two different terminals on it. the upper one lets the horn be on all the time and the lower one does nothing. im guessing the top is ground and the bottom is positive? _________________ 1966 Sedan (Dad owned in Germany '74-'75)
1970 Yukon Yellow Sedan 'Puddin' SOLD
1970 Beetle Convertible (under restoration) SOLD
1970 Sedan (fresh restoration)Trophy Queen
1973 Super Beetle (Totaled in '99)
1972 Standard Beetle SOLD
looking for a 1969 Beetle hardtop
i mess with sasquatch on weekends.
jmsmilin wrote: |
...he will be tucking blocks soon... |
Posted: Sun Oct 02, 2016 7:29 pm Post subject: Re: horn button help |
resolved. _________________ 1966 Sedan (Dad owned in Germany '74-'75)
jmsmilin wrote: |
zerzat Samba Member
Posted: Sat Jun 16, 2018 2:58 pm Post subject: Re: horn button help |
How? I think I have the same problem. I figured out that there seems to be no connection to the live wire (the steering column) but don't have a clean way to connect |
vwoldbug Samba Member
Posted: Sun Jun 17, 2018 11:19 pm Post subject: Re: horn button help |
Bigblue can you show what fixed it ,was it the ground . |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Mon Jun 18, 2018 5:30 am Post subject: Re: horn button help |
Hmmm, not sure you will get a reply on a 1.5 year old post.
Depending on the model year of your Beetle the path of power and the path to ground for the horn switch is different.
If you consider the horn button/switch as the "center" of the horn circuit with a path to ground on one side and a source of positive current coming from the other side...
'68-'70 -
Positive side includes:
upper steering shaft bearing
steering shaft
steering wheel
Ground side:
the wire that runs inside the steering shaft
grounded to the steering box
'71 -
turn signal switch assembly
horn contact ring in turn signal cancel disc under steering wheel
steering wheel+ steering shaft
Ground side:
'72 -
Ground side:
So if you have a '71-earlier the steering wheel is part of the positive side of the horn switch and the wire coming out the center of the steering shaft is your path to ground.
From '72-later the wire coming thru the steering wheel is the positive side and the steering wheel is your path to ground.
When using an aftermarket steering wheel you need to consider if the wheel+adapter still allow the current to flow the same way the stock system did. For my Grant steering wheel the horn button had two terminals. By default, one was shorted to the steering wheel and not needed if your steering wheel was part of the horn circuit. If it wasn't, you could snip a small wire and then the horn button was entirely independent of the steering wheel and you had to wire BOTH terminals. Pressing the horn button closed the contacts between the two wires.
If you are uncertain which arrangement you have....
Check the rubber (insulating) steering coupler near the steering box. If the steering shaft has a wire electrically connecting the bolt for the steering box to the bolt for the steering shaft you know your shaft is grounded.
If there is a wire running from the steering box bolt and it goes up inside the steering shaft you know your shaft is NOT supposed to be grounded and the shaft is likely part of the positive side of the horn switch.
_________________ AshMan40
zerzat Samba Member
Posted: Sun Jul 08, 2018 1:21 pm Post subject: Re: horn button help |
Looks like I got two replies on a 1.5 year old post 😁. I've seen enough people get mad at people for asking questions already asked so I decided to play it safe and ask on the only thread that seemed close.
By accidentally brushing the wire against the shaft I confirmed that it is ground. I'm in a 74 super so no wire coming through the shaft and your post confirmed it @ashman40
Red/black is coming from turn cancelling ring and green is wire I added going to shaft/ground.
Hopefully this thread is now useful for the next schmuck searching a year and a half from now
Edit: for the history books, it was a volante steering wheel purchased from jbugs with appropriate hub and button. |
virusdoc Samba Member
Joined: August 13, 2018 Posts: 525 Location: Durham, NC, USA
Posted: Sun May 10, 2020 6:39 pm Post subject: Re: horn button help |
zerzat wrote: |
I am that schmuck, and nearly a year and a half later you got my horn working with the same Volante hub. Thanks! _________________ 1976 Convertible Super Beetle, "June Bug".
FI-->34PICT3 carb conversion-->now dual 40 IDFs
Self-rebuilt 1904 (after totally botching a 1641 rebuild, cussing a lot, and throwing lots of cash in the fire) |
quantumchaos Samba Member
Joined: October 02, 2020 Posts: 220 Location: Gardner, IL
Posted: Wed Jun 08, 2022 3:41 pm Post subject: Re: horn button help |
Hello All,
Can you clarify where the red and black wires are attached, I have the same exact issue.
Thanks |
