Trouble finding a place that sells cooling tins
74superTN
74superTN is offline
PostPosted: Mon Oct 10, 2016 10:28 am    Post subject: Trouble finding a place that sells cooling tins Reply with quote
Anyone else having trouble finding a place that sells lower cooling tins? I need one for my 77 Westfalia with a type 4 motor. The lower drivers side tin seems like it's impossible to find.
73 Thing
80 Vanagon Westy
Balmoral1958
Balmoral1958 is offline
PostPosted: Mon Oct 10, 2016 11:52 am    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
saw this in the for sale section:
http://www.thesamba.com/vw/classifieds/detail.php?id=1683975
Wildthings
Wildthings is offline
PostPosted: Mon Oct 10, 2016 12:46 pm    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
The sled tins need to match the exhaust system you are running,; 72-74, 75-78, 79, and California variants.
Tcash
Tcash is offline
PostPosted: Mon Oct 10, 2016 1:24 pm    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
75-78 Type 4 Engine Tin
gintaras
gintaras is offline
PostPosted: Mon Oct 10, 2016 2:25 pm    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
This is my big problem.. Mad
I wish I had found a '78 instead..
1979 Deluxe Westy in Mexico Beige
74superTN
PostPosted: Mon Oct 10, 2016 2:44 pm    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
Thanks, I just emailed them. It just seems like I have a mixed amount of parts or something that don't add up, lol
The holes always seem to be off, even after looking at the link tcash shared
73 Thing
80 Vanagon Westy
busdaddy
busdaddy is offline
PostPosted: Mon Oct 10, 2016 4:07 pm    Post subject: Warm air channel (sled) tins with "F" pipe Reply with quote
Those won't fit a 78 unless you have a 72-74 exhaust, this is what you need if you still have F pipes leading to U pipes at the front: http://www.thesamba.com/vw/classifieds/detail.php?id=1974959
Слава Україні!
Tcash
Tcash is offline
PostPosted: Mon Oct 10, 2016 4:36 pm    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
You might have a mix of parts. Here is the 72-74 tins.
1972-73-74 Type IV (4) Engine Tin
Tcash
SGKent Premium Member
SGKent is offline
PostPosted: Mon Oct 10, 2016 5:51 pm    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
talk about great service, these guys did everything but deliver them Smile
74superTN
PostPosted: Tue Oct 11, 2016 8:24 am    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
Thanks guys! awesome help as always Smile I'll reply here with any updates or what I find out!
73 Thing
80 Vanagon Westy
74superTN
PostPosted: Wed Oct 12, 2016 7:55 am    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
Here's an old pic from under the bus...dont mind the old oil leaks, those have been taken care of!
The oranges circles show where my cooling tin would mount.
73 Thing
80 Vanagon Westy
busdaddy
busdaddy is offline
PostPosted: Wed Oct 12, 2016 8:08 am    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
You need the 72-74 style, like the ones in the first link. The ones with the valley in the middle won't work.
Слава Україні!
74superTN
PostPosted: Wed Oct 12, 2016 8:22 am    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
Thats crazy considering it's a 77 lol...Thanks Busdaddy!
73 Thing
80 Vanagon Westy
74superTN
PostPosted: Wed Oct 12, 2016 8:25 am    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
So this one?
73 Thing
80 Vanagon Westy
74superTN
PostPosted: Wed Oct 12, 2016 8:41 am    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
I swear my current setup looks like I need this one for two holes
and this one for two holes because they are a little closer together
73 Thing
80 Vanagon Westy
vwed
vwed is offline
PostPosted: Wed Oct 12, 2016 9:04 am    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
I have this available:
http://www.thesamba.com/vw/classifieds/detail.php?id=1942367
busdaddy
busdaddy is offline
PostPosted: Wed Oct 12, 2016 9:43 am    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
Partially correct, whoever swapped the early exhaust on there left the late forward tin in place, you'll need those as well.
That one VWEd posted will work but you'll still need the early forward curved plates.
Слава Україні!
74superTN
PostPosted: Wed Oct 12, 2016 12:12 pm    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
Ok thanks, so these wouldn't work right?
73 Thing
80 Vanagon Westy
74superTN
PostPosted: Fri Nov 04, 2016 2:17 pm    Post subject: Re: Trouble finding a place that sells cooling tins Reply with quote
Alright, found my tins. Ended up having to install an older model forward tin that connects to my bottom sled piece, as suggested..
77 bus with 72-74 lower tins. go figure! Thanks for all the help fellas
73 Thing
80 Vanagon Westy
