knocking on the solenoid is working for now
FreakCitySF
FreakCitySF is offline
PostPosted: Tue Oct 11, 2016 1:13 pm    Post subject: knocking on the solenoid is working for now Reply with quote
So I got to my car after work and click nothing.
I ended up pushing starting it and getting home.
This morning again click but I use a rubber mallet and gently hammer the solenoid and it starts right up.
Any good options currently? I may have a spare solenoid but unknown working condition.
Can I remove just the solenoid or its best to remove the entire starter assembly? I know that will be a job in itself. If I did get it out could I repair the solenoid?
If worst comes to worse I'll take it to the shop but I'd love to see if I have options.
Thanks!
Chris
74 Thing
74 Thing is offline
PostPosted: Tue Oct 11, 2016 4:39 pm    Post subject: Re: knocking on the solenoid is working for now Reply with quote
Typically Things have auto starters in them Bosh SR17x.
More than likely it is the solenoid.
Pulling the starter is not too bad. Disconnect the battery then go under the car and disconnect the battery/alt wires as well as the spaded ignition switch wire. Then there are two nuts-once inside the engine compartment near the firewall and one underneath.
You can unscrew and desolder the solenoid and remove and clean up the copper contacts. Also look at the braided wire between the solenoid and the starter motor.
Here is some info on how to do it:
http://www.thesamba.com/vw/forum/viewtopic.php?t=531782&highlight=solenoid+rebuild+solder
FreakCitySF
PostPosted: Tue Oct 11, 2016 9:22 pm    Post subject: Re: knocking on the solenoid is working for now Reply with quote
Thank you for that! I forget there is a search function!
I now have the starter on the kitchen table ;)
Bashr52
Bashr52 is offline
PostPosted: Wed Oct 12, 2016 4:36 am    Post subject: Re: knocking on the solenoid is working for now Reply with quote
After years of age, its not uncommon for the wiring to get old and corroded and have trouble supplying power to the starter. If you are still having issues after installing a new starter, you may need to install a "hard start" relay.
Wildthings
Wildthings is offline
PostPosted: Wed Oct 12, 2016 2:59 pm    Post subject: Re: knocking on the solenoid is working for now Reply with quote
Old worn or corroded brushes will do the same thing.
Semper_Dad
Semper_Dad is offline
PostPosted: Thu Oct 13, 2016 9:14 am    Post subject: Re: knocking on the solenoid is working for now Reply with quote
I always find that "percussive maintenance" quite useful at times.
74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
World 181 Registry Map:
http://bit.ly/1axDF1r
Gitm registared boys!
Officially, there are only 112 181s in the world
ALANSD
ALANSD is offline
PostPosted: Thu Oct 13, 2016 9:31 am    Post subject: Re: knocking on the solenoid is working for now Reply with quote
my wife uses that on me.. Embarassed
FreakCitySF
PostPosted: Tue Oct 25, 2016 12:10 pm    Post subject: Re: knocking on the solenoid is working for now Reply with quote
dang nabbit!
Starter quit on me again. After about a week of working fine.
I just get the click and thats it.
I'm thinking brushes need a looking into as suggested.
74 Thing
74 Thing is offline
PostPosted: Tue Nov 21, 2017 7:29 am    Post subject: Re: knocking on the solenoid is working for now Reply with quote
edit
CraigInPA
CraigInPA is offline
PostPosted: Tue Nov 21, 2017 7:59 am    Post subject: Re: knocking on the solenoid is working for now Reply with quote
Look on the bright side:
Having a starter that needs a tap to get going means you can leave the keys in the car and not worry that someone will steal it...
