Sage79 Samba Member
Joined: September 13, 2008 Posts: 433 Location: Holland MI
Posted: Wed Oct 12, 2016 7:08 am Post subject: Strange vapor hose behind spare tire well |
Check out the hose behind the spare tire well on my '77. Does the "S" shape seem original or did a straight hose deform to that shape? The metal line from the front definitely slopes to the rear but the hose seems longer than a straight section would have been. _________________ Dirk
'79 Westy 2.0FI
'73 Sportsmobile 1.7dual Solex 003Auto - now my daughter's
'77 delux 2.0FI 090Auto - now my son's |
Joined: January 01, 2007 Posts: 16886 Location: sticksville, ct.
Posted: Wed Oct 12, 2016 7:11 am Post subject: Re: Strange vapor hose behind spare tire well |
it correct, it just dropped. should be straight, but I have seen a few bent like that _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Oct 12, 2016 7:33 am Post subject: Re: Strange vapor hose behind spare tire well |
That doesn't look like the OG hose, I suspect whoever changed it last didn't use enough lube and couldn't get the front section slid on far enough so they said "fu*k it" and left it like that. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Wed Oct 12, 2016 8:03 am Post subject: Re: Strange vapor hose behind spare tire well |
If you look inside the driverside air intake- you will se a little condenser that condenses the fuel vapor from the gas tank back to gas that runs down that tube and into the tank- SO- yup that has to be a good piece of line in there. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Sage79 Samba Member
Posted: Wed Oct 12, 2016 10:10 am Post subject: Re: Strange vapor hose behind spare tire well |
Oh--totally makes sense. The line needs to continually slope back to the gas tank, which it doesn't now. _________________ Dirk
'79 Westy 2.0FI
chimneyfish Samba Member
Joined: July 28, 2009 Posts: 881 Location: United Kingdom
Posted: Wed Oct 12, 2016 10:58 am Post subject: Re: Strange vapor hose behind spare tire well |
This is useful on Ratwell:
http://www.ratwell.com/technical/FuelHoses.html#fitank
(I find it much easier to change that tricky piece of hose when the vehicle is jacked up onto axle stands - you then don't have to become a contortionist to do it). _________________ 1965 Type 1 Deluxe (1200cc)
1976 Type 2 T2b Microbus L (1800cc Type 4)
Previously...
1972 T2 Camper (Devon), 1988 Golf, 1972 Type 1, 1984 Polo, 1972 T2 Camper (Danbury) |
Posted: Wed Oct 12, 2016 12:15 pm Post subject: Re: Strange vapor hose behind spare tire well |
c fish is right- another hint in combination is to remove the stop light housing- then its a straight shot. _________________ some days I get up and just sit and think. Some days I just sit.
Tcash Samba Member
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Sage79 Samba Member
Posted: Wed Mar 15, 2017 10:06 am Post subject: Re: Strange vapor hose behind spare tire well |
Replaced this hose and BD was right (again!). It was a totally shot replacement hose. All good now. _________________ Dirk
'79 Westy 2.0FI
CarlosZ Samba Member
Joined: April 23, 2016 Posts: 319 Location: Los Angeles
Posted: Wed Mar 15, 2017 10:53 am Post subject: Re: Strange vapor hose behind spare tire well |
It took me less than 5 minutes to replace. No need to remove anything unless you're super fat, out of shape or can't bend/kneel. I had to use a slightly longer piece. A little lube will help out a lot. |
airkooledchris Samba Member
Posted: Wed Mar 15, 2017 11:02 am Post subject: Re: Strange vapor hose behind spare tire well |
CarlosZ wrote: |
Did you stick half your body into the engine bay? I don't get why it would matter if your fat.
Now if your a short short man with stubby little arms that might make it harder. At 6.2 I just reached in there and got it done, with my gut happily resting upon the rear valance. |
Posted: Wed Mar 15, 2017 12:02 pm Post subject: Re: Strange vapor hose behind spare tire well |
CarlosZ wrote: |
HEY I resemble that remark. _________________ some days I get up and just sit and think. Some days I just sit.
kooper271 Samba Member
Posted: Wed Mar 15, 2017 12:05 pm Post subject: Re: Strange vapor hose behind spare tire well |
airkooledchris wrote: |
CarlosZ wrote: |
What if you're short and fat? |
Posted: Thu Mar 16, 2017 11:00 pm Post subject: Re: Strange vapor hose behind spare tire well |
I must confess. I installed it with the engine out. I'm sure I could do it as easily with the engine in. |
stevespeirs Samba Member
Joined: June 10, 2008 Posts: 310 Location: Virginia Beach, VA
Posted: Thu Oct 10, 2019 9:28 am Post subject: Re: Strange vapor hose behind spare tire well |
Could be a good time to replace mine. Might explain the faint smell of gas in the engine bay too.
_________________ 1979 Microbus |
Posted: Thu Oct 10, 2019 10:03 am Post subject: Re: Strange vapor hose behind spare tire well |
WD40 makes a great lube for doing a job like this, helping lessen the effort necessary to get the hose to slide on to the tubing. Also I would recommend using 30r9 or 30r14 hoses as they can handle ethanol laced fuel over the long haul. |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Thu Oct 10, 2019 12:21 pm Post subject: Re: Strange vapor hose behind spare tire well |
Wildthings wrote: |
I've come to like using a little smear of dielectric silicone grease for these kinds of things. I suppose it doesn't matter much. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Thu Oct 10, 2019 5:33 pm Post subject: Re: Strange vapor hose behind spare tire well |
Wildthings wrote: |
I've got the Bus Depot 7mm hose and clamps. That'll work, right?
https://www.busdepot.com/n0202811 _________________ 1979 Microbus |
Posted: Thu Oct 10, 2019 5:40 pm Post subject: Re: Strange vapor hose behind spare tire well |
stevespeirs wrote: |
Wildthings wrote: |
https://www.busdepot.com/n0202811 |
Does it say SAE J30-R9 or SAE J30-R14 on it?, if not I wouldn't waste the time to install it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
