ac78 Samba Member
Joined: March 18, 2008 Posts: 330 Location: Nashville
Posted: Thu Oct 13, 2016 8:42 am Post subject: Windshield Wiper Spindle Cover PSA |
Hi All-
I went through a carwash a while back and it had a top brush at the exit end of the tunnel that took my DS wiper for a ride up the windshield. It did not break off and I was surprisingly able to return it to position. It did operate properly until today. I attached some pics as I removed the assembly. There is a shear bolt/hex cup that has enough resistance to allow wiper arm to travel but will strip out to protect the arm and prevent body damage. I have never had one apart so I thought this is a cool design and posted some pics. They are only $1.30-$2.00 a piece so you might want to order a couple to throw in your bag on you next parts run.
I searched here, looked in my Bentley and Chilton's without finding anything on this cap.
Bus Depot calls it a Windshield Wiper Spindle Cover. Other vendors have some as well.
http://www.busdepot.com/211955275a
_________________ 78 Westy 2.0l hydr. FI
VW Campmobile
For people who believe a family's
car should be it's castle ! |
SGKent Samba Member
Posted: Thu Oct 13, 2016 3:39 pm Post subject: Re: Windshield Wiper Spindle Cover PSA |
use a small exacto blade to clean the serrations in the spindle before you push the wipe back on.
Now the bad news, the wiper motor has a plastic gear in it that easily cracks. If it does after that event the wiper will be slow then stop. The fix is in classifieds. http://www.thesamba.com/vw/classifieds/detail.php?id=1720906 |
busdaddy Samba Member
Posted: Thu Oct 13, 2016 4:06 pm Post subject: Re: Windshield Wiper Spindle Cover PSA |
ac78 wrote: |
There is a shear bolt/hex cup that has enough resistance to allow wiper arm to travel but will strip out to protect the arm and prevent body damage. |
There's a possiblility you may have misinterpreted the function of that cap, it's just a cap, purely decorative, the act of retightening the nut in the middle of the arm hole is likely what restored your wiper action.
If that larger nut that holds the pivot to the body is turning with the wipers you have siezed pivot shafts and your plastic gear in the motor is doomed. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
danfromsyr Samba Member
Posted: Thu Oct 13, 2016 4:24 pm Post subject: Re: Windshield Wiper Spindle Cover PSA |
each time the wiper arm moves independent of the center shaft.
you'll want to use a pick and clean out those little grooves, those are what actually do the job you were thinking the plastic nut did..
if it happens alot you'll have removed too much material and would require new wiper arms. _________________
Abscate wrote: |
Tcash Samba Member
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Thu Oct 13, 2016 9:43 pm Post subject: Re: Windshield Wiper Spindle Cover PSA |
That cap is NOT "purely decorative" it acts as a seal to prevent water from getting in the bushing and seizing the shaft. They wear out over time and should be changed. Hard to find good ones these days that do the job. |
ac78 Samba Member
Posted: Thu Oct 13, 2016 10:47 pm Post subject: Re: Windshield Wiper Spindle Cover PSA |
Thank you for all the responses and especially the links. I was not search for terms that would have lead me there. Have check my Bentley again to find that exploded view.
I do find it curious that the cap has a hex end and no value. I did make assumption based on the wiper giving vs getting ripped off the bus. Maybe I'm dead wrong on that and spent too much time changing out snowblower bolts...
I did tighten it back down and seems to be functioning but from what you guys are describing I may have stripped out that gear on the motor a bit.
Edited- btw, is one arm spring supposed to have much more tension on it? My PS was much harder to deal with because of the spring.
Thx! _________________ 78 Westy 2.0l hydr. FI
VW Campmobile
Tcash Samba Member
Posted: Thu Oct 13, 2016 10:59 pm Post subject: Re: Windshield Wiper Spindle Cover PSA |
What happens sometimes is this nut loosens up.
But do to the wiper arm and this shaft being different metals, tapered and splined. The wiper arm gets stuck on there even though the nut it loose. Maybe when the brush hit it, it knocked it loose.
If the nut is tight and the wiper arm still moves, the splines in the arm or on the shaft are stripped out.
Tcash |
ac78 Samba Member
Posted: Thu Oct 13, 2016 11:06 pm Post subject: Re: Windshield Wiper Spindle Cover PSA |
Thx tcash! I'll monitor and take it back apart this weekend for more thorough cleaning. _________________ 78 Westy 2.0l hydr. FI
VW Campmobile
Posted: Fri Oct 14, 2016 7:55 am Post subject: Re: Windshield Wiper Spindle Cover PSA |
Al Capulco wrote: |
Correct, I meant as far as the mechanical function of the wipers it's not a player. But yes it is a seal, the hex is to keep it from rotating along with the shaft.
Ac78, the spring tension should be the same for both arms, springs get weak or bent, or the hinge where it folds away from the glass wears, all add up to crappy wiper performance. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
