aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri Nov 04, 2016 9:45 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
cdennisg wrote: |
SGKent wrote: |
aeromech wrote: |
I need to speak to Cynthia about this but here's my plan.
I have a complete long block in a basket that I purchased a few months ago when I bought my 1971 bus. This morning I spoke to my engine builder, Kenyon Machine, and we agreed that tomorrow morning I can bring this engine to him to inspect and start the process of building the long block. That way, we can save a ton of time.
Cynthia also is considering having me do a brake booster mod because she's having a hard to stopping the bus. I've done this several times with good results and even spoke to my welder Carlos this morning about fabricating a plate and welding it to the beam. |
sounds like a good plan Gary |
Sure does. My only suggestion on a mostly stock 1776 is to makes sure it is dynamically balanced. there is nothing like a long life, smooth running engine. |
Yep. Kenyon has a shop he sends the rotating parts out to for balancing. I'll be sure to include that clutch plate too.
Depending on what he finds, I might opt for brand new heads. Century Distributors sells new heads that use the deep reach T4 style spark plug. Century has been a greats source for parts in the past. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Brian Samba Moderator
Posted: Fri Nov 04, 2016 9:59 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
asiab3 wrote: |
Brian wrote: |
Luckily we have a spare bug you can use I guess. |
Caveat: it doesn't have any brakes sometimes. Want to learn how to work on brakes? |
And rebuild starters _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
chabanais Samba Member
Posted: Fri Nov 04, 2016 10:06 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
Wow those jeans.
I have a 1776 with dual Dells and straight cut cam gears for a little whirring sound and things have been extremely reliable for 6+ years. I think it depends on who builds your motor and how and more importantly upkeep of the engine.
Sad to see VW shops still ripping people off by thousands (what it sounds like to me) and thinking they can get away with it. _________________ "I spud therefore I yam." |
wcfvw69 Samba Purist
Posted: Fri Nov 04, 2016 10:16 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
aeromech wrote: |
Cynthia also is considering having me do a brake booster mod because she's having a hard time stopping the bus. I've done this several times with good results and even spoke to my welder Carlos this morning about fabricating a plate and welding it to the beam. |
How big of an improvement is this Gary on an all drum 70 bus? I've seen your thread where you did this before and was curious what percent improvement it was? Now, I've never driven a booster assisted bay bus before. _________________ Contact me at [email protected]
The Samba member since 2004.
Abscate Samba Member
Posted: Fri Nov 04, 2016 11:09 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
I loved my 1970 with tight adjusted drums and two leading shoes on front, but my 1971 with boosted stock discs was like throwing out four anchors in comparson - they are sweet.
I would hold off on spending her money and get the drums working perfectly though, they are pretty good. _________________ .ssS! |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Fri Nov 04, 2016 11:10 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
wcfvw69 wrote: |
aeromech wrote: |
How big of an improvement is this Gary on an all drum 70 bus? I've seen your thread where you did this before and was curious what percent improvement it was? Now, I've never driven a booster assisted bay bus before. |
If there were unlimited funds available I would consider adding a front disc brake kit and compatible master cylinder along with the booster. $2000 The booster alone will require less foot force but it will not change the stopping distance or eliminate the need for periodic adjustment.
Aloha
tp |
wcfvw69 wrote: |
aeromech wrote: |
It's extreme. Works great. Photobucket is down or I'd show you pictures. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
chicagovw Samba Member
Joined: January 06, 2007 Posts: 1424 Location: Chicago IL/CHandler AZ
Posted: Fri Nov 04, 2016 11:12 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
I am sure sorry to see you having issues, Cynthia, but sounds like you are on the right path now. I know it can be frustrating dealing with issues. Once this is behind you, you should have a good, reliable VW. These really are great vehicles and if sorted properly, give very little trouble. Like anything else sometimes you have to spend some time and money fixing previous issues. Hoping the rest goes well! |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Fri Nov 04, 2016 11:19 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
See you when you get here girl. Ill have either some dogs ready or Jalapeno Pineapple Grilled Chicken Breast.
Drive safe. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Fri Nov 04, 2016 11:23 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
Pretty sure that part of her $2800 went to having brake work done and she is still having trouble stopping.
Several years ago I had a gal named Brook Empe come to me for some work on her very nicely restored 1968 Camper. She said that it was so hard to stop when going down hill that she had to push on her knee with her hand to give more pressure. I installed the booster.... problem solved. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Nov 04, 2016 11:34 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
aeromech wrote: |
Several years ago I had a gal named Brook Empe come to me for some work on her very nicely restored 1968 Camper. She said that it was so hard to stop when going down hill that she had to push on her knee with her hand to give more pressure. I installed the booster.... problem solved. |
I have to admit that I've thought of retrofitting a booster on my bus so my gal can drive it w/more confidence. I've also noticed this bus is much more sensitive to brake pull than my bugs if the front brake pad adjustments get off much. _________________ Contact me at [email protected]
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Fri Nov 04, 2016 12:24 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
and don't forget that English made electric power steering.
can there be an end to it??? somebody STOP ME--- _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Xevin Samba Member
Posted: Fri Nov 04, 2016 2:54 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
notchboy wrote: |
Drive safe. |
Is the Cookout today or next Saturday. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Xevin Samba Member
Posted: Fri Nov 04, 2016 3:14 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
Oops my bad, forgot Im a day ahead of you. Have fun y'all. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Fri Nov 04, 2016 3:16 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
Xevin wrote: |
Oops my bad, forgot Im a day ahead of you. Have fun y'all. |
Dont forget to buy some of that real expensive Emperor tea before you leave. _________________
t3kg wrote: |
1964 1500 S
Clara Samba Member
Posted: Sat Nov 05, 2016 10:30 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
Bummer about your engine issue! _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Sat Nov 05, 2016 11:04 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
Her engine issue has led her to living the next phase of her life with a decent set of folks looking out for her by making her self sufficient.
Getting help when getting started is what it's all about. All the stories about self made people aren't the ones to follow, it's the 99.999% others who did it by learning and giving back as soon as you can. _________________ .ssS! |
SGKent Samba Member
Posted: Sat Nov 05, 2016 2:20 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
Abscate wrote: |
Getting help when getting started is what it's all about. All the stories about self made people aren't the ones to follow, it's the 99.999% others who did it by learning and giving back as soon as you can. |
well said - much of what I have learned in my life if from other professionals who were willing to share and pass on their knowledge. She is in good hands now. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Bleyseng Samba Member
Posted: Sat Nov 05, 2016 9:03 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
Got to meet Emma and Sven plus Cynthia sans Sunny the bus tonight at Jasons.
We jumped in Jason's camper for a ride with his super Camper Special, wow, nice engine! Lot's of other great people so it was fun to meet and talk to you all.
_________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
