Brian Samba Moderator
Posted: Wed Nov 16, 2016 3:32 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
My Model A has mechanical brakes. They suuuck.
Gary, did you drink all my beer yet? _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
pittwagen Samba Member
Joined: November 08, 2005 Posts: 766 Location: North of the 49th parallel
Posted: Wed Nov 16, 2016 3:54 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
I did some research locally and found that CIP has both front and rear 68-70 drums. The better quality rears come from CSP and are made by Sebro in Germany. The fronts come via Econo Intl and are supposedly made in Brazil.
With respect to the drum/drum vs disc/drum matter, I would not have anything but the disc/drum for our climate. I drive my 79 year round and this time of year it rains plenty - all but 4 days since Oct.1. Lots of heavy rain and water pooling from time to time. With commercial grade winter tires my van is stable and predictable. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Wed Nov 16, 2016 5:51 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
What beer?
Okay, well you all dying for the update so here it is. I got the bus today around 4pm. Here are several pictures so you get an idea of what it's like.
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Wed Nov 16, 2016 5:54 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
So here's my list right now. There are other things wrong not on the list right now but they will be fixed also.
1) Brakes need work and the booster will help a lot
2) I smelled fumes inside while driving but later found the rear hatch ajar so that might have been the cause
3) There is a whine in the engine which might be the alternator bearings
4) The hold open catch for the sliding door needs to be adjusted
5) Not sure what that gauge is in the dash but I'd get rid of it. Either install a tach or just go back with a stock blank off which I happen to have
6) Transmission pops out of third. You have an actual 1968 original transmission which isn't a good thing. I just called my tranny guy Eric at Transworks and he can fix yours but the cost will be around $1300 and take 3 weeks or so. Might be better to find a replacement transmission (002) from a 1969-1971 bus to install if possible because of the time. Now is the time to fix this because the engine needs to come out for Carlos to do the welding on the air cleaner stand. Carlos is scheduled to come here after work on Friday to do the booster plate as well as the stand. BTW, where is the stand? I didn't see the oil bath either. Could they be in the wooden box?
7) Your reverse lights need to be connected
The gas filter needs to be relocated out of the engine bay for fire safety
9) Gear shifter is sloppy and you might need a new front shift shaft bushing (which I have)
10) Gas filler lid lock needs to be repaired to work
11) Ignition switch. Not sure right now what to do (if anything) about that.
Lots to fix. Lots to prioritize _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Posted: Wed Nov 16, 2016 6:04 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
Gary, I'm pretty sure the '68 ingintion switch is a one year only.
I only paid $450 for my '73 002 from a member on thesamba. $1300 sounds really high, Az Transaxle will be cheaper then that. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
airschooled Air-Schooled
Posted: Wed Nov 16, 2016 6:19 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
I have a core 69-71 002 in my storage unit. I'll gladly swap you cores if the RnP are quiet.
Party on Sunday? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Wed Nov 16, 2016 6:28 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
Party on Sunday?
Yeah, and we're drinking on Brian. Actually the fun starts sooner than that. I might be pulling the engine tomorrow.
The transmission would normally be an $800 overhaul but since it's an actual 1968, Eric said he'd need to swap over several parts which would drive up the cost. I'd much rather find a good 002 from a later year. Eric called it a boat anchor. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Wed Nov 16, 2016 6:59 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
That's the shitty throttle positioner I was telling you about. Definitely the source of that high idle. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Posted: Wed Nov 16, 2016 7:38 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
OB Bus wrote: |
Gary, what carb in on the engine? |
No clue right now _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Brian wrote: |
That's the shitty throttle positioner I was telling you about. Definitely the source of that high idle. |
Okay, you're in charge of fixing that _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Wed Nov 16, 2016 7:46 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
aeromech wrote: |
Brian wrote: |
Okay, you're in charge of fixing that |
Don't the Stu rules apply for Brian too? _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Bleyseng Samba Member
Posted: Wed Nov 16, 2016 10:44 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
If hookup and adjust the throttle positioned fight they work great. Took me awhile to get it right on my 70 Ghia but they work fine and font screw up the idle.
I think all the bug and bus 68-70 take the same ignition components. If the part that's there isn't destroyed then installing the key part is easy
_________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
chabanais Samba Member
Posted: Thu Nov 17, 2016 11:48 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
This Bus is getting more expensive by the week. I wonder if the PO knew all of the issues he was passing along to the new owner.
I hope the OP can see this project through financially and that she gets good insurance coverage for it. _________________ "I spud therefore I yam." |
Posted: Thu Nov 17, 2016 11:52 am Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
chabanais wrote: |
I hope the OP can see this project through financially and that she gets good insurance coverage for it. |
Totally! the bus is solid but lacked knowledgable maintanence. I experienced the same thing with my westy and ghia. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Thu Nov 17, 2016 12:08 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
Quote: |
]This Bus is getting more expensive by the week. |
Don't they all...
Quote: |
I wonder if the PO knew all of the issues he was passing along to the new owner. |
Probably. But people get used to having old vehicles like that, where half of it doesn't work right (or at all). It becomes "normal". He probably didn't think anything of it. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Thu Nov 17, 2016 12:12 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
telford dorr wrote: |
Don't they all...
Probably. But people get used to having old vehicles like that, where half of it doesn't work right (or at all). It becomes "normal". He probably didn't think anything of it. |
Ignorance is bliss. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Thu Nov 17, 2016 12:15 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
I just arranged for Kevin at KCR Transmissions in Riverside to build her a new transmission. The cost is $1k out the door cash deal, no core. She will pick it up Saturday morning on her way to San Diego from Los Angeles.
I asked Telford to come by this afternoon and help me assess the bus. We'll drive it and check all the electrical out. Then develop a list we can prioritize.
The original plan was to pull the engine today but I think it's better to wait a bit so Telford can drive it before it's all torn apart. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Thu Nov 17, 2016 12:19 pm Post subject: Re: Story of a girl and her new Volkswagen Bus, Sunny |
aeromech wrote: |
The original plan was to pull the engine today but I think it's better to wait a bit so Telford can drive it before it's all torn apart. |
Did you get the later trans you wanted? _________________
t3kg wrote: |
1964 1500 S
