PEPPE Samba Member
Joined: August 24, 2003 Posts: 1068 Location: Roma Italy
Posted: Mon Apr 29, 2019 10:09 pm Post subject: Re: Rebuilding a German throw out bearing |
i do this regularly here, but not all of them can be saved. most has wear in the fixing "ears", where they ride on the fork. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5995 Location: Brooklyn
Posted: Mon Apr 13, 2020 3:22 pm Post subject: Re: Rebuilding a German throw out bearing |
Just wanted to give a shout-out to Zundfolge1432 for this thread.
Thanks to his guidance I was able to rebuild two old-style throwout bearings.
One of them was an NOS Sachs bearing that I bought and ran. It gave me about 9000 miles of service before the however-many-year-old grease inside finally liquified and exited the bearing (I initially thought it was engine oil in the bell housing, but no, it was the remains of throwout bearing grease).
So, note to others, if you do buy one of these NOS, better rebuild it before running it just to get some fresh grease in there.
The other one I had in the stash of parts that came with my car was the original one from the car back in 1965. Visually different in that the outer housing is fully round rather than having the flat spots at top and bottom that the newer ones have.
It still spun but it sounded dry. Took it apart, bearing cage was metal. Luckily all the balls and races were good and I was able to rebuild it.
So now I have what should be a lifetime supply of high quality throwout bearings ready to go. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
RWK Samba Member
Posted: Mon Apr 13, 2020 4:41 pm Post subject: Re: Rebuilding a German throw out bearing |
Make sure you use the Bo$ch di$t. grea$e ! _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6594 Location: Houston, Texas
Posted: Tue Apr 14, 2020 2:05 pm Post subject: Re: Rebuilding a German throw out bearing |
I wouldn't use distributor grease in a throwout bearing but I would use it in a distributor.
Wheel bearing grease should be ideal for a throwout bearing. _________________ 1965 Volkswagen 1500 Variant S
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
