Ben Middleton Samba Member
Joined: April 11, 2016 Posts: 219 Location: England, UK
Posted: Tue Oct 18, 2016 5:53 am Post subject: Fitting Thermostat Flaps Without Dropping Engine |
Hi guys,
The engine cooling flaps are currently missing from my engine, but I've managed to buy some replacements. I was wondering, can I fit them without removing the engine? If so, does anybody know the best method?
Thanks,
Ben |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76896 Location: Sneaking up behind you
Posted: Tue Oct 18, 2016 6:17 am Post subject: Re: Fitting Thermostat Flaps Without Dropping Engine |
Type 1 or Type 4? _________________ Glenn
Member #1009
#BlueSquare |
Bleyseng Samba Member
Posted: Tue Oct 18, 2016 6:54 am Post subject: Re: Fitting Thermostat Flaps Without Dropping Engine |
His pics in his gallery are of type4 so yes you can! Remove muffler, heat shield, assorted tin and then the half of the fan housing, Install flaps and put everything back together. Then install the thermostat wire so when cold it shuts the flaps and warm opens them. Pretty easy to do all this in a couple of hours unless everything is grimy dirty then clean clean everything esp. inside the fan housing and the fan itself as oily dirt slows down airflow. Do not take the fan apart. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Tue Oct 18, 2016 8:25 am Post subject: Re: Fitting Thermostat Flaps Without Dropping Engine |
Ahh OK, that sounds good. Yeah, it is a type 4 engine. I thought of taking the cylinder shrouds off and going in that way. Is that a more difficult procedure? |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Tue Oct 18, 2016 8:55 am Post subject: Re: Fitting Thermostat Flaps Without Dropping Engine |
You just have to take off the whole induction system, and all top components. Also realigning the big tin pieces with the firewall and lower forward tins may be a pain in the ass.
I have pulled the shroud assembly before with the motor in place. You can get at it without lowering the exhaust, but it's a tight squeeze. I replaced the 4 studs the shroud bolts to the motor on with bolts so it is much easier to remove, should I ever need to in the future _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
Posted: Wed Oct 19, 2016 8:13 am Post subject: Re: Fitting Thermostat Flaps Without Dropping Engine |
Thanks for the info guys. I'll probably try taking the front assembly off.
Unfortunately I bought a broken cooling flap that I thought was OK. Does anyone have any photos of what it should look like with the clips on there? Also, I don't know how the back of the flap fits inside the hole. Could anyone explain for me please?
Thanks!
eche_bus Samba Member
Posted: Thu Oct 20, 2016 7:29 pm Post subject: Re: Fitting Thermostat Flaps Without Dropping Engine |
Thanks for adding that photo. I had a look at your build thread too; very informative! I have now replaced my broken pieces.
Today I tried to fit the thermostat flaps. I couldn't see how I could fit them without removing the top shrouds, so I thought I'd remove those first. I removed the inlet manifolds and all the screws for the shroud on the oil cooler side, and then realised that it is trapped behind the firewall. I'm not sure how to get it out.
I have also discovered what seems like a more serious problem. I lifted the shroud enough to fit my hand where the oil cooler flap should go. I felt for the two prongs inside the casing which the flap should clip on to. I could only feel one prong. Is this is a serious problem? Does anybody know of a good solution?
Thanks again for your help! |
