Albertoprop17 Samba Member
Joined: March 15, 2016 Posts: 196 Location: Valencia (Spain)
Posted: Tue Oct 18, 2016 6:34 am Post subject: CB performance EFI on a wbx? |
Hi, I'm looking to put on my 2.1 dj wbx the cb performance EFI kit.
Does it fit on an '89 westy vanagon? I need to do modifications?
Greetings from Spain |
Posted: Thu Oct 20, 2016 5:49 am Post subject: Re: CB performance EFI on a wbx? |
Nothing? |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Thu Oct 20, 2016 6:23 am Post subject: Re: CB performance EFI on a wbx? |
Yes, you could install CB's EFI ecu on your WBX, and modify their harness to work with your injectors and sensors. You *may* need to come up with a solution for the crank trigger-wheel, as it *may not* clear the WBX pulley (or it might...you'll need to do that leg work).
CB's intake manifolds would need significant porting to fit your heads, but will not clear the engine bay. Their exhaust (if you're contemplating turbo'ing your engine) would need 2 of the flanges modified for the WBX exhaust stud pattern.
Considering the question you are asking indicates that you are at ground-zero on the learning curve, why not research ECUs that are common on the European market, and find out which ECUs tuners local to you are using? _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Sun Oct 23, 2016 2:54 pm Post subject: Re: CB performance EFI on a wbx? |
Stripped66 wrote: |
Considering the question you are asking indicates that you are at ground-zero on the learning curve, why not research ECUs that are common on the European market, and find out which ECUs tuners local to you are using? |
I'm going to put that engine on an original 1.9 wbx with carburator, so I didn't have the original ECU and the injection system is in bad conditions.
If I put the CB kit, I'll use all it's stuff. I don't want turbo power, I'll run on NA.
So I need to adapt a sensor to my engine pulley?
Sorry but I'm lost in this matter
Posted: Sun Oct 23, 2016 5:40 pm Post subject: Re: CB performance EFI on a wbx? |
Albertoprop17 wrote: |
There's a solution offered here:
http://thedubshop.goodsie.com/wasser-oxy-boxer-crank-trigger-package _________________
66brm wrote: |
Bodacious wrote: |
Mavelotta Samba Member
Joined: March 27, 2006 Posts: 50 Location: Monroe, Wa.
Posted: Mon Oct 31, 2016 10:15 am Post subject: Re: CB performance EFI on a wbx? |
Thanks Stripped66!
I just so happen to have a couple wasser pulleys available for exchange right now. Seeing your in Spain Albertoprop17, it may be more effective to just pay a core charge for a pulley instead of sending yours to me. _________________ The Dub Shop
[email protected]
Facebook-Tech-Store |
Posted: Fri Nov 04, 2016 11:14 am Post subject: Re: CB performance EFI on a wbx? |
Mavelotta wrote: |
Thanks Stripped66!
I just so happen to have a couple wasser pulleys available for exchange right now. Seeing your in Spain Albertoprop17, it may be more effective to just pay a core charge for a pulley instead of sending yours to me. |
Yes, I think it's the best solution
If I put the EFI, I will contact you |
