Is this plug too lean? |
Too lean |
50% |
[ 7 ] |
Just right! |
42% |
[ 6 ] |
Too hot. |
7% |
[ 1 ] |
Total Votes : 14 |
vamram Samba Member
Posted: Tue Oct 18, 2016 8:28 am Post subject: Poll - too lean or just right? |
Just pulled the plugs on my '72 Super to check them due to the bug recently not starting on the first hit of the key after doing so for as long as I can remember. I was thinking that perhaps it was running rich also because of my MPG dropping after recently installing a new POS chinese mechanical fuel pump.
_________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Tue Oct 18, 2016 10:00 am Post subject: Re: Poll - too lean or just right? |
It looks a little on the lean side--certainly not rich. But not too lean, in my opinion.
How long have those plugs been in?
Are you starting the car according to the owners manual? Has it been sitting for, say a week?
I always start my engine for the first time, by slowly pressing the pedal to the floor and letting it up slowly to engage the choke. All other starts in the day, I just start normally (just a little pedal).
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Tue Oct 18, 2016 10:01 am Post subject: Re: Poll - too lean or just right? |
Richard O'Brien |
vamram Samba Member
Posted: Tue Oct 18, 2016 10:19 am Post subject: Re: Poll - too lean or just right? |
Tim, this is my '72 and my daily driver. I put about 25/miles a day on it, sometimes more. And I start it per the manual (I think) - one quick pop of the pedal to engage the choke when it's cold, turn the key. When hot, slowly press down on the gas pedal. Oh, and I wouldn't characterize this as a "hard start" problem at all. Despite my description, I NEVER have to lean on the key for more than 2-3 seconds for it to start.
[EDIT] oh and the plugs have several 1000 miles on them. They're the NGK B5 something-or-other (i think that's the brand and model) plugs. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Agent47 Samba Member
Joined: April 22, 2016 Posts: 271 Location: Scott AFB
Posted: Tue Oct 18, 2016 10:27 am Post subject: Re: Poll - too lean or just right? |
Tim Donahoe wrote: |
Tim |
x2
I would expect to see a little more carbon on a the base of the plug. _________________
TDCTDI wrote: |
... The VW beetle is the cockroach of the automotive world, no matter how many are killed, there always seems to be 100s more lurking in all the cracks & crevices. |
Posted: Tue Oct 18, 2016 11:51 am Post subject: Re: Poll - too lean or just right? |
I run NGK B5HS plugs, gapped at .025.
Bently says .025 for carbed models, and .028 for fuel injection. My original Owners Manual says to gap at .028. So what's a guy to do? I just gap per Bently and assume the longer the plugs are in there, the wider the gap will become. However, when I pull them, they never seem to increase in gap. But, I don't put enough miles on the car. After a round of harder summer starting--when the engine was warm and sitting for about a half hour--I replaced my plugs with new ones that probably have fewer than 4000 miles on them. They were a little darker than yours, but not by much--a tad more carbon.
By "harder starting", I meant that it wouldn't fire up on the first, short try. The new plugs seemed to help, but I believe that unless you gas it perfectly when the engine has been for a run (and you spent a good half hour, letting it sit), a second try is sometimes necessary because that's just what carbed acvw's do sometimes.
Starting cold: easy.
Starting hot after a short period after shut down: easy. Barely any pedal required.
Starting warm after awhile--say over a half hour--requires an experienced touch on the pedal that works most of the time, but not always. Thus, it's necessary to go at it a second time.
Either time, however, I never have to turn the starter more than a second or two, unless I've flooded it, and three or four seconds is required.
I've found that learning my engine's starting requirement's, according to its temperature, pretty much assures first-crank fire ups.
But, I also check my point gap, timing, and valve adjustment fairly often: once every four months, or thereabouts.
I'd re-check your plug gaps, then reinstall them.
Richard O'Brien |
mark tucker Samba Member
Posted: Tue Oct 18, 2016 2:24 pm Post subject: Re: Poll - too lean or just right? |
check oil to see if the fuel pump is putting fuel in the oil for the droped mpg. the mix looks ok a tad leen for my likeinngs, but not that bad. pull them all to get a good idea. possiably a valva adjustment too. and air cleaner cleaning/replacing. timing check. and check for kids stealing your fuel.....well it used ot be kids not it could be your neibor's dad . also sometimes it's the connection between your brain and thoughts and then back to your brain down to your foot. if somethen is going on that wasent it can change your driving habbits enough to change the mpg but not enough for your brain to see the change....also traffic patterns and extra morons in the way can cause it....as well the loose nut behind the wheel. |
Posted: Tue Oct 18, 2016 4:10 pm Post subject: Re: Poll - too lean or just right? |
Actually, a too-rich condition would cause poorer gas mileage--not too lean.
Victor, is your timing right on? Do you get a nice advance when you reve it up?
Richard O'Brien |
vamram Samba Member
Posted: Tue Oct 18, 2016 5:20 pm Post subject: Re: Poll - too lean or just right? |
Timing is spot on 5* ATDC. It advances to a out 32* BTDC at 3k+ RPM, so about 37* total advance. It's a German bosch DVDA dizzy that's correct for a '71 autostick based on glutamodo's chart. 205AJ I think.
I have the same plugs as u, Tim, but I gapped them to .28. No gas thieves on my street as far as I know...valves set to.005 about 1k miles ago. Definitely the occasional issue with the nut behind the wheel. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
