Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3467 Location: Charleston, SC
Posted: Sat Oct 22, 2016 9:44 am Post subject: Re: SPEC stage 1 pressure plate/clutch vs Kennedy Stage 1 |
fuguboy wrote: |
Who makes The "spec"Clutch is it USA or chona? |
IIRC, they are located in Alabama. They offer clutches for most cars, and I am fairly confident they are assembled here in the US, but also confident the stampings, diaphragms and shoes are all made in Asia. At least that's what I received the last time I ordered from them. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
fuguboy Samba Member
Posted: Fri Oct 21, 2016 12:01 pm Post subject: Re: SPEC stage 1 pressure plate/clutch vs Kennedy Stage 1 |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Oct 21, 2016 8:54 am Post subject: Re: SPEC stage 1 pressure plate/clutch vs Kennedy Stage 1 |
Go lightest clutch you can for your driving style, its like having a fuse in your electrical system, a blown clutch is a lot cheaper to replace than having your $1000 transaxle in parts and pieces and dripping goo on garage floor...
Also excessively heavy clutch will make your left leg larger then your right leg and if you drive vehicle a lot you left leg will ache more...
I gave 1700 KEP in buggy and its almost more clutch than I need, but then I start by getting car to roll and once slack is out of drive train I bump throttle up and release clutch all the way, can still can do wicked burnouts... IF you are just cranking up the revs and side stepping clutch, BANG, you are going to break something with monster clutch...
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4338 Location: Los Angeles, CA 90016
Posted: Thu Oct 20, 2016 9:50 pm Post subject: Re: SPEC stage 1 pressure plate/clutch vs Kennedy Stage 1 |
And maybe not even then. Mike Lawless had an 1800# clutch and a really good disc setup when he was making 250-260HP N/A. Wheelies all day. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15280 Location: Deep in the 405
Posted: Thu Oct 20, 2016 4:52 am Post subject: Re: SPEC stage 1 pressure plate/clutch vs Kennedy Stage 1 |
Having too much Pressure plate is very harsh on parts and you will break your transaxle. You do not need a stage 2 until you get around 190-200 HP. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
sweetguth Samba Member
Posted: Thu Oct 20, 2016 4:19 am Post subject: Re: SPEC stage 1 pressure plate/clutch vs Kennedy Stage 1 |
I had a spec before wit no issues. I have a kennedy now but haven't got it put on. The stage 2 is the same price and has a bit more tolerance depending on your final torque concerning ur setup.
If you think u may eventually may go bigger and better u may want to consider the stage 2. One less thing to do down the road. |
Posted: Tue Oct 18, 2016 9:33 pm Post subject: Re: SPEC stage 1 pressure plate/clutch vs Kennedy Stage 1 |
Balance either one and run it. |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Tue Oct 18, 2016 11:25 am Post subject: SPEC stage 1 pressure plate/clutch vs Kennedy Stage 1 |
Any big differences in performance/quality or pretty much same thing? Thanks _________________ 1963 Ragtop Bug |
