looking for dual solex28 pci linkage
Pirulero1986
Pirulero1986 is offline
PostPosted: Thu Oct 20, 2016 5:10 am    Post subject: looking for dual solex28 pci linkage Reply with quote
i'm looking for a dual solex 28 pci linkage for my car
manifolds doesn't have any part to fix a linkage
in your opinion what will be the best solution?
thanks
michele
tobiasax
tobiasax is offline
PostPosted: Thu Oct 20, 2016 9:02 am    Post subject: Re: looking for dual solex28 pci linkage Reply with quote
thanks
michele
What engine do you have? The earlier engines has less options than the post-August-1960 ones. Also, hos period correct do you want it to be? CSP carries a lot of options for the newer and their linkage for the WW Okrasa is a god base if you have the earlier style.
__________________________________________
exotic plants
exotic plants is offline
PostPosted: Thu Oct 20, 2016 2:16 pm    Post subject: Re: looking for dual solex28 pci linkage Reply with quote
Post a picture of your manifolds here. That will help to answer your question precisely.
But for examples:
If carbs are side to side set up, then CSP is a good option.
If carbs are front to back set up, then probably best to get a custom Gene Berg linkage.
If it is a cable linkage then motorcycle shop or bicycle shop.
1956 Beetle - Jungle Green.
Parts needed to complete:
Front driver side fender.
Rear driver side fender.
Cash waiting.
