ldj1002 Samba Member
Posted: Thu Oct 20, 2016 6:14 am Post subject: Brake fluid hose |
Will fuel line from the master cylinder reservoir to the master cylinder be OK? |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
gt1953 Samba Member
Posted: Thu Oct 20, 2016 9:17 am Post subject: Re: Brake fluid hose |
Use the correct hose or have major issues. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Fri Oct 21, 2016 5:38 pm Post subject: Re: Brake fluid hose |
gt1953 wrote: |
Use the correct hose or have major issues. |
In a hurry and don't want to wait for shipment to come. Went to several FLAPS no help there. Someone suggested a place called "Tubes and Hoses" Checked with them and said yes we have it, it's called remote reservoir brake hose. He said don't use it for anything except brake fluid. I said let me have it. Got it home and got to looking at it and it looks just like plain ole rubber hose. Now I am worried . I cut a small piece off and put in brake fluid. Should a day in the fluid and if it doesn't get soft or swell be a good enough test to see if it will be OK. I also cut a small piece of fuel line and put in to make a comparison. |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2408 Location: Gladstone, Ore
Posted: Fri Oct 21, 2016 6:11 pm Post subject: Re: Brake fluid hose |
You got time to see if rubber melts but no time to wait a couple days for shipping? _________________ 1972 1302
HPMX 40's & 019 |
Posted: Fri Oct 21, 2016 8:38 pm Post subject: Re: Brake fluid hose |
cletus_zuber wrote: |
You got time to see if rubber melts but no time to wait a couple days for shipping? |
I didn't say I didn't have time to wait, I said I didn't want to. If I have to wait I will. I just can't believe that all the things that use master cylinders with remote reservoirs and slave cylinders that the vw uses something that isn't available local. Monday I'll got to truck shops, Industrial equipment and even brake shops. I'll bet some of them will have hoses that carry brake fluid and that they didn't have to go to a VW bug supplier to get it. |
birddog1 Samba Member
Posted: Fri Oct 21, 2016 9:37 pm Post subject: Re: Brake fluid hose |
Well it is a 40+yr old car. Want to have fun? Try going to a local store looking for 40yr old Fiat parts. VW doesn't make anything for ACVW's anymore so count ya blessing we still can get hoses that are comparable.
That said you probably could get away with any hose that is compatible with our brake fluid as long as it's the right metric size which frequently is a problem finding in USA. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Fri Oct 21, 2016 9:44 pm Post subject: Re: Brake fluid hose |
The hose you bought should have a manufacturer name and number or description printed on it. Google that info and you should find complete info for that hose and what it is compatible with. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
helowrench Samba Member
Joined: August 27, 2003 Posts: 567 Location: dallas texas
Posted: Sat Oct 22, 2016 1:22 am Post subject: Re: Brake fluid hose |
he last time I needed the blue reservoir hose, I got it off of Amazon _________________ Current VWs:
70 bug vert for wifey
73Thing bucket o rust
73 914 1.7
12 Passat 2.5 Highway cruiser |
goober Samba Member
Posted: Sat Oct 22, 2016 4:56 am Post subject: Re: Brake fluid hose |
I bleed and put fresh DOT 3 brake fluid in my Bugs every two years.
I've been using regular 3/8" gas line to connect the reservoir to the m/c for years. I haven't noticed any weeping of brake fluid through the hose. When I bleed the system I see no bits of rubber nor is the brake fluid blackened. Maybe it's just luck and/or the type of gas line I've used.
This is only my experience and I make no claim other than that. I'm no rubber materials expert nor have I done any research on the subject. |
