z33taxi Samba Member
Joined: October 15, 2016 Posts: 119 Location: Troy, NY
Posted: Thu Oct 20, 2016 7:56 am Post subject: First beetle. 1968 1600SP. winter refresh/rebuild |
Good morning, I'm Phil. I have recently purchased a 1968 Bug w/ a 1600SP. This is my very first beetle and its everything I wanted it to be. My best friend has a 66, but its slammed and that's cool, but not exactly my taste. I've always loved the look of rally cars and especially the long distance cars like the Peking to Paris or the Panamerica. That was always the idea I had for my beetle. At first I thought it would just give it the aesthetics, but then....my motor went. I was having a great day cruising around lake George and the Adirondacks when I noticed the car was not accelerating anymore. Pulled over and saw some smoke, I turned the car off and it stayed that way. Car wont turn over, can't turn the crank. So I got it towed down and now I'm diving in.
They day I took delivery
Next to the DD
That time I "totally" beat a shelby in a drag race
Downtown Ballstion spa,NY show
how she sits now
was my first time pulling a motor. Did it by myself. It went east until the valve cover latch snapped up and cover flew off mid drop.
Here is a list of things I want to get done this winter; though it is doubtful I will get to finish them all:
enigne
Rebuild engine
-Look into DP set up
Doghouse oil cooler
Full flow oil system
Remove heater tubes. Car will never be driven in cold weather.
Interior
POR15 the pans. Top and bottom
Carpet/sound deadening
Convert to all metal dash
Gauges: Oil temp/oil pressure/volt/tripometer/map lights/fuel
door cards/window scrapers
exterior
Fog lights
-Cibie
kamei spoiler
roof rack
new rubber seals
suspension
LSD
wheels/tires
drum to disc
skid plates
drop spindles???
some inspirational beetles:
Thank you for reading my build thread. I look forward to posting more and to any criticism or suggestions.
-Phil |
gt1953 Samba Member
Posted: Thu Oct 20, 2016 9:14 am Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
I get where you want to take your VW.
Do your homework on the engine. Not sure if the engine case is a single relief, dual relief case is better. Nothing wrong with a single port.
For safety when I remove an engine a minimum of two, four is better, one on the jack, two on the engine, one ready to dial 911. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Thu Oct 20, 2016 10:38 am Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
gt1953 wrote: |
Not sure if the engine case is a single relief, dual relief case is better. Nothing wrong with a single port. |
I havent come across this concern in my research will have to look into it more
gt1953 wrote: |
For safety when I remove an engine a minimum of two, four is better, one on the jack, two on the engine, one ready to dial 911. |
Sucks when you live alone in a new city and don't know anyone that's into cars |
Air-Cooled Head Samba Member
Joined: October 15, 2002 Posts: 4070 Location: Chicago Suburbs
Posted: Fri Oct 21, 2016 11:45 am Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
Welcome Phil!
z33taxi wrote: |
-Phil |
What ya got there, Phil, sounds like a seized motor. Likely a spun bearing on the crank. Happened to me.
Despite that, I think SP engines are ultra-reliable; nearly bullet-proof.
What's the number under the gen stand? Does it start with "H5"? H5 engines are notorious for being "soft". It's also probably single relief.
If I were in your situation, I'd rebuild the engine as is. You don't get much ROI for the expense of upgrading to DP, especially on a single relief H5 case.
Meanwhile, I'd be saving my $$ and doing research into the more powerful go-box of my dreams.
Good luck, and welcome to the club. _________________ Everything known to man has been written.
Readers are Leaders! |
curtp07 Samba Member
Posted: Fri Oct 21, 2016 12:14 pm Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
That's a great car..I've been looking at that same photo of the silver and black...I'm thinking the same rally car conversion. _________________ Subaru |
Posted: Fri Oct 21, 2016 1:13 pm Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
Air-Cooled Head wrote: |
Welcome Phil!
z33taxi wrote: |
-Phil |
Good luck, and welcome to the club. |
I was just having too good of a day when it happened. I was pushing it for too long at highway speeds, around 65/70. Went up a hill, noticed a the speed dropped, but when I flattened out the car would not accelerate and when I pulled over saw some smoke. Turned the car off and let it cool down. From there sounds like it wanted to turn over, but wouldn't.
Live and learn.
At the suggestion of a friend I picked a Gene Berg oil temp dipstick, but I plan on running a oil temp sensor.
Also, the number under my gen stand is AE 946702 which doesn't make sense because it is definitely a single port motor
curtp07 wrote: |
That's a great car..I've been looking at that same photo of the silver and black...I'm thinking the same rally car conversion. |
His build thread is amazing
http://www.airspeedparts.com/forums/index.php?topic=19982.90 |
Posted: Fri Oct 21, 2016 1:28 pm Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
double post |
Beetlebaum Samba Member
Joined: December 04, 2008 Posts: 2181 Location: Virginia Beach, VA
Posted: Fri Oct 21, 2016 8:32 pm Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
Beetlebaum wrote: |
Good luck with the car! It looks like a fun one. |
I hope it turns out that way. I just have to beat back the anxiety and approach everything carefully. |
Posted: Sun Oct 23, 2016 7:17 pm Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
z33taxi wrote: |
Beetlebaum wrote: |
I learned everything I know about cars on my '73 over the eight years that I've owned it (I bought it when I was fifteen). You can do it--just go methodologically, take pictures, make notes, and spend a lot of time browsing this site! Looking forward to seeing your progress. _________________ 1973 Super Beetle
2003 New Beetle
Post your Super here: http://www.thesamba.com/vw/forum/viewtopic.php?t=331999
Beetle Bums VW Club Member |
Zundfolge1432 Samba Member
Posted: Mon Oct 24, 2016 5:46 pm Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
z33taxi wrote: |
Welcome Phil!
z33taxi wrote: |
-Phil |
Live and learn.
Also, the number under my gen stand is AE 946702 which doesn't make sense because it is definitely a single port motor |
Here's something to consider. I can take a dual port engine AE,AE, doesn't matter remove the four upper center studs and install single port heads and presto change O you've got a single port. It works the other way as well I can build a use dual port engine using 66-70 case by changing those same studs. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Mon Oct 24, 2016 6:35 pm Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
Zundfolge1432 wrote: |
Back in 1976 I made a 1970 1600cc SP engine into an 1835cc DP engine. So not uncommon for engine not to jive with original engine number details. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Oct 25, 2016 9:07 pm Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
Ah ok that makes perfect sense. I just want to make sure when I start ordering parts they are the correct size and fit. |
Posted: Thu Oct 27, 2016 2:17 pm Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
I forgot I had this(I'm addicted to vintage racing memorabilia and other signs). Hopefully the beetle will earn its own rallye plaque in the near future.
In more depressing news, my daily driver decided it didn't need 2 rods and threw them out. I am not even going to attempt to fix it or have it fixed, I'm just not that cash rich right now
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Thu Oct 27, 2016 2:27 pm Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
Want a racer??
This might be the perfect time to transplant the engine from your daily driver into your bug and make your bug the daily driver.... surprised no one caught that one yet... I hope for your sake that the reason that I don't see any badge on the silver car is that you pried the STi badge off for a cleaner look of the rear end _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much!
Posted: Thu Oct 27, 2016 2:30 pm Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
My yoke just came in the mail, so that's good news. Tomorrow I will pick up an engine stand from Harbor F. I understand I will have to do some drilling to make it spin and whatnot.
Soon it will be time to tackle this little fella.
I'm really hoping this becomes somewhat therapeutic because I really need it. Burning the candles at both ends just isn't working for me anymore. |
Posted: Sun Oct 30, 2016 4:47 pm Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
Started to tear my carb down tonight. Overall it looked decently clean, there was some small traces of rust/browning. It was my first time tearing down a carb and it was overall a fun time. Learned a lot about how they work and have a much better understanding about them.
Good carbs vs bad carbs
Bought a rebuild kit and J bugs and it came with a nice tear down schematic for both the 30Pict/1 had the 34 series.
SO many tiny pieces. I actually managed not to drop or lose anything
It's currently soaking in a gumout carb bucket. Will let it stew for a day and see how it turns out
I picked up the sweet enamel sign off ebay from a man living in Ukraine. It's repainted but I love how it looks.
[/b] |
Posted: Sun Oct 30, 2016 11:56 pm Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
got bored, so I decided to start tearing out the interior. I took all the lap belts out which was straight forward. The front seats rails are soaking in PB blaster because they would not budge and it 2AM and didn't feel like using a mallet and wake the neighbors up. The only thing I couldn't figure out is the backseat. I got the bench out, but they back presented some issues. I searched on here and it seems people were just focused on getting it to drop flat. I found the bar and pull on the side, but it seems that there is fabric sewn into the seat back that extends into the luggage area?
The "plan" was to possibly go without a backseat for a rally appearnce and for storage boxes; so I don't know if taking out the sharp blades is the way I want to go. Any input on how to get this seat out? Id love to be able to get back there and get a wire wheel on the metal and start hitting the interior with POR15.
[b] Not a beelte, but I love this guys approach to his 2 stroke Saab rally car.
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1597 Location: The South Zone
Posted: Mon Oct 31, 2016 7:03 am Post subject: Re: First beetle. 1968 1600SP. winter refresh/rebuild |
z33taxi wrote: |
. . . The only thing I couldn't figure out is the backseat. I got the bench out, but they back presented some issues. I searched on here and it seems people were just focused on getting it to drop flat. I found the bar and pull on the side, but it seems that there is fabric sewn into the seat back that extends into the luggage area?
The "plan" was to possibly go without a backseat for a rally appearnce and for storage boxes; so I don't know if taking out the sharp blades is the way I want to go. Any input on how to get this seat out? . . . |
I converted my back seat into a cargo area a few years ago (check out my gallery photos if you want a pic of it), and it's been a while since I messed around with any VW interiors, but I'm pretty sure that bit of carpet that stretches from the seat back to the luggage area is just tucked into a metal slot that sits between the fender wells (about where you wrote the words "sewn in?" in your photo). You should be to able to pull it out by giving it a good tug. Once the carpet is out of the way, it's pretty obvious how to remove the seat back. I only had to remove one bolt on mine (I don't remember if it's the one on the driver or the passenger side), the other bolt is just there as a pivot point. The seat frame should slide right off it once you take out the other bolt, assuming yours is like mine.
Good luck, man! I'm digging the whole rally car thing. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
