CarlosZ Samba Member
Joined: April 23, 2016 Posts: 319 Location: Los Angeles
Posted: Sun Oct 23, 2016 9:28 am Post subject: Rebuild advice |
Bought a 72 westy earlier this year and already messed up the engine. Assuming a valve seat is the culprit at this point. It has a 2.0 GD engine with a progressive weber. I'd like to keep the existing block intact, buy dual webers and rebuild everything else but not sure on its condition. I've never been in another running bus so not sure what a good or poor running bus feels like. I'm also limited on tools and time. I'm on a budget, but am willing to spend what it takes to do it right. Anyone know if the AMC has improved their heads? Thanks
SGKent Samba Member
Posted: Sun Oct 23, 2016 9:38 am Post subject: Re: Rebuild advice |
I am hoping that you took the tin off and that it did not come out of the engine with no tin on it. You indicate you are both on a budget and also will spend what it takes to make it work. You also indicate you are limited in tools so that may be another expense, I don't know. Depending what is wrong that build can cost from $3000 to $6500 if you make no mistakes. You'll have 150 hours in it when you are done if you do it right unless the stars align and then it might be 30 hours. That doesn't include tuning. It will include learning and finding no longer available parts. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Oct 23, 2016 11:31 am Post subject: Re: Rebuild advice |
Tell us more about what happened to your engine. Did it just randomly start to make a lot of noise? Did it lock up and skid the tires going down the road? Did it just not crank over one day?
Your repairs and of course your cost depend on what is actually wrong with your engine. |
Posted: Sun Oct 23, 2016 5:33 pm Post subject: Re: Rebuild advice |
Started tapping real loud getting off the freeway and had it towed home. Removed the heads and #1 isn't looking so good. Shrapnel on the piston and head. Is that what's left of the valve seat? I removed the tin. No heater boxes or thermostat.
Posted: Sun Oct 23, 2016 5:49 pm Post subject: Re: Rebuild advice |
Looks like a serious valve recession issue on both heads. They may well not be worth rebuilding. If you are close to an experienced Type 4 head rebuilder you could take them in and let them have a peek but you might be better off to spend the money and go for new heads. I have heard the hardware on the AMC heads is better these days and don't need upgrading right out of the box, maybe others will comment. |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Sun Oct 23, 2016 7:31 pm Post subject: Re: Rebuild advice |
I will be watching this thread. I foresee this in my near future, and I'm trying to decide if I take my engine apart and rebuild before or after it blows up like this. >.< _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Mon Oct 24, 2016 9:27 am Post subject: Re: Rebuild advice |
Wildthings wrote: |
My understanding is the AMC heads out of the box are not any different than a few years back. I'd highly recommend upgrading the internals of new AMC heads. Spend a bit now....or spend a lot later. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
SGKent Samba Member
Posted: Mon Oct 24, 2016 9:32 am Post subject: Re: Rebuild advice |
Len Hoffman at Hoffman Automotive Machine in GA. About $1500 for a set of heads. He does heads for the camper special - awesome work. That and new pistons and cylinders is the only way to go. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
kooper271 Samba Member
Posted: Mon Oct 24, 2016 9:58 am Post subject: Re: Rebuild advice |
Wildthings wrote: |
This is true, the newer AMC heads to have better hardware now. |
Posted: Mon Oct 24, 2016 10:02 am Post subject: Re: Rebuild advice |
kooper271 wrote: |
Wildthings wrote: |
Not from what I've seen and continue to hear. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
Posted: Mon Oct 24, 2016 10:12 am Post subject: Re: Rebuild advice |
udidwht wrote: |
kooper271 wrote: |
Wildthings wrote: |
Not from what I've seen and continue to hear. |
I've seen and heard that they do. |
SGKent Samba Member
Posted: Mon Oct 24, 2016 10:19 am Post subject: Re: Rebuild advice |
From what I understand, AMC provides the castings. I've been told that Whatever wholesaler sells the actual heads installs the springs, keepers, and valves. I know that Len buys AMC castings by the pallet. His heads are very well priced for the quality. His economically priced heads are the best bang for the buck. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Oct 24, 2016 10:52 am Post subject: Re: Rebuild advice |
SGKent wrote: |
From what I understand, AMC provides the castings. I've been told that Whatever wholesaler sells the actual heads installs the springs, keepers, and valves. I know that Len buys AMC castings by the pallet. His heads are very well priced for the quality. His economically priced heads are the best bang for the buck. |
As I figured....Buyer beware. IOW...Purchase from Len or Adrian and install new upgraded hardware. Avoid anyone else. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Mon Oct 24, 2016 11:12 am Post subject: Re: Rebuild advice |
SGKent wrote: |
From what I understand, AMC provides the castings. I've been told that Whatever wholesaler sells the actual heads installs the springs, keepers, and valves. |
This is not true. When I bought mine, from Gowestyautoparts (RIP), they were sealed and packaged in AMC boxes with everything ready to go, all I had to do was install the step studs for the rockers and exhaust.
I had called Len and he told me a number of years ago he gets them the same way and removes the components to make them HAM sold heads.
I have 4 years and 6k+ miles on my off the shelf AMC heads, certainly not the same mileage to test the QC of the components, but have had no issues thus far. _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
SGKent Samba Member
Posted: Mon Oct 24, 2016 1:36 pm Post subject: Re: Rebuild advice |
aerosurfer wrote: |
SGKent wrote: |
I have 4 years and 6k+ miles on my off the shelf AMC heads, certainly not the same mileage to test the QC of the components, but have had no issues thus far. |
Actually I spoke with Len about 60 days ago and he told me he gets only the castings. He replaces the guides and seats with better ones, cleans up the flashing and ports a little then adds valves and springs. In my case I had some nos Porsche springs and keepers that he chose from. I also had him do a couple extra things for me that are good for 400 - 500 RPM on a mostly stock engine. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Randy in Maine Samba Member
Posted: Mon Oct 24, 2016 1:48 pm Post subject: Re: Rebuild advice |
Keep in mind that a type 4 engine makes all of its power from the heads and the camshaft, so invest your money there.
Tell Len that you intend to use dual carbs and he will set you up with larger intakes.
Buy the lifters from the camshaft guys as they need to be the same hardness.. |
ac78 Samba Member
Joined: March 18, 2008 Posts: 330 Location: Nashville
Posted: Mon Oct 24, 2016 3:11 pm Post subject: Re: Rebuild advice |
I have a stock FI setup and have about 5,000 miles on the "out of the box" AMC heads that were paired with new Mahle kits since July 22nd. I have experienced great power and great gas mileage.
If you dont want to wait for the next run and are interested in going stock hydr FI, I would let my HAM pair go for what I paid plus shipping. They are still in the bubble wrap. Otherwise I'm saving them for my future rainy day. _________________ 78 Westy 2.0l hydr. FI
VW Campmobile
For people who believe a family's
car should be it's castle ! |
Posted: Mon Oct 24, 2016 4:03 pm Post subject: Re: Rebuild advice |
SGKent wrote: |
Actually I spoke with Len about 60 days ago and he told me he gets only the castings. |
This doesn't answer the question of whether or not the hardware AMC supplies has improved or not. |
busdaddy Samba Member
Posted: Mon Oct 24, 2016 4:27 pm Post subject: Re: Rebuild advice |
I'm still trying to figure out just what the hell that thing swallowed It almost looks like a section of valve seat. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Oct 24, 2016 4:30 pm Post subject: Re: Rebuild advice |
busdaddy wrote: |
I'm still trying to figure out just what the hell that thing swallowed It almost looks like a section of valve seat. |
That was my guess as well. |
