Envious Samba Member
Joined: January 08, 2003 Posts: 1821 Location: Toronto, Ontario, Canada
Posted: Fri Oct 28, 2016 7:09 pm Post subject: Source for filtered velocity stacks for Dellorto DRLA's |
I've found them from multiple vendors for IDA's but not for DRLA's. Anybody know where I can get them?
http://www.piersideparts.net/CB6372.html _________________ 71 Type 1302 Custom
64 Type 151
63 Type 117 L469 Anthracite
64 Type 361 L575 Nutria
64 Porsche 356c
56 Type 113 L227 Strato Silver
52 BSA C11G
59 Heilite Single Wheel Camping Trailer
56 Allstate Single Wheel
84 Vanagon Westfalia
http://www.thesamba.com/vw/forum/viewtopic.php?t=388225 |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Fri Oct 28, 2016 7:15 pm Post subject: Re: Source for filtered velocity stacks for Dellorto DRLA's |
Make your own single stack filters, it will be more work than the IDA because you also have to make a filter or screen to go over the middle of the carb, or not. If you want it to work right for any length of time, you should.
how much would you pay? is looking cool a requirement? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Fri Oct 28, 2016 7:21 pm Post subject: Re: Source for filtered velocity stacks for Dellorto DRLA's |
I've always heard they kill "standoff".
_________________ Glenn
Member #1009
#BlueSquare |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Fri Oct 28, 2016 7:30 pm Post subject: Re: Source for filtered velocity stacks for Dellorto DRLA's |
If you crunch the numbers, and see how much open space is left after adding the screen, you might change your mind. The screen causes more of a restriction than you would think, and may actually offset whatever flow improvements the velocity stacks make to begin with. Of course, you could form the screen into a dome; more surface area, more open space..
I remember reading on an alfa forum where some English guys were messing around with them. They found that the cheap eBay screen stacks for weber DCOE flowed worse than no stacks and old dirty filters. But they do look cool _________________ modok wrote:
modok Samba Member
Posted: Fri Oct 28, 2016 8:22 pm Post subject: Re: Source for filtered velocity stacks for Dellorto DRLA's |
If you want something like the picture, just use a screen. There's no point in foam because as they get soaked with gas, that will just wash the dirt through anyway. Stainless screens. |
vince1 Samba Member
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
