T2 Samba Member
Joined: February 15, 2003 Posts: 187 Location: Yachats, Oregon
Posted: Thu Mar 19, 2020 1:38 pm Post subject: Odd remote full flow oil filter - can anyone identify it? |
I have this odd remote full flow oil filter set up. The guy who had this claimed it was from a Porsche 356. I got it when I bought several 36hp engines from him years ago.
Can anyone shed some light on what this is?
VeeDee Samba Member
Joined: February 02, 2020 Posts: 212 Location: Wolfsburg, Germany
Posted: Thu Mar 19, 2020 4:48 pm Post subject: Re: Odd remote full flow oil filter - can anyone identify it? |
Should be an Oettinger part. It was mounted to the rear bolts of the generator stand. The connector is to be screwed in the location of the oil pressure switch via a special hollow screw. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
alanhall Samba Member
Joined: February 18, 2006 Posts: 115 Location: Northern California
Posted: Thu Mar 19, 2020 7:01 pm Post subject: Re: Odd remote full flow oil filter - can anyone identify it? |
A by-pass filter, not full flow. |
T2 Samba Member
Posted: Thu Mar 19, 2020 8:23 pm Post subject: Re: Odd remote full flow oil filter - can anyone identify it? |
Thanks Everett for those links. |
Peter_Plade Samba Member
Joined: January 09, 2005 Posts: 551 Location: Denmark
Posted: Fri Mar 20, 2020 10:19 am Post subject: Re: Odd remote full flow oil filter - can anyone identify it? |
Is possible to buy filters for this setup?
I’ve been considering it for my 66 bug. _________________ http://vw-bluehats.blogspot.com/ |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri Mar 20, 2020 10:21 am Post subject: Re: Odd remote full flow oil filter - can anyone identify it? |
spin on filters are pretty generic so yes, not hard to find. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Joined: June 24, 2015 Posts: 719 Location: Rialto. CA
Posted: Fri Mar 20, 2020 11:55 am Post subject: Re: Odd remote full flow oil filter - can anyone identify it? |
Does anyone know where I can get that oil sender adapter for this kit . |
Tvättbjörn Samba Member
Posted: Sun Apr 05, 2020 10:17 pm Post subject: Re: Odd remote full flow oil filter - can anyone identify it? |
[email protected] wrote: |
It looks complete in the picture. Only the filter and oil pressure switch is missing which will be installed in the female threaded part on the fitting.. |
TomSimon Samba Member
Posted: Tue Apr 07, 2020 11:13 am Post subject: Re: Odd remote full flow oil filter - can anyone identify it? |
I just sold an NOS kit a few months ago... The kit is well made, well thought out. As has already been noted, isn't a full-flow filtering system, but it is full time... that is, some of the engine's oil is being filtered and returmed at all times. sure does dress up a vintage 40hp or later engine, it might also work on 356 porsche (mounting this style requires a bolt on generator stand).
They were very clever, no machining needed, it's comprised of a bunch of custom machined fittings, hollow banjo bolts and banjo fitting, a small casting.
The oil exits the case at the oil light sender location, thru a hollow banjo bolt and fitting, which by the way, re-accepts the factory oil pressure light sender. Oil runs thru the filter housing which I believe has it's own built in bypass, for cold oil at start up. Filtered oil is then returned to the case by way of a long hollow bolt that replaces one of the factory generator stand studs. The banjo bolt and fittings seal by way of copper crush washers, still commonly used on American brake systems (like the front of my Ford E350). _________________ 2-time NASA Pro Racing Champion, Bonneville 130 Club and 150 Club Memeber, BRS Pro Gas racer |
Braukuche Samba Member
Posted: Wed Apr 08, 2020 8:02 am Post subject: Re: Odd remote full flow oil filter - can anyone identify it? |
They are pretty ineffective, they only filter like 4% of the oil, just like the old Porsche ones.
I have a couple of the,m floating around the garage, they would look kind of cool on a vintage 40hp set up. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Sun Apr 26, 2020 8:03 pm Post subject: Re: Odd remote full flow oil filter - can anyone identify it? |
I dug around and found two of these kits, but both are missing the adapter piece that screws into the oil pressure switch hole.
I went ahead and screwed the through bolt that passes directly through the banjo fitting and it screws and tightens in the oil pressure switch hole, so not sure what the purpose of the adapter is? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Sun Apr 26, 2020 9:04 pm Post subject: Re: Odd remote full flow oil filter - can anyone identify it? |
I was/am looking for that adapter so I can use it for my fullflow oil canister if I can ... just like the denzel fullflow oil sender adapter looks similar in a way ..unless someone has a denzel one i want it lol ...but I was looking to use that adapter to see if it will work or not .... |
