beetleseb Samba Member
Joined: November 09, 2006 Posts: 430 Location: Cheltenham UK
Posted: Sun Oct 30, 2016 6:06 am Post subject: early Porsche brake rings and stopping the bug |
Just ordered a set of these beauties after seeing them in the flesh
http://www.thesamba.com/vw/classifieds/detail.php?id=1979402
Getting them on brand new 57-64 drums (supplied) but wondered what else I can do to help the car stop well. Am looking at stock 57-64 drums and internals all round at the moment. Don't want to go servo or late, want to keep it period. Car is a 1950 beetle _________________ Wanted - OG 50 split bug door panels, brown mats and old running boards |
sled Samba Member
Posted: Sun Oct 30, 2016 9:00 am Post subject: Re: early Porsche brake rings and stopping the bug |
those rings will do nothing to help the car stop (they're just very expensive). Those cooling rings might help if you were actually racing your car at high speeds. Even going down a long mountain pass, your 57-64 brakes are just fine for a 50 beetle.
to make the car stop as well as possible, make sure you have the shoes arc'd to the drums accurately, and make sure there is zero air in the brake system. Other than that, discs would be the next upgrade. _________________ drive your split. |
Posted: Sun Oct 30, 2016 9:14 am Post subject: Re: early Porsche brake rings and stopping the bug |
I should have mentioned the engine is being modified with 72mm crank etc and the car will be used in friendly road rally's. I've had issues with heat and brake fade before so am still going for these.
I thought the price was quite reasonable considering the cost of new drums is included and it's a pair. I was very impressed with the quality and being cast on is a massive improvement over the other ones you can buy. If nothing else they look the dogs through my custom drilled wheels
Didn't know if anyone had ever used bigger slaves etc or if racing shoes were available. _________________ Wanted - OG 50 split bug door panels, brown mats and old running boards |
sled Samba Member
Posted: Sun Oct 30, 2016 1:51 pm Post subject: Re: early Porsche brake rings and stopping the bug |
I did not see that they included drums, that helps a bit.
if you're really looking to improve your splits braking, you should get some 356/356A aluminum drums with track compound shoes.
you may be able to find a brake shop that will re-line your shoes with a more aggressive compound. _________________ drive your split. |
