akomjathy Samba Member
Posted: Wed Nov 02, 2016 11:28 am Post subject: 36 HP engine case with a 40 HP big bore 83 mm p/c kit |
I need a little bit of help. I want to build a 36 HP engine case with a big bore 83 mm p/c set. I know that I have to modifie the engine case, because the 36 HP cylinder bore is 81 mm, but the 40 HP big bore 83 mm cylinder is 87 mm on the case side. Does anyone know, if there is enough place beside the original studs? I don't want to modifie them. Thanks for your help!!
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Fri Nov 04, 2016 3:09 pm Post subject: Re: 36 HP engine case with a 40 HP big bore 83 mm p/c kit |
I have checked the possibility to do that with a Mahle big bore set I have. You have to modify the cylinder walls where the sylinder studs are, because of thighter spacing. And cut down the finns at the top, because the 40hp cylinders are wider.
It has been done by others. _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
Posted: Fri Nov 04, 2016 3:12 pm Post subject: Re: 36 HP engine case with a 40 HP big bore 83 mm p/c kit |
Kjell Roar wrote: |
I have checked the possibility to do that with a set of Mahle big bore set I have. You have to modify the cylinder walls where the sylinder studs are, because of thighter spacing. And cut down the finns at the top, because the 40hp cylinders are wider.
It has been done by others. |
That's what I thought. And do you know anything about the cylinder head side? I am going to use the Wolfsburg West Okrasa heads. Do I have to modifie the cylinder wall, too? Thanks: Attila |
pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Posted: Fri Nov 04, 2016 5:31 pm Post subject: Re: 36 HP engine case with a 40 HP big bore 83 mm p/c kit |
without question you are going to have to machine everything.
there are a couple of threads re WW okrasa heads, and the extra size actually benefitting the seal between head and cylinder...
machine heads.
machine fins.
machine case.
_________________ 1954 L227 Type 113
1964 L31 Type 265 |
Posted: Sat Nov 05, 2016 12:29 am Post subject: Re: 36 HP engine case with a 40 HP big bore 83 mm p/c kit |
It is at least one thread showing what to cut down, here on thesamba. Search and find 🙂 _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
AirCooledClassics Samba Member
Joined: August 20, 2004 Posts: 294 Location: Saskatoon, Sk Canada
Posted: Sat Nov 05, 2016 10:26 pm Post subject: Re: 36 HP engine case with a 40 HP big bore 83 mm p/c kit |
Mathews pics were very helpful to me. I.ve done this mod several times. It is very time consuming . The heads and case need to be opened up. On the case you cannot use a flycutter.It must be milled, Or get a flycutter made in about 1967. I install case savers and used 8mm studs to make the cutting easier. many other just use an angle grinder to clearance the barrels for the stud. If you have access to a mill check Blacklines build on their 36 hp challenge its much nicer than the way I do it. I hear that AA is finaly doing the 80mm big bore kit. With no machining that's the way I would recommend .It has an easy button. _________________ 2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552 |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sun Nov 06, 2016 6:22 pm Post subject: Re: 36 HP engine case with a 40 HP big bore 83 mm p/c kit |
How about offsetting case savers in the case and using 8mm studs? that would give you a bit more room.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 727 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Sun Oct 01, 2017 11:26 pm Post subject: Re: 36 HP engine case with a 40 HP big bore 83 mm p/c kit |
It would be easier to use 912 cylinders, bore 'em 1mm and install 40hp pistons. You would trim the bottoms and tops & remove 1 fin.
You would not need to trim as much fins to fit under sheet metal. Worked for me.
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
