nobrakes Samba Member
Posted: Tue Mar 23, 2004 7:57 am Post subject: Hinge screws |
Anyone know where I can find a screwdriver bit to fit the hinge screws ? I bought a 3/8 butterfly impact wrench but can't find a bit anywhere. _________________ If your not workin or cleanin your not looking hard enough. |
7thing3 Samba Member
Joined: April 05, 2003 Posts: 473 Location: Cleveland, OH
Posted: Tue Mar 23, 2004 10:00 am Post subject: |
I went to a Sears Hardware store and bought the biggest bit they had (I can't remember the size) that fit into a standard 3/8 socket wrench. Still would not budge. I finally used an extractor bit--it came out but of course it chewed it all up. I was putting a mirror hinge on before I had it painted so I didn't care if the screw got damaged, I just used another and it was painted over.
Bob Vila _________________ '73 Thing--Ted
'77 Super Beetle Convertible
'87 Vanagon GL Syncro
'84 Mercedes 280 CE |
edgy Samba Member
Joined: January 22, 2003 Posts: 424 Location: Bel Air, Maryland
Posted: Tue Mar 23, 2004 4:21 pm Post subject: |
I have a 1/2 drive impact wrench that you hit with a hammer. I use a #4 phillips bit. THey have always come and and do not strip out. |
nthang Sambassador
Joined: February 05, 2003 Posts: 158 Location: Up Stream
Posted: Wed Mar 24, 2004 5:16 am Post subject: |
I like Sears, too, for tools. Those are the same screws as on the hood and deck lid hinges, I think. Of course use a penetrant. Try using some propane heat on the hinge and tapping it (an educated whack) before removal. I used a bigassed philips screwdriver with a pair of kingsized vise-grips, leaning into it. No problems.
Mike Basso at Things Unlimited with send you all the stock screws that you need for nothing: http://www.thingsunlimited.net/ . _________________ NTHANG, LLC |
Posted: Wed Mar 24, 2004 5:29 am Post subject: |
I checked Sears again and they have a 3/8 drive #4 bit, funny last month I looked at every page on their website with no luck.
Thanks guys. _________________ If your not workin or cleanin your not looking hard enough. |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Wed Mar 24, 2004 8:12 am Post subject: |
I use a big honkin' Husky #4 phillips screwdriver- it's got a hex on the shaft just below the handle, so I slide a box end wrench on it, and as nthang said, lean into it, and slowwwly twist... after liberally spraying with PB Blaster for a day beforehand. I don't like impact drivers for this stuff- the metal of the screws is too soft, and dollars to donuts, you'll bugger 'em up, or worse, walk your impact driver across the bodywork. _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
edgy Samba Member
Posted: Wed Mar 24, 2004 7:12 pm Post subject: |
Good point, while I have an impact driver, I don't actually hit it when loosening the screws in the hinges! |
Posted: Mon Mar 29, 2004 4:49 am Post subject: |
Well the 3/8 butterfly impact and Sears #4 bit worked fantastic, the screws came right out and the screws themselves don't have a mark on them. This is the best way to remove the screws IMHO. _________________ If your not workin or cleanin your not looking hard enough. |
Chris181Westy Samba Member
Joined: August 05, 2003 Posts: 148 Location: Michigan, The Third Coast!
Posted: Mon Mar 29, 2004 10:35 pm Post subject: |
I need to do this as well. I have not done so out of fear of stripping the screws. But a #4bit you say, I need to go get one! The studs on my door hinges are wore out. My doors don't close worth a crap. I have replacements to install just need to sack up and do it. _________________ "So we went for a spin in the country
To feel the wind in our hair
To feel the power of my engine
To feel the thrill of desire"
Roger Waters, The Pros and Cons of Hitchhiking |
Posted: Tue Mar 30, 2004 6:42 am Post subject: |
Maybe you want to tape some thick cardboard or something around the hinge just in case you slip. _________________ '73 Thing--Ted
Posted: Tue Mar 30, 2004 11:01 am Post subject: |
The cardboard would be good insurance but the 3/8 butterfly is very easy to control, I didn't notice any tendency to jump out of the screw but if I had nice paint I might protect it just in case. _________________ If your not workin or cleanin your not looking hard enough. |
