Warm air to air filter
Page: Previous  1, 2
BJT
BJT is offline
PostPosted: Tue Aug 13, 2019 11:48 am    Post subject: Re: Warm air to air filter Reply with quote
Al Capulco wrote:
The vacuum ports on the carburetor are all different for different reasons, none are for that air cleaner flap. Use the one on the intake manifold and just reduce it or get the right manifold.
That’s kind of what I thought, but someone else suggested using the carb vacuum port..
germanbilly
germanbilly is offline
PostPosted: Tue Aug 13, 2019 1:31 pm    Post subject: Re: Warm air to air filter Reply with quote
Just think about this for a minute, The vacuum port at the bottom of the carb just below the throttle butterfly is the same as having it at the big vacuum on the manifold. That port is pulling no vacuum until the throttle is opened. The ports above the throttle butterfly are for vacuum advance and other duties.
GB
BJT
BJT is offline
PostPosted: Wed Aug 14, 2019 6:35 am    Post subject: Re: Warm air to air filter Reply with quote
Got it sorted out. The lower vacuum port on the carb
Does not provide a vacuum, even when I left it open, the idle didn’t change and no registered vacuum with a tester. However, the upper, driver’s side vacuum works perfectly for the warm air intake. Hooked the hose up to that, and the flap opened up to allow the warm air to enter the engine. After a short warm-up and drive around the neighborhood the flap was closed, this sucking in only the “cold” air. In any case, glad I got another thing working on the Thing. Next up, front brakes....
Page: Previous  1, 2
Page 2 of 2
