FullFender Samba Member
Posted: Fri Apr 20, 2018 6:23 pm Post subject: Re: 71 Project |
Finished up the lower mount today. I think I'm going to round the end of the stud but overall I'm happy with it. With this mount the bottom of the decklid sits flush with the apron
Without the decklid-
Secured with a quick pin, with decklid-
Bought a new Spectre filter today, the colour is going to take some getting used too but I'm happy with it
Posted: Sat Apr 21, 2018 9:23 pm Post subject: Re: 71 Project |
These are the upper mounts, they bolt right above where the original hinges go. Still need to paint them then drill for the quick pins and it should be done.
Posted: Fri Apr 27, 2018 8:11 pm Post subject: Re: 71 Project |
Painted a drilled the mounts for the upper quick pins
Here is how they mounted up
This is painted with pins I only have a picture of the driver side but both sides are identical
Got a call from Innovate and since AutoMeter just bought out Innovate the corporate offices are in a chaotic switchover with the mechanics trying to learn the all new tech. A lot of systems are on back order so if I don't get it back by Monday they'll send me a new kit altogether. |
Posted: Sun May 06, 2018 5:58 pm Post subject: Re: 71 Project |
Innovate sent me a whole new kit, which works good. I'm really happy with how they handled the situation in light of being in the middle of a buyout. I took its for a run today in beautiful 70* weather. It ran pretty dang good but the carb still needs some fine tuning (FI is lookin real great right about now lol). The temp stayed solid at 200F. It starts to warm up in stop and go traffic, which I think is pretty normal but it cools off after the traffic clears up.
I've got a GoPro vid from the rear window that I'll try and get posted in the next few days she's a head turner for sure
Posted: Fri May 11, 2018 3:11 pm Post subject: Re: 71 Project |
New innovate censor kaput again, I know I know why should I expect anything different? :fist: |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Fri May 11, 2018 4:07 pm Post subject: Re: 71 Project |
Get a PLX with Multigauge..... _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Fri May 11, 2018 6:38 pm Post subject: Re: 71 Project |
clonebug wrote: |
Get a PLX with Multigauge..... |
Yep..I'm on it! What exactly is a Multigauge? |
Posted: Fri May 11, 2018 9:49 pm Post subject: Re: 71 Project |
FullFender wrote: |
clonebug wrote: |
Here you go...it's even on sale.
http://www.plxdevices.com/Wideband-O2-Touch-Screen-Multi-Guage-p/897346002719.htm
The Multigauge is the display gauge that fits in any 2 1/16 inch standard gauge hole. It will daisy chain up to 32 different controllers if you wan to add them.
The AFR controller and gauge will display AFR and Voltage so you could pull your voltmater gauge and install this one. You cycle through the display choices by pushing a hidden button on the display.
I currently have the AFR and EGT gauges daisy chained to the multigauge display.
Here you can see the AFR and EGT controllers stacked on top of each other.
Mine has held up to daily use for over 3 years now with the same O2 sensor.
You also never need to calibrate it. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Posted: Sat May 12, 2018 7:16 pm Post subject: Re: 71 Project |
clonebug wrote: |
FullFender wrote: |
clonebug wrote: |
You also never need to calibrate it. |
Now since you're up near Oregon I'm guessing you still get moisture that spits out the exhaust? I'm wondering if the moisture has anything to do with the errors even with the bug at 7o'clock on the exhaust. If the kit comes with a bung I might weld it in the bottom of the pipe to act as a drain plug. The clutch cable broke the other day (thankfully in my garage and not when I was driving). So I'm going to be off the road for only a week or so..hopefully |
Posted: Sat May 12, 2018 8:06 pm Post subject: Re: 71 Project |
The O2 sensor needs to be up at the 10:00 or 2:00 o'clock position to stay out of the condensation. The 7 o'clock position allows moisture to get into the sensor which will kill it quickly.
I get lots of condensation when I start my Buggy and I still have not had any issue with my PLX AFR sensor in over 3 years. My sensor bung is at the 10:00 o'clock position.
It's been in that position since 2011.
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Posted: Sat May 19, 2018 12:06 pm Post subject: Re: 71 Project |
Grab your popcorn, disaster may have struck people. But before I poop on my own party. I got the PLX yesterday and installed just fine, happy with the whole setup. Now, the real fun that is VW's. Remember back when I said the clutch cable broke? Pulled that out and it looks fine as wine. Yet when it broke the pedal when to the floor and was just flopping around. Something with the throwout bearing must've broke, the arm the cable attaches to moves freely.
I'd like to hear your input but I'm thinking the motor is going to have to come out........again. I guess the good news is I don't have to clean and paint it this time
Go turbo they said, it'd be fun they said. |
Posted: Sat May 19, 2018 4:13 pm Post subject: Re: 71 Project |
It is fun.....but no one said it would be a cake walk......
It takes some time to get it all worked out but once it's running good you will never go without a turbo again. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Posted: Sat May 19, 2018 5:51 pm Post subject: Re: 71 Project |
clonebug wrote: |
It takes some time to get it all worked out but once it's running good you will never go without a turbo again. |
It's all good, I'm going to enjoy every minute of driving it. I can guarantee that!
Here lies the culprit, I guess it was time for it to go.
I'm looking at some heavy duty arms, like $40. |
Posted: Fri May 25, 2018 7:25 pm Post subject: Re: 71 Project |
Finished installing the throwout bearing shaft. The arms on this one wrap all the way around and are welded on one side
Old
New
Installed
Posted: Sat May 26, 2018 9:06 pm Post subject: Re: 71 Project |
Got the engine back in
I also worked on cleaning up the lower gauge cluster
Will go for a test run tomorrow and report back |
Posted: Sun May 27, 2018 5:04 pm Post subject: Re: 71 Project |
I got a lot done (for me anyway) today that I'm pretty happy about. 99% done with the interior.
It ran OK but the carb needs work. I think I'm going to 1 1/4 turns out on the idle mix. At a stop light today it loaded up and shut off right as it turned green people were generous and no one ran me over. I'd also like to get a larger power valve...it's goes a little lean up at higher rpm. I know a carb guy and he said at 10lb vacuum I should get like an 8.5 which should improve the AFR. Right now it's got a 4.5 |
Posted: Sat Jun 16, 2018 3:34 pm Post subject: Re: 71 Project with Turbo 1915cc Build |
A little more adjusting on the carb, the new power valve has made the AFR's way more happy and it doesn't go lean any more unless I shift too early. I've dropped a few jet sizes and I still think I need to go down because it likes to load up in traffic. Very driveable though. I also changed out my old oil feed line to a new copper one, I was a little worried about it being close to the turbo
I maybe got a few new stickers too
Drove it a couple miles to a Horsepower cruise-in and brought home a knarly sunburn and a "Top 10 Trophy"
I only knocked the exhaust of once on the way easy fix and it is part of the adventure. All in good fun
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun Jun 17, 2018 2:50 am Post subject: Re: 71 Project with Turbo 1915cc Build |
Good job on the trophy Heating the intake on mine sure helped the Loading up ( RLR intake) but he's sure proud of them , Mine use to load up when I'd pull up to a traffic lite or cruising sometimes ,, not anymore Before & after
_________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sun Jun 17, 2018 6:22 am Post subject: Re: 71 Project with Turbo 1915cc Build |
I'm a little surprised going to a higher number on the power valve helped at all on the upper rpms. That doesn't make it a larger power valve, just changes when it opens. That number is how many inches of vacuum it opens up at. An 8.5 opens at 8.5" of vac, a 4.5 opens at 4.5" of vac and so on. It doesn't change the amount of fuel. If you actually need more fuel in upper rpms you will have to drill out the orifices where the power valve is. Pretty common on turbos.
I love my PLX but that's one of the things that is tough having the multi gauge. For turning you kind of need to see more than one thing at a time. Ideally I'd you could see boost, afr, and vacuum at the same time, it would be easier to tune. Especially the power valve. If you could see right where it goes lean you would know where you were on the vacuum and adjust accordingly.
Almost sounds like you need a larger main jet to me. Going too high on the power valve might get you into the power valve at medium throttle cruise.
For mine I make 20" of vac at idle so I went with a 10.5 power valve. Didn't work well because it doesn't take much to get down to 10.5" of vacuum, so it would richen it up too early.
It's a crazy balancing act between the accelerator pump, main jets, and power valve. |
Posted: Sun Jun 17, 2018 11:22 am Post subject: Re: 71 Project with Turbo 1915cc Build |
madmike wrote: |
So to heat it up you changed to a thicker walled cast manifold? I didn't notice a good amount of condensation on my intake (LowBugget non-cast) though it was still early (7:00am) and cold out.
buguy wrote: |
Yeah my PLX is performing pretty good, I'm happy with it. Yeah tuning it sure is fun |
