rapping at idle smoking under load
iamdonquixote
iamdonquixote is offline
PostPosted: Thu Nov 10, 2016 6:40 pm    Post subject: rapping at idle smoking under load Reply with quote
The bug from hell strikes again, just about everything that can go wrong has. After replacing the clutch and exhaust I've been daily driving it for the last week.
It started to sound louder I thought a day or so ago, it always kinda rapped a little while cold but this seemed worse.
Anyhow, tonight driving home after pulling out from a stop light I saw smoke. Then driving in stop and go traffic it was really coming out under load. It was bluish and I could smell the oil.
Time to pull the engine and check the rings and valve guided? Is the rapping related? The PO had the engine 'rebuilt' however PO had no clue and made it the bug from hell.
vwfreek61
vwfreek61 is offline
PostPosted: Thu Nov 10, 2016 7:12 pm    Post subject: Re: rapping at idle smoking under load Reply with quote
Can you describe the rapping? If it's gangsta, the smoking is probably related.
Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/2.0 ABA
iamdonquixote
PostPosted: Thu Nov 10, 2016 7:34 pm    Post subject: Re: rapping at idle smoking under load Reply with quote
pick it, pack it, fire it up
73sports
73sports is offline
PostPosted: Thu Nov 10, 2016 8:24 pm    Post subject: Re: rapping at idle smoking under load Reply with quote
I had a sp1600 that smoked too much, but seemed to run well otherwise. At idle, blue cloud out the exhaust. I pulled the plugs, and found that #4 was wet/ oily. Pulled the head on that side, and saw a couple of score marks on the cylinder wall. Pulled the cylinder off and found that the wrist pin clip had come out of place and the pin was pushing it up against the cylinder wall. I replaced that cylinder, put it all back together, and am still using the engine. So, that being said, a quick check of the plugs may reveal where your problem lies.
I will never lie, but sometimes the truth changes.
Central Jersey VW Society
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Fri Nov 11, 2016 4:43 am    Post subject: Re: rapping at idle smoking under load Reply with quote
^^^X2 do this and report back.
There's never enough time to do it right the first time. But there's always enough time to do it twice.
iamdonquixote
PostPosted: Fri Nov 11, 2016 5:22 pm    Post subject: Re: rapping at idle smoking under load Reply with quote
so I took a closer look, and the oil isn't coming out of the exhaust, instead its pooling in the pulley tin and then spewing on to the exhaust.
I cannot tell where the oil leak is coming from, but I suspect blow by and/or oil pump is leaking.
