Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Posted: Sat Nov 12, 2016 4:17 pm Post subject: Gauges for a 6 volt system |
I'm installing gauges in my '66 Beetle. I found a Voltage gauge with a range of 6 to 16 V, for $22.50 at PILOTSHOP.COM. The 120 A gauge will be replaced with the voltage gauge seen below.
I tested the tach at 6 V, which worked with the display a little dimmer.
The Amp meter and CHT gauges do not require power except for illumination. 6 V bulbs are available, it's easy to make LED replacements.
I have a three gauge panel for oil pressure, oil temp and 12 V battery. All the gauges will be wired with connectors, so I can remove them if I want go to a show with the stock look.
I'm designing a 6 to 12 V DC TO DC converter with a 6 A output. The converter will be connected to a 12 V gel cell to power any additional items requiring 12 V.
_________________ Additional products https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231 |
Bug-nut Samba Member
Joined: December 20, 2015 Posts: 488 Location: Knoxville, TN
Posted: Sun Nov 13, 2016 9:19 am Post subject: Re: Gauges for a 6 volt system |
What tach are you using? I'd love to find a 6 volt tach or a 12v one that would work that doesn't cost both my arms and a leg _________________ 1959 Fjord Blue Volkswagen Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1962 Austin-Healey Sprite
Snort wrote: |
A 59 Beetle is just an Oval-Window car with aspirations of modernity. |
Posted: Tue Nov 15, 2016 8:35 pm Post subject: Re: Gauges for a 6 volt system |
This is my DC TO DC CONVERTER, 6V TO 12V @ 1A OUTPUT. It's designed stay on all the time to power a 12V CD Player memory or USB charger. The output has a relay to also provide a switched 12V output for gauge power, which is wired to the ignition switch. The input range is 5V to 8V. I measured the current of a digital tach at 0.6 A.
Last edited by Wayne S. Johnson on Wed Nov 16, 2016 10:00 am; edited 1 time in total |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Wed Nov 16, 2016 2:42 am Post subject: Re: Gauges for a 6 volt system |
Dear Wayne
For my '63 my choice was like yours but with those three analogic gauges:
Oil pressure
Oil temperature
Water temperature
http://www.ebay.it/itm/52-mm-Triple-kit-Oil-Temp-G...210fc629eb
http://i.ebayimg.com/00/s/NjQwWDY0MA==/z/V7kAAOSwQjZXPhOO/$_12.JPG
Then I used the water temperature connected to the oil temperature sensor, wich range is appropriated.
So I've put the Oil temperature bulb into the waste hot air from cylinder heads, so I have a measurement of air t° from heads, ~head temperature.
I read, under load, 130-140°C.
All gauges feeded with a simple dc-dc converter; LED illumination directly by 6V after stock dimmer.
For Voltage I preferred a digital unit (4$), more appropriate to a 6V because a 16V gauge like your has no efficiency in the 6Volt range.
Choose a voltage meter with separate input for feed and for measurement so you can feed it with the 12V DC (more stable) and check the voltage directly on the 6V battery. It gives precious informations on how dynamo regulator is working.
http://www.ebay.it/itm/Voltometro-Pannello-DC-0-10...FYs25WyC-g
Finally, put a simple LED with a resistor between +ign and the FIELD terminal of the generator, so you can check how generator is controlled.
I will post a photo of my arrangement. |
Posted: Wed Nov 23, 2016 1:36 am Post subject: Re: Gauges for a 6 volt system |
Dear Wayne,
No, I did not find a so cheap gauge, do you have a link to this? I'm interested, but I found only digital CHTs. |
Posted: Wed Nov 23, 2016 11:56 pm Post subject: Re: Gauges for a 6 volt system |
I was referring to the CHT you posted, not the voltmeter that I already have.
Thanks |
Posted: Thu Nov 24, 2016 12:16 am Post subject: Re: Gauges for a 6 volt system |
Many thanks! I will add it! |
Posted: Fri May 19, 2017 12:05 am Post subject: Re: Gauges for a 6 volt system |
Added my CHT gauge. Problem: readings are too low!
Tried it out from car with boiling water and all seems OK.
BUT when in the car I read very low temperatures.
Value starts from 20°C - 68°F and in 5 - 8 minutes raises up to 85°C - 185°F and almost stays there.
Temperature increases only when I'm stuck into traffic, or when engine is shutdown.
So my hypotesis: is my sensor too much exposed to fresh air and, instead of spark plug temperature, measures air temperature?
Thank you. |
Posted: Fri May 19, 2017 4:44 am Post subject: Re: Gauges for a 6 volt system |
Thank you, I'm confident about my thermocouple accuracy.
My doubt is that the great mass of fresh air blown in the spark plug zone affects the suspended part of the thermocouple.
The wire couple is soldered not directly on the circle but on a sort of its protrusion, so is exposed to fresh air.
The very fast measurement increase at the moment that rpm drops (~5°C degrees into 10 seconds) take me to consider that the real head temperature is only a far image of what I read on the gauge.
I don't think that a cylinder head really has a so speed temperature increase (thermal gradient?). Instead a little sensor does. |
EVfun Samba Member
Posted: Fri May 19, 2017 10:54 am Post subject: Re: Gauges for a 6 volt system |
When I saw that gauge at the top of this thread the first thing that came to mind was Westach. It turns out that isn't one of their gauges, but they do have a small number of 6 volt gauges they build. There is a 0-10 volt meter and a 0-5000 tach for 4 cylinder engines. _________________
Wildthings wrote: |
