67ctbug Samba Member
Hokie87 Samba Member
Joined: May 27, 2010 Posts: 280 Location: Richmond, VA
Posted: Mon Nov 14, 2016 4:48 pm Post subject: Re: What Axle Boots? |
The description on the WW site says they are also German. I used the WW without problems so far (1 year). |
Posted: Mon Nov 14, 2016 5:12 pm Post subject: Re: What Axle Boots? |
Allright so they are both German so they are most likely the same? _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Nov 14, 2016 5:47 pm Post subject: Re: What Axle Boots? |
I'd say equally important or more so is the installation technique: not overtightening, lining up the split correctly, taking up the stress before tightening the end clamp, etc. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Nov 14, 2016 5:53 pm Post subject: Re: What Axle Boots? |
The split is set up at 2-3 o'clock right? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Mon Nov 14, 2016 6:22 pm Post subject: Re: What Axle Boots? |
67ctbug wrote: |
The split is set up at 2-3 o'clock right? |
2-10 it really doesn't make a difference. Just not vertical horizontal or the split at the bottom. Of course someone will chime in and say 2 is the correct way and then another will say 10 is correct. They just need to flex without pulling the boot from the trans due to incorrect installation.
The comment regarding taking the stress off the boot is correct. Also when you tighten the clamps on the axles make sure to push the boot about a 1/2" toward the trans. That too will help relieve stress on the boots.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Mon Nov 14, 2016 6:33 pm Post subject: Re: What Axle Boots? |
Allright so, either is good, 2-10 (as long as it isn't too center or on the bottom center), and move it in a half inch toward the trans. Got it! _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Mon Nov 14, 2016 7:10 pm Post subject: Re: What Axle Boots? |
One last question... the WW made by WW floor seal or the CIP1 German one. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Tue Nov 15, 2016 1:35 am Post subject: Re: What Axle Boots? |
I'm not sure what options there are for split boots these days. What brands are you guys seeing for sale? I think I have like 3 of them in the basement, all FEBI. The Febis are "OK" but I've always thought they were bit soft/thin on their rubber. I remember one other brand, I think TeGuFa??, that were thicker/beefier overall, but I also remember they were more prone to dry-rot/cracking.
I put the stock style Brazil/Orion brand, non-split boots on my 62 a few years ago at the same time that I put in new side gears and fulcrum plates. Last year at some point I realized that I didn't set one of them up properly when I pinched the clamps, and that one was slightly twisted, and had worn a small hole near the top of the boot. I don't drive the car a lot and it really doesn't leak so I left it for the time being. I 've actually been thinking about trying a tire patch on the spot, rather than go back to a split boot. _________________ Andy T.
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Tue Nov 15, 2016 5:10 am Post subject: Re: What Axle Boots? |
67ctbug wrote: |
One last question... the WW made by WW floor seal or the CIP1 German one. |
I'd get the WW. You'll have to punch the holes in it. I made a punch out of an aluminum piece of scrap pipe but they sell the punch's for not much money. I bought a rubber steering coupler that was supposed to be German and paid the higher amount from cip. It wasn't. Unfortunately I didn't check or use it for 6 months after purchase. If you look at the ad it says "German equivalent". |
Posted: Tue Nov 15, 2016 5:14 am Post subject: Re: What Axle Boots? |
Both WW it is then. Thanks guys! _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Tue Nov 15, 2016 9:42 am Post subject: Re: What Axle Boots? |
Okay, still Febi then. WW is where I got the last set or two from a few years ago, and they were Febi. _________________ Andy T.
mukluk Samba Member
Posted: Tue Nov 15, 2016 10:15 am Post subject: Re: What Axle Boots? |
I've been running a set of the Febi boots from WW on my '60 for close to four years now, no leaks and they're holding up very well. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Tue Nov 15, 2016 11:32 am Post subject: Re: What Axle Boots? |
I've never heard of febi, are they good? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Tue Nov 15, 2016 12:13 pm Post subject: Re: What Axle Boots? |
"That's a Bingo" ! ... Good German stuff. |
Posted: Tue Nov 15, 2016 12:17 pm Post subject: Re: What Axle Boots? |
Oh good, I was hoping it wasn't some Brazilian garbage . WW it is. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Tue Nov 15, 2016 12:29 pm Post subject: Re: What Axle Boots? |
They are allied with Bilstein, the shock absorber company and they make some steering/suspension parts.
My main complaint is the damn pinch clamps they come with. On split boots I find it much easier to use screw clamps, so in the past I've always re-used them if that was what was on the car before rather than use the pinch style.
They haven't changed their rubber moulds in years - they still say Volkswagen on one side and Made in West Germany on the other.
Here's a photo I just took of what you get and detail of the sealing edges:
Posted: Tue Nov 15, 2016 12:40 pm Post subject: Re: What Axle Boots? |
Those look great! Mine has split ones that are torn, I'll see what clamps they have. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
