scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Thu Nov 17, 2016 6:37 am Post subject: Diagnose type 1 engine sound - marbles rolling around |
1641cc type one in a bus, about 10k miles on it since I rebuilt it last year.
I just noticed a sound like marbles rolling around, loudest on the left side by the #4 main bearing. It only shows up at low RPM- I was setting idle speed and found the noise around 600 RPM or so.
Any ideas? It sounds more and more like a "split the case" problem.
_________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
wcfvw69 Samba Purist
Posted: Thu Nov 17, 2016 7:07 am Post subject: Re: Diagnose type 1 engine sound - marbles rolling around |
Have you run it w/out the belt for the alternator? _________________ Contact me at [email protected]
The Samba member since 2004.
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Thu Nov 17, 2016 8:51 am Post subject: Re: Diagnose type 1 engine sound - marbles rolling around |
I've heard this on an engine with a busted guide for the fuel pump pushrod. It was jammed in sideways and making a racket, but still operated the pump. _________________ modok wrote:
jason Samba Member
Posted: Thu Nov 17, 2016 9:37 am Post subject: Re: Diagnose type 1 engine sound - marbles rolling around |
Check easy stuff first. Fuel pump rod as mentioned, maybe distributor drive spring busted and its jumping around. Check valves and for exhaust leak. |
Posted: Thu Nov 17, 2016 9:45 am Post subject: Re: Diagnose type 1 engine sound - marbles rolling around |
Guys I'm ashamed to even admit what the problem was.
I have an A/C system in progress right now. The compressor pulley came loose on the engine pulley, so I removed it and tightened the engine pulley bolt back down minus the washer. I didn't even realize the washer is what secures the pulley down!
esde Samba Member
Posted: Thu Nov 17, 2016 11:00 am Post subject: Re: Diagnose type 1 engine sound - marbles rolling around |
jeez, a human error?! I thought I was the only one that did that.. _________________ modok wrote:
mark tucker Samba Member
Posted: Thu Nov 17, 2016 11:03 am Post subject: Re: Diagnose type 1 engine sound - marbles rolling around |
dam you got some real thin wall sockets to do that. and the marbles...were in you head, dont worry we all been there before on short trips and long ones too.Be gladd you made it all the way back. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Nov 17, 2016 11:16 am Post subject: Re: Diagnose type 1 engine sound - marbles rolling around |
Gotta love that, this went from "case split" to "missing washer", can't beat the simple fixes
And we've all done similar things, don't feel bad. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Thu Nov 17, 2016 7:00 pm Post subject: Re: Diagnose type 1 engine sound - marbles rolling around |
Darn, I was going to guess right for once. |
