Inchpincher61 Samba Member
Joined: February 05, 2016 Posts: 141 Location: Germany
Posted: Tue Jan 24, 2023 1:34 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
FINALLY back on the Pan.
That milestone took about 5 years
I am still happy with the color choice and the motivation is kicking in right now
metz Samba Member
Posted: Wed Jan 25, 2023 1:52 am Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
What a way to start the year, congrats!
Going to convert my clock to tacho as well. Any key tips? _________________ 68 panel
64 ghia coupe |
TRS63 Samba Member
Joined: December 17, 2017 Posts: 999 Location: Stuttgart - Germany
Posted: Wed Jan 25, 2023 11:18 am Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Antoine, you will have that moment too
@Metz: I would recommend not to use an adapter ring to mount the smaller tach into the clock housing because I had no space left for stock lights. I had the problem that the single bulb of the tach is not sufficient to get any light into it. I had to add some LEDs to fix that problem.
metz Samba Member
Posted: Thu Jan 26, 2023 1:25 am Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Cool, thanks. Looks great! _________________ 68 panel
64 ghia coupe |
obus Samba Member
Joined: March 08, 2001 Posts: 11069 Location: just off Garden State Parkway Exit 81
JeffL Samba Member
Posted: Sun Jan 29, 2023 6:27 am Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Quote: |
JeffL: Really a great gauge setup |
Thanks @Jeff, I will probably have to open the fuel gauge due to dirty glas. Speedo looks good, what you see in the picture is just an reflection.
Yesterday I have check the tire fitment. I am planning to go with 185/65 R15. With the drop plates there is no problem even lifted. BUT this is not the final wheel. I have a set of OG Sprints 4" + 5,5". Fronts are fine with 33mm offset but the rears have 6mm offset. In comparison to the picture this makes +9mm. With enough camber I see no problem but I am a bit concerned when the car will be lifted.
Last but not least....I think we sometimes have to be proud for the steps that we have already made instead of complaining about failing to keep or own schedules. Good things take take their time. The lesson that I have learned so far is that you should not force any progress in cost of the fun in building cars.
So maybe some of you are demotivated sometimes as well?
That's my remedy:
TRS63 Samba Member
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2875 Location: Auckland, New Zealand
Posted: Sun Jan 29, 2023 11:55 am Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
TRS63 wrote: |
True words, and really a great motivational picture!
Antoine |
Someone should start a before-and-after thread. For motivation and as a record of Ghia history. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
