8URN Samba Member
Joined: August 20, 2007 Posts: 107 Location: Newcastle upon Tyne,UK
Posted: Sun Jan 08, 2017 1:07 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Great project and skills, looking forward to see how this turns out
I nearly bought a terra brown from Holland in the early noughties, loved the colour:
If your looking to restore the interior you can still get the original seat cloth material:
https://www.smsautofabrics.com/products/seat-materials/foreign-cars/volkswagen.php
Did you sell the engine bay sheet metal? |
Inchpincher61 Samba Member
Joined: February 05, 2016 Posts: 141 Location: Germany
Posted: Tue Jan 17, 2017 1:37 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Here are some pictures of the preparation of the fender. I am almost finished with the disassembly...
Furthermore we finished the corrections of the A-Pillar so we can soon move on with the rear end of the car.
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Thu Jan 19, 2017 4:02 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Wow, you are replacing the entire rear quarter and not just the outer panel! I am doing major surgery but not sure I would be brave enough to attempt this. Can you please show how you are bracing the body for when you cut the old one out? _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Posted: Sun Jan 29, 2017 1:07 am Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
@ Mellow Yellow: The first idea was to replace the whole section including the b-pillar but without the inner part you have below the quarter window. BUT we are now thinking about removing the outer wheel shell as well because this is the last chance to remove possible rust between the shell and the fender.
Except of the rear building site we did some progress in the front. We finished the little corner at the bottom of the A-pillar. Unfortunately it was not fixed at all so we connected it to the A-pillar and restored the edge of the fender... here we tried to form this section for beeing able to derive possible rain/water..
Posted: Sun Apr 16, 2017 12:50 am Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Hello Guys,
Its been a while since my last post but we of course made some progress in the meantime. The first goal was to finish the front. After welding on the top of the fender we have added some pewter to avoid centimeters of bondo.
Umfortunately the previous owner uses the same "technology" for the nose. We thought about leaving this section as it is but we were not sure about the rust between the two layers. Finally we wanted to have a continious weld even if the nose would maybe have some dents due to the welding.
AND I think it was the right decision:
So the the front is finished now, the door seems to be in the right position, the door gap is fine as well so its time to prepare the rear fender
c21darrel Samba Member
Posted: Tue Aug 08, 2017 12:27 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Hello Guys...
due to some other projects the Ghia is growing quite slow but fine I guess...
After stripping the fender we discovered some bigger dents and of course some rust but nothing too bad. Anyway its a lot of work until you have a useable fender for the Ghia....
To see if the fender has almost the same line like the passenger side we have built a simple tool to transfer the shape...
...replaced the rear corner...
...and finished it with some pewter...
...last but not least the lower section has been replaced with the original part that has been cut out the car...
I hope its going to have a good fit on the car...but we will see. |
Posted: Tue Aug 22, 2017 6:55 am Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Today I picked up the rear end from plastic blasting and 2K epoxy priming...
Awesome job from "Strahlwerk Deluxe" -> more aircooled stuff on FACEBOOK
Posted: Wed Sep 06, 2017 6:07 am Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Today we have taken a closer look to the fitment of the spare for the engine bay.
Passenger side looks fine.
At the driver side the inner wheel housing just need to be "hammered" back into the right shape... but its still close to the right position.
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Wed Sep 06, 2017 10:41 am Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
The engine bay is my next major job on my convertible. How difficult was cutting out the two sides and rear sections ? Is there any thing I should look for ? Thanks _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
Posted: Wed Sep 06, 2017 1:23 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
It depends on the spare parts you have for the replacement. If you donīt need the old metal you can cut everything out piece by piece. I would recommend to keep the bumper mounts if possible because in my mind these are good reference points. Furthermore you should try not to damage the parts that you keep in the car because this is your future base for the welding... so take your time for the disassembly. |
kgj Samba Member
Joined: February 25, 2013 Posts: 418 Location: Uk, Cornwall
Posted: Wed Sep 06, 2017 1:31 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Plenty going on here and equally inspiring.
I too will be heading into the engine bay soon so thanks for posting.
I'm watching. _________________ 1958 coupe |
Posted: Wed Sep 06, 2017 2:07 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Inchpincher61 wrote: |
Thanks for the information. I assume it is held in place by spot we!ds ? I have replacement panels. Which could be welded together prior to install if that is easier. _________________ ----------------------
Posted: Wed Sep 06, 2017 5:06 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
CiderGuy wrote: |
The engine bay is my next major job on my convertible. How difficult was cutting out the two sides and rear sections ? Is there any thing I should look for ? Thanks |
I just replaced my entire engine bay on my 62 - battery trays, bumper mounts, lock carrier panel, rear valance and wheel wells. You are lucky because the repro panels are all late style that will suit your 71 without modification. It is all held together with a lot of factory spot welds which you will need to remove carefully.
Note that there are brackets behind the valance and stiffeners under the battery trays that are not reproduced and the inner wheel wells are not reproduced so be careful when you drill out the spot welds.
Make sure you cleco everything in position before welding and trial fit the bumper and engine lid to check all is ok. Also do a template of the original engine opening and check this before welding as well. Also don't forget the small piece of rubber on the back of the battery trays which must be installed before welding - this is the same rubber as used on the hinge pillar cover plates _________________ 1962 Karmann Ghia
Posted: Wed Sep 06, 2017 6:27 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Mellow Yellow 74 wrote: |
CiderGuy wrote: |
Make sure you cleco everything in position before welding and trial fit the bumper and engine lid to check all is ok. Also do a template of the original engine opening and check this before welding as well. Also don't forget the small piece of rubber on the back of the battery trays which must be installed before welding - this is the same rubber as used on the hinge pillar cover plates |
Thanks great information. Would you have the part number for that rubber piece ? I'm not sure what it is. Thanks ! _________________ ----------------------
Posted: Wed Sep 06, 2017 9:36 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
CiderGuy wrote: |
Would you have the part number for that rubber piece ? I'm not sure what it is. |
Hi it is part number 141-805-381 - it is also used between the inner fender panels and the nose at the front _________________ 1962 Karmann Ghia
Posted: Wed Sep 06, 2017 9:52 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
@YellowMellow... thanks for the explanation. At the moment the parts are just laying in the car. We are going to fix all parts with screws first before the welding.
@ciderguy... yes everything is put together with spot welds...a lot of spot welds! I drilled out every single spot. Same as I had to do at the new fender. I needed about 10 spot weld cutter drill bits until I had everything dissassembled.
Here is a pic of the mentioned bracket sitting below the battery tray:
Posted: Thu Sep 07, 2017 2:40 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
c21darrel wrote: |
Quote: |
Thanks great information. Would you have the part number for that rubber piece ? I'm not sure what it is. Thanks ! |
It is the same profile that is used on the mud sills/hinge pillar and up front at leading edge of L/R fender to nose. At KGPR, when I bought for the mud sill it was enough for front and the short approx. 3-4 inch piece in the back.
https://www.karmannghia.com/Door-Hinge-Pillar-Cover-Plate-Seal/item/141-805-381 |
Thanks, I'll order them now, I need them also. _________________ ----------------------
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Thu Sep 07, 2017 3:36 pm Post subject: Re: 1962 - "San Bernardino" - Ghia Project |
Cider, you can see the short section of that rubber seal in the shot below. It's located at the transition of the rear of the flat engine surround panel to the vertical rear panel. Painted body color. This is on my pearl white '64 Ghia cabrio which has original paint in the engine compartment. Yeah, that rear area could use a bit of a cleaning . There is another such seal on the right side, but I don't have a good shot of it. |
