mikewilkinson007 Samba Member
Joined: October 26, 2016 Posts: 554 Location: Nebraska
Posted: Thu Dec 07, 2017 9:21 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Thanks Buggeee! That's a cool page.
Found that my brake pedal travel was too long due to me not adjusting the rear shoes properly. Adjusted them and checked the others. She stops on a dime or a couple dimes.
Ordered today:
Strut top bearings.
Control arm bushings.
Ball Joints.
Rear Tires.
Onward and upward! _________________ 72 Super - Marina Blue
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Long Gone: 70 Vert, 66, 68, 73SB, 70, 72, 61 Rag and a 64 with a cinder block in the spare tire well. |
Beetlebaum Samba Member
Joined: December 04, 2008 Posts: 2181 Location: Virginia Beach, VA
Posted: Fri Dec 08, 2017 9:23 am Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Beetlebaum wrote: |
Where'd you order the suspension parts? |
It's a combo of Topline and CIP1. _________________ 72 Super - Marina Blue
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Posted: Sat Dec 09, 2017 3:05 am Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Beetlebaum wrote: |
mikewilkinson007 wrote: |
Beetlebaum wrote: |
It's a combo of Topline and CIP1. |
Nice--I got my suspension stuff from Topline and really like the quality. |
Agree with you there! Everything from Topline has been really good so far. _________________ 72 Super - Marina Blue
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Posted: Sun Dec 10, 2017 9:24 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
This is the one job I've been really looking forward to getting done.
Luckily, my nephew has a really nice shop and lift at his house.
I replaced the ball joints (shot) control arm bushings (not terrible) and the stabilizer bar bushings (shot). The ride home was something I've dreamed of since I bought this little bug. No shake. No shimmy. Solid. Love it.
Getting the old bushings out of the control arms was the part I stressed about. An 8 ton press was as handy as you can imagine. One bolt in the stabilizer bar sheared off so had to drill and tap. Other than that, a pretty easy project. _________________ 72 Super - Marina Blue
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Mon Dec 11, 2017 12:44 am Post subject: Re: Mike's 72 Super Semi-Resto Thread |
I had one stabilizer-bar captive nut break loose inside the frame head. If you turned the bolt, it just spun around. There are four captive nuts that you install through the stabilizer brackets to hold the stabilizer bar to the frame head. If one is broken, your stabilizer bar slides around, which kind of negates the bar's purpose.
The fix was to first cut off the head of the bolt. But that still left one of the four stabilizer-bar attachment points useless, due to the captive nut shearing loose. So ... it was necessary to insert a new bolt upside down from its normal position, via the tiny access hole (the hole with the plastic plug) which is behind the area where the captive nuts reside. Then, I could fasten a nut below to hold the stabilizer bracket on.
Once this was done, I still had the problem with the bolt head inside the frame head. It kept turning, of course, as I wrenched on the opposing nut. So, I had cut an offset box end wrench in half, had a friend weld it back together at a right angle, then inserted this altered wrench inside the little access hole and onto the head of the bolt. Once the bolt head was being held by this wrench inside the frame head, I was able to tighten the nut below to torque (29 lbs. in my case).
If the forward captive nut had been the one that had sheared, I'd have been screwed. Fortunately, it was the rear one.
Talk about dodging a bullet ....
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Sat Dec 16, 2017 4:34 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Dialed in the new front end. Very solid at any speed.
New 165/80 15's on the rear.
Mechanically about set for now. Time to start the rest of the project! _________________ 72 Super - Marina Blue
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
vamram Samba Member
Posted: Sat Dec 16, 2017 4:40 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Looks awesome. What's the next phase? Like phase 3 in mr robot? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Posted: Sat Dec 16, 2017 8:57 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
vamram wrote: |
Looks awesome. What's the next phase? Like phase 3 in mr robot? |
Well I'm just starting the planning now but the usual. The decisions are color, carpet etc. Semi custom while keeping it fairly stock??? Still working it through my thick skull.
Still planning an all new engine build too. Not sure on size etc. But it won't be a screamer. I like my single port dual carb set up. _________________ 72 Super - Marina Blue
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Posted: Sat Dec 16, 2017 10:34 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Oh. And add this to my to do list.
Coming soon: 74 Vert Full Resto!
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Posted: Mon Jan 08, 2018 12:10 am Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Just a few things this weekend.
Replaced the turn signal switch finally. I could only make right turns because I didn't want to break any traffic laws.
And added a tachometer because I love watching her scream up to 3000 rpm.
I kid. I'm a kidder.
Also, I got around to replacing the emergency brake handle.
Carpet ordered so that's next! _________________ 72 Super - Marina Blue
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4406 Location: Stuck in Ohio
Posted: Thu Feb 08, 2018 2:46 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Test fitting new TMI carpet. So far so good!
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
vamram Samba Member
Posted: Thu Feb 08, 2018 6:40 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
What kind of seats are those? _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Fri Feb 09, 2018 12:41 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
vamram wrote: |
What kind of seats are those? |
Yanked them out of a Dodge Neon. _________________ 72 Super - Marina Blue
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Posted: Sat Mar 03, 2018 6:11 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Update:
Putting a new motor in this weekend. Going from an H motor to an AH dual relief.
I’m staying with single port dual carb set up I have now. Here’s a few pics of where I got to today. Should have her in and running tomorrow!
And, yes, this IS a German 034 you see! Finally!!
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Posted: Sun Mar 04, 2018 10:49 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
It went in fine. Got oil pressure up and started right away.
Unfortunately, I didn’t like the sound of it. Exhaust leak, valve noise, rod???
Idk. Definitely making a sound I don’t like. Shut her down so I’ll get into it in the next day or so.
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
