mikewilkinson007 Samba Member
Joined: October 26, 2016 Posts: 554 Location: Nebraska
Posted: Thu Sep 28, 2017 2:34 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Ordered today:
Pertronix SVDA with points replacement and Flamethrower Coil. _________________ 72 Super - Marina Blue
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Long Gone: 70 Vert, 66, 68, 73SB, 70, 72, 61 Rag and a 64 with a cinder block in the spare tire well. |
vamram Samba Member
Posted: Thu Sep 28, 2017 4:36 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
mikewilkinson007 wrote: |
Ordered today:
Pertronix SVDA with points replacement and Flamethrower Coil. |
Mike - hope you have better luck with those devices than I did in the recent past. I've purchased the same new over the last few years and BOTH went south within a year!! _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Zundfolge1432 Samba Member
Posted: Thu Sep 28, 2017 4:39 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Geez I had one fail last Saturday, I actually replaced it then it had been not advancing for awhile. Hope you have better luck.
Posted: Thu Sep 28, 2017 8:26 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Well it's already ordered so we'll see! Someone I respect a lot uses this model and really likes it. Maybe I'll get lucky! _________________ 72 Super - Marina Blue
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Posted: Sat Sep 30, 2017 11:42 am Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Waiting for parts gives me the unfortunate time to clean and repair.
Not may fave but gotta get the tin and shroud cleaned up. The PO did not run a thermostat so I'll be adding that too. This is a doghouse shroud and should help make this single port 1600 a dependable daily driver...which is the goal.
Brosol fuel pump getting a refresh too.
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Posted: Tue Oct 03, 2017 4:30 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Doghouse Shroud is rehabbed and put a coat of paint on it. All the flaps are working and I attached the thermostat rod thingy. I seem to recall it needs to be attached before putting the fan shroud on??
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Posted: Tue Oct 03, 2017 4:58 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Heat exchangers are ready! I'm starting to get close!
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Posted: Tue Oct 03, 2017 5:43 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Tins are ready. They are original.
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4421 Location: Stuck in Ohio
Posted: Tue Oct 03, 2017 10:46 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
One more piece before calling it a day!
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Chris333 Samba Member
Posted: Tue Oct 03, 2017 11:54 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
I'm going through the same stuff now. Got a decent shroud, but the flaps were removed. Got a shroud with flaps, but it is rough and rusty. So I will pull the flaps out.
72' came with a single port? Thought 1970 was the last year for those. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Wed Oct 04, 2017 3:36 am Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Mike, on the flaps, I recommend adding a drop of engine oil at the flap shafts. The shafts have a small amount of play in them front/rear, like 1/8". Place a drop of engine oil, or even 3-in-1 oil onto the exposed section of the shaft. Push the flap the other direction to expose the shaft on the other side, and place another drop of oil there. Wiggle the shaft front to rear, then rotate the flap to work the oil onto the shaft. Do this to each flap, as well as the down-rod for the thermostat.
Yes, that thermostat down-rod needs be attached like you have it before you lower the shroud down onto the long block. You need to see where the small hole is in the right cylinder head where the rod passes through, aim the rod down the hole and rotate the entire shroud slightly as you lower the shroud and see that the rod comes out the bottom of the head.
When you attach the cylinder cover tins to the heads, coat the fastening screws with anti-seize. When the screws are nearly tight, push the tins toward the center of the engine so that the opposite ends nearly, or do touch the engine case sides. This reduces/eliminates an air gap where cooling air can leak out. Then tighten the fastening screws.
As you set the fan shroud down onto the cylinder cover tins, make certain the shroud fits/slips inside of the cover tin top edges. Use a plastic wedge to pull the cover tin edges out as needed to slip the shroud inside. It's like tucking your shirt into your pants. |
Posted: Wed Oct 04, 2017 2:16 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Do the generator posts need to be in this position? I thought I read it somewhere. I'd like to put them more on top than in the 2-3 o'clock position they are now.
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Posted: Wed Oct 04, 2017 2:17 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Thanks Rome! Will do! _________________ 72 Super - Marina Blue
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
Posted: Wed Oct 04, 2017 4:10 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
There is an opening on the bottom of the generator from where air comes into it and cools it. This opening needs to match the location of the opening on the stand. _________________ **1971 Super Project
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 |
Posted: Thu Oct 05, 2017 2:02 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Thanks Joey! _________________ 72 Super - Marina Blue
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Posted: Thu Oct 05, 2017 5:46 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
It was a good day. Went from short block to this.
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Posted: Thu Oct 12, 2017 2:04 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Got the motor in today.
The dual carb install looks like it's gonna be a pain.!
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Thu Oct 12, 2017 2:37 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Be sure to use knee pads. It'll take a while to install the carburetors. The engine looks good.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
cjsuner Samba Member
Joined: January 04, 2013 Posts: 476 Location: Bay area CA
Posted: Thu Oct 12, 2017 2:59 pm Post subject: Re: Mike's 72 Super Semi-Resto Thread |
Lookin good!
But ya, as Tim said, be sure to wear knee pads, you will be down there a while. I usually end up using a combanation of 3 different socket extensions to reach the forward nuts. _________________ 71' Super Convertible (Orange)
74 Super Beetle (Red) |
