Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Fri Nov 25, 2016 7:04 am Post subject: Black Friday 2016 - $199 Eastwood MIG Welder 110VAC/ 135A Output |
This is a PSA and should not be considered an endorsement.
EDIT: As of 10:00 AM EST on 12-01-16 the deal is still available using the promo code/Source Code below.
This is a direct link to the deal:
http://www.eastwood.com/mig-welder-110vac-135a-out...ArJX8P8HAQ
The promo code for this deal is:
TXT00110 (To be used in the "Source Code" field during the check-out process.)
I just ordered one and the deal includes free shipping.
I found the deal by Googling on my phone (PC results were different) so always check from various sources since retailers tend to monkey with search results and pricing depending on your location and device. _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted
63 vwnotch Samba Member
Joined: December 31, 2002 Posts: 734 Location: Riverside,CA Econo Motors
Posted: Fri Nov 25, 2016 9:41 am Post subject: Re: Black Friday 2016 - $199 Eastwood MIG Welder 110VAC/ 135A Output |
shows up for $259 on my Samsung 6.. this is the exact unit I was looking to buy when the time came... but at 199 shipped you just cant beat it.. _________________ BUS WANTED: 13 window BUS any year considered.. |
Posted: Fri Nov 25, 2016 10:07 am Post subject: Re: Black Friday 2016 - $199 Eastwood MIG Welder 110VAC/ 135A Output |
Use the link in the post above. It should take you directly to the deal. If that does not work try the "TXT00110" promo code during the checkout process. I noticed the promo code was included in the form when I was checking out.
I used a Samsung Galaxy Note 3 when I searched. The search string I used was "black friday mig welder" and I used the Google search bar on the home screen. The Eastwood MIG was the first result. You may also have to be on their mailing list for the "WEB" to track you and show you the deal. There was a post on TS last summer and people were having to sign up for the Eastwood mailing list, create an account on the site, and then log in to the Eastwood site and search/browse for the 135 MIG. Here is the link to that thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=632254
I joined the mailing list about 1 Mo. ago and I also created an account on the site. That is probably the way to go to get the deal. Get creative and don't give up. _________________
kiwighia68
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Fri Nov 25, 2016 1:48 pm Post subject: Re: Black Friday 2016 - $199 Eastwood MIG Welder 110VAC/ 135A Output |
I would vouch for their powder coat set up . Its on sale as well. Ive used it quite a bit, even on my stock wheels . I'm contemplating getting the nickel~tin plating kit......... |
Redlabel6 Samba Member
Joined: October 17, 2016 Posts: 383 Location: Minnesota
scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
Posted: Sat Nov 26, 2016 6:53 pm Post subject: Re: Black Friday 2016 - $199 Eastwood MIG Welder 110VAC/ 135A Output |
I am not sure but I just followed the link in the OP, on my Mac/PC, and it popped up at $199. The banner at the top of the Eastwood page says the Black Friday sale runs through 11/27/16
I tried it from my wife's iPad yesterday and was able to get the $199 deal as follows: (I was confirming the deal for a fellow TS member)
1- go to www.eastwood.com
2- search for MIG 135
3- Add to cart
4- Proceed to check-out
5- Enter TXT00110 in the "Source Code" box on the lower left
6- continue with the Check-Out process
The price should change from 259 to 199. I did not go any further but the free shipping option should appear on one of the subsequent "Check-Out" pages.
I hope you are able to get the deal. If you do, post your process to the thread for others to follow. _________________
kiwighia68
Posted: Mon Nov 28, 2016 6:09 am Post subject: Re: Black Friday 2016 - $199 Eastwood MIG Welder 110VAC/ 135A Output |
As of 8:00 Am EST on Monday 11-28-16 the deal is still available using the promo code/Source Code TXT00110. _________________
kiwighia68
Posted: Thu Dec 01, 2016 8:14 am Post subject: Re: Black Friday 2016 - $199 Eastwood MIG Welder 110VAC/ 135A Output |
YUP, as of 10:00 AM EST on 12-01-16 the deal is still going on using the TXT00110 code. _________________
kiwighia68
Posted: Thu Dec 01, 2016 9:43 am Post subject: Re: Black Friday 2016 - $199 Eastwood MIG Welder 110VAC/ 135A Output |
shows its out of stock...I almost pulled the trigger but most likely it will just sit here for a year before I need it so I'm hopeful the same deal will be going on next year when I need it.. _________________ BUS WANTED: 13 window BUS any year considered.. |
Posted: Fri Dec 02, 2016 6:36 am Post subject: Re: Black Friday 2016 - $199 Eastwood MIG Welder 110VAC/ 135A Output |
63 vwnotch wrote: |
shows its out of stock...I almost pulled the trigger but most likely it will just sit here for a year before I need it so I'm hopeful the same deal will be going on next year when I need it.. |
I received an E-Mail from Eastwood yesterday saying they were back in stock. You may want to try again if you are still in the market. Mine is due in today! Not sure why they sent me the e-mail other than I am now on their marketing distribution list.
d _________________ 1957 Oval Window Beetle
1973 Karmann Ghia Coupe
https://www.thesamba.com/vw/forum/viewtopic.php?t=666792&highlight=73+coupe |
