Robw_z Samba Member
Posted: Wed Nov 30, 2016 8:10 pm Post subject: Re: Converting Waterboxer to Megasquirt |
So what are anecdotes about running this setup? Improved MPG, power, reliability? I expect improvements would be subtle but am still curious.
-Rob |
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Thu Dec 01, 2016 3:23 pm Post subject: Re: Converting Waterboxer to Megasquirt |
Robw_z wrote: |
So what are anecdotes about running this setup? Improved MPG, power, reliability? I expect improvements would be subtle but am still curious. -Rob |
Yeah, I saw the Q about fuel mileage on the previous page. Can a couple of owners who've done this pricey conversion report on that? |
Posted: Thu Dec 01, 2016 3:31 pm Post subject: Re: Converting Waterboxer to Megasquirt |
mine was running "less than optimally" with the Digifant. Much better with good MPG now, and a lot more power too. I haven't done a long trip to acquire hwy mpg numbers. I will report it when I get it, but it's pretty much mothballed for Winter here, until April or so. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Thu Dec 01, 2016 4:58 pm Post subject: Re: Converting Waterboxer to Megasquirt |
You said the pulley had to be rebalanced with the trigger wheel. How was that accomplished? Did the vender do that for you or did you have that done?
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Thu Dec 01, 2016 5:11 pm Post subject: Re: Converting Waterboxer to Megasquirt |
pinetreeporsche wrote: |
Pricey conversion? Different strokes for different folks. I was surprised it could all be purchased for $1k.
I would like to think that there is the possibility of incorporating a knock sensor. |
Robw_z Samba Member
Posted: Thu Dec 01, 2016 7:05 pm Post subject: Re: Converting Waterboxer to Megasquirt |
CdnVWJunkie wrote: |
If a knock sensor can be wired in it would open up a whole new world for upping compression with custom or DJ 2.1 pistons. Increasing the compression, in my limited engine theory knowledge, is the most effective way to increase mpg and power. Factory Difigant constrains this avenue.
-Rob |
bluebus86 Banned
Posted: Thu Dec 01, 2016 7:18 pm Post subject: Re: Converting Waterboxer to Megasquirt |
Robw_z wrote: |
-Rob |
the thousand bucks or so of this system, plus your time (time is money) will buy a lot of fuel, the stock digifant system is pretty reliable, and there is only so much extra power you can get by changing the injection system only.
it may be a fun project, but practicality is questionable for mileage, power, and reliability. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Thu Dec 01, 2016 7:30 pm Post subject: Re: Converting Waterboxer to Megasquirt |
He keeps completed pulleys on the shelf. Basically you can do it one of 2 ways.
Send your pulley in and he'll do YOUR pulley, but this can take 1-2mos to do them in a batch.
Or what I did, was send him mine, and he sent me another one which was already modified and balanced.
Frankly, changing the pulley was one of the most challenging parts of the entire job, since I don't have the factory tool to loosen the pulley bolt (over 200lb/ft). I had to drop the muffler and rear heat shield, and use a strong impact.
hdenter wrote: |
I was so frustrated with the Digifant, everything checked out but it was completely unreliable. I considered carbs, but I knew that if I did that it wasn't optimal, since I do a lot of driving at high and low elevations, and carbs do NOT compensate for this like FI can.
Hans |
remraf Samba Member
Posted: Fri Dec 02, 2016 3:39 pm Post subject: Re: Converting Waterboxer to Megasquirt |
Noticed Mario at thedubshop posted images of modified wasser intakes for modern/newer fuel injectors. Is this something he's working with you on? Curious if he has any plans to release a system for wbxr. Gowesty's system is now out of my price range. |
a1fa Samba Member
Joined: September 25, 2011 Posts: 585 Location: Central Arkansas, United States
Posted: Fri Dec 02, 2016 7:08 pm Post subject: Re: Converting Waterboxer to Megasquirt |
Yes, you can incorporate knock sensor. I have a knock sensor for my air cooled setup and microsquirt, but have not yet wired it in. _________________ Learn to ride. Ride to learn. |
toomanyveedubs Samba Member
Joined: November 26, 2007 Posts: 596 Location: Great White North
Posted: Sat Dec 03, 2016 5:40 am Post subject: Re: Converting Waterboxer to Megasquirt |
Of course you can wrie up a knock sensor, the trick is tuning it to the ping of a vanagon engine and locating the sensor in the best spot. Pretty sure this is what gowesty is struggling with for its system. |
leebh1975 Samba Member
Joined: April 09, 2014 Posts: 14 Location: Hillsboro, OR
Posted: Sat Dec 31, 2016 10:35 am Post subject: Re: Converting Waterboxer to Megasquirt |
a1fa wrote: |
It's about a $1000 - insignificantly less if you go down the junkyard route.
microsquirt ~ $375
ign4 wasted spark coil ~ $80
ignition coil driver ~ $89
trigger kit ~ $124
quality 1bar map sensor ~ $50
iat sensor ~ $15
clt sensor ~ $43
wideband o2 and controller ~ $100
pigtails and other misc wiring items - $140
optional cam trigger ~ $149
optional TPS - $80
There is just no way around a grand it if you go with off the shelf items. The crank trigger is worth it.
For my project, I ended up copying well behaved SVDA distributor curve, with a slight advance.
John, would you mind sharing your ignition map, and AFR map? |
What did you use for the TPS? I have an idea of what I'd need to do a Megasquirt project on my van, but I'm not sure what TPS to use. |
Posted: Sat Dec 31, 2016 4:13 pm Post subject: Re: Converting Waterboxer to Megasquirt |
I did not use a TPS, I did MAP sensor only. TPS is best used on engines with "oversized TBs", but for an engine with adequate vacuum it's not needed at all.
My fuel and ignition maps are based off of manifold pressure and barametric pressure (for correction). _________________ It's just advice, do whatever you want with it!
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2332 Location: Southeast Kentucky
Posted: Sat Dec 31, 2016 10:23 pm Post subject: Re: Converting Waterboxer to Megasquirt |
Very interesting and I am glad to see this Thread...
I've been looking into doing the MS install on an in-line 2.2 5-cylinder Quantum engine for my 89 carat. I have inquired about the possibilities and they said it can be put together ... I have an 87 engine with less than 140 miles on as well as the South African Bell Housing.
Subscribed... _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
a1fa Samba Member
Posted: Sun Jan 01, 2017 8:28 am Post subject: Re: Converting Waterboxer to Megasquirt |
[email protected] wrote: |
My fuel and ignition maps are based off of manifold pressure and barametric pressure (for correction). |
Yes, and your engine will run just fine. However, incorporating TPS is not only for fuel delivery but also for acceleration enrichment, and more importantly, idle timing control. This way you can have very high advance on your idle w/o, and very precise RPM control at idle through timing variation. This feature is not available unless you have a way of signaling the ECU throttle plate is closed. _________________ Learn to ride. Ride to learn. |
Posted: Sun Jan 01, 2017 9:12 am Post subject: Re: Converting Waterboxer to Megasquirt |
That feature is not at all important to me. I never drive at 800RPM at 0 load, so I have that cell programmed as idle.
It runs fantastic, passes emissions, and MPG improved a ton over the stock FI.
I am very aware of the capabilities of MS, but I am also realistic. This is a STOCK ENGINE. I don't need to have race features for this engine in a multivan. I have kids and more important things to do with my life than tweak MS for 4 years "perfecting it". I have raced in the past, and know that the system is ideal for that, but you don't have to use everything in order to use it at all.
I kept it simple by
using MAP (no TPS)
Using batch fire injection
Using wasted spark ignition
In fact, many "features" beyond the basics simply prevent most guys from taking on a project like this, because in their mind (and mine too) it becomes too complex to consider. There is a learning curve, and it CAN be significant. By keeping it simple they can easily get running, and learn new features as their brain gets up to speed on it's capabilities. _________________ It's just advice, do whatever you want with it!
Posted: Sun Jan 01, 2017 9:51 am Post subject: Re: Converting Waterboxer to Megasquirt |
^^^^ That's what I've wanted to hear, as the response(s) I got appeared to involve making my engine far more than I want or need. And, no doubt, at the moment I am still standing on the ground facing that ladder. _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
a1fa Samba Member
Posted: Sun Jan 01, 2017 11:30 am Post subject: Re: Converting Waterboxer to Megasquirt |
John, I believe you may be missing a point.
It's not about driving at 800 RPM, and 0 load (unrealistic) - It's about achieving efficiency; even if it takes you 4 years to get there. You are not adding any more complexity over what you have.
I'm not picking on you or bashing your choices by any means; I was responding to the question why TPS would be desirable.
My system is exactly the same (MAP,BATCH,WS,WB02 with EGO,FUEL CUT OFF). Hell, even my latest fuel map and ignition map are very close to Federal L-Jetronic with SVDA. My van will cold-start and run just like it would've with L-Jetronic -- no need to jockey with the throttle to keep the RPM up, and it will also maintain IDLE RPM hot.
The engine is perfectly happy with timing and fuel... That took 4 years to get to, but in hindsight it would've been much easier to achieve that with TPS, idle control and burn less fuel in process. It would also be a lot more resilient/adaptable to the engine conditions, down the road. _________________ Learn to ride. Ride to learn. |
Posted: Sun Jan 01, 2017 5:54 pm Post subject: Re: Converting Waterboxer to Megasquirt |
maybe I'm stupid, but my engine behaves just like yours does, and I'm not using TPS nor a throttle switch.
If TPS/Throttle switch work for you that is great, but I found I didn't need it at all. Maybe I'll add it in a couple years, but I don't see the point in a 5k pound van with 90hp. _________________ It's just advice, do whatever you want with it!
jocoman Samba Member
Joined: August 11, 2016 Posts: 427 Location: Ottawa, Canada
Posted: Sun Jan 01, 2017 6:58 pm Post subject: Re: Converting Waterboxer to Megasquirt |
This is so interesting it never fails to amaze me how we can adapt just about anything to these great old vehicles.
Will you be sharing a "how to"? I'm sure a lot of people would love to do this modifications, including me but I don't think I could "trail blaze" . I can follow instructions.
Thanks for sharing. |
