olivetree Samba Member
Joined: July 31, 2005 Posts: 21 Location: Oakville, Ontario, Canada
Posted: Mon Nov 28, 2016 9:55 pm Post subject: Looking for Information for an Okrasa 36hp Engine Build |
I am building a 36 hp Okrasa engine with the WW carb and head kit and 80mm P&Cs and I am considering also going with a 69.5mm stroker crank. I am trying to come to grips with the potential issues that the stroker crank may result in. My major concerns are reduced engine life and higher engine temperatures. I am not sure what compression I will be running but it will see ambient temps of 90 degrees in the summer.
I would appreciate hearing from people who have experience running 36hp okrasa engines with 69.5mm and stock cranks. I would like to hear about your experiences with engine longevity and engine temperatures.
I would also like opinions on whether anyone has had issues running stock 36 hp rods in an okrasa engine.
I have searched the Samba forums for this information but came up empty so I would appreciate any info. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Nov 29, 2016 6:29 am Post subject: Re: Looking for Information for an Okrasa 36hp Engine Build |
21k on mine. 69.5 crank stock rods 77 jugs. 8.5 CR
no heating issues _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Tue Nov 29, 2016 7:11 am Post subject: Re: Looking for Information for an Okrasa 36hp Engine Build |
Are you adamant about using WW carbs/linkage? Their heads are great, but need a little port work.
I ask because with the 80mm p/c and 69.5 crank, I'd recommend that you buy the Speedwell Okrasa to IDF manifolds and go with 36 or 40 IDFs.
Much more bang for your buck and higher quality carbs as well. Here's a picture of mine in the process of installing the manifolds/carbs. I'm waiting on a few parts to finish.
tobiasax Samba Member
Posted: Tue Nov 29, 2016 11:57 am Post subject: Re: Looking for Information for an Okrasa 36hp Engine Build |
olivetree wrote: |
I have an Okrasa 1300TSV bottom end (but with Zeniths instead of Solex), I run 8,2:1 compression and a stock camshaft. As the original Okrasa heads can't be used with thermostat I am more concerned it runs cold. During last summer here in Sweden I was never even close to having a "hot" engine. I have tuned the engine on a dyno to be sure I don't run too lean (hot). Perhaps I can even go to smaller jets and squeeze a little more power out of the engine, but I prefer to play it safe.
The rods shouldn't be a problem, just clear it so it misses the cam _________________ __________________________________________ |
