E-Brake levers with rivets, Brake Shoes
captincanuck
captincanuck is offline
PostPosted: Tue Nov 29, 2016 6:27 pm    Post subject: E-Brake levers with rivets, Brake Shoes Reply with quote
Working on my brakes this last week I come across this issue that I couldn't find much info on, so thought I would share it.
The rear brake shoes on my 79 had the E-brake lever riveted on to them instead of using the standard clip.
Shouldn't be mush of a problem, but the rivets actually have a shoulder on them with the levers having a larger hole than a standard clipped on lever
No luck finding a piece of tubing to make a shim, so I ended up center drilling out the old rivets, grinding them down, and using them to sleeve the new pins.
Seemed to work well. One question, of the 3 possible places you could put the wavy washer, is this the correct 1? (Between the shoe and the lever)
A Before and After
1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0
busdaddy
busdaddy is offline
PostPosted: Tue Nov 29, 2016 6:56 pm    Post subject: Re: E-Brake levers with rivets, Brake Shoes Reply with quote
Nice work!, especially the redrilling to make a sleeve, I would have called the FLAPS myself for some fresh pins.
The wavy washer is best under the head of the pin, it keeps the lever pressed against the shoe and prevents rattles, lots of Never-seeze on all the moving joints of course. Leave the washer where it is until you are in there next time, it won't make a whole lot of difference as is.
SGKent Premium Member
SGKent is offline
PostPosted: Tue Nov 29, 2016 9:49 pm    Post subject: Re: E-Brake levers with rivets, Brake Shoes Reply with quote
rebuilt shoes often are often presented with a pounded rivet instead of a horse shoe. Nice work.
Godspeed to all who undertake a journey in a VW Bus.
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing those right.
It isn't our fault you bought a 50-year old toy you can't afford. None of us can afford it really. Even Steve Jobs had to sell his bus to make his financial life work.
1971 (sold)
1977
BellePlaine
BellePlaine is offline
PostPosted: Mon Aug 07, 2017 11:10 am    Post subject: Re: E-Brake levers with rivets, Brake Shoes Reply with quote
Just wanted to say thanks for this post. My worn out shoes are riveted as well. I now know I might have to make sleeves out of the old rivets.
'75 Riviera
Whether you are a novice or know your way around an ACVW, a day with Amskeptic is money well spent. My mechanical ability/knowledge/bus is always better after Colin visits.
http://www.thesamba.com/vw/forum/memberlist.php
Goach2
Goach2 is offline
PostPosted: Wed May 30, 2018 7:36 pm    Post subject: Re: E-Brake levers with rivets, Brake Shoes Reply with quote
Hope it's ok to revive this thread...
I have shoes with the levers riveted on. I picked up new shoes and the pins with washer and clips. The holes were the same size, so I didn't need the 'shoulder' as discussed earlier, however the pin is considerably longer than the original rivet and when the clip is put on, it just barely stays on and I can see it falling off quite easily once things start moving. Do they make shorter pins that would tighten things up? Or is there some trick to make the clips stay put?
1977 FI Westfalia
Tcash
Tcash is offline
PostPosted: Wed May 30, 2018 8:06 pm    Post subject: Re: E-Brake levers with rivets, Brake Shoes Reply with quote
They make shorter ones.
Depending on how long they are you can use wave washers under the head of the pin or stack washers next to the clip.
timvw7476
timvw7476 is offline
PostPosted: Wed May 30, 2018 8:30 pm    Post subject: Re: E-Brake levers with rivets, Brake Shoes Reply with quote
There are decent E clips at any serious hardware/fastener store too.
I would let the arm work directly against the shoe, but whatever provides
decent feel/bite at the handle is what matters most.
Goach2
Goach2 is offline
PostPosted: Thu May 31, 2018 4:16 am    Post subject: Re: E-Brake levers with rivets, Brake Shoes Reply with quote
Ok, so it is tension on the pin that keeps the clip in place. I'll try a washer or two.
1977 FI Westfalia
Goach2
Goach2 is offline
PostPosted: Thu May 31, 2018 5:13 am    Post subject: Re: E-Brake levers with rivets, Brake Shoes Reply with quote
I just found this video that explains a 'C' clip, is is the same procedure for a 'horseshoe'?
https://www.youtube.com/watch?v=dTDBcmRkbhM
1977 FI Westfalia
Tcash
Tcash is offline
PostPosted: Thu May 31, 2018 8:01 am    Post subject: Re: E-Brake levers with rivets, Brake Shoes Reply with quote
The horse shoe ends need to be bent to stay on the pin.
https://m.youtube.com/watch?v=dTDBcmRkbhM
Goach2
Goach2 is offline
PostPosted: Thu May 31, 2018 10:09 am    Post subject: Re: E-Brake levers with rivets, Brake Shoes Reply with quote
Thanks for confirming, probably should have known that....
1977 FI Westfalia
