houseofboyd Samba Member
Joined: September 28, 2014 Posts: 613 Location: Flatwoods, Ky
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Dec 03, 2016 1:09 pm Post subject: Re: Back To Stock????? |
I'm not sure I understand the question. Did you install the narrowed beam yourself? Going back to stock would be no more difficult than any front beam swap.
You would have to remove the front beam. I think the procedure is covered in the Bentley manual. It's not overly difficult but it IS heavy. I've done it by myself but it helps to have a friend or two. You can swap the brakes over and maybe even get by without bleeding them. You'll need a set of stock length tie rods if you don't have them with your 1968 beam since your narrowed beam has narrower ones. Same goes for the torsion bar stacks. If you want to go COMPLETELY back to stock then you'll also need a set of stock spindles and brakes to replace the lowered ones you have now because your standard height (drum) spindles won't work with your disc brakes. You have to switch the steering box over from the old beam to the new one. You might also have to deal with the sway bar. The car will need aligned when you're done. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Sat Dec 03, 2016 3:55 pm Post subject: Re: Back To Stock????? |
Even if you intall a stock-width beam, if you transfer over the lowered spindles you'll most likely have clearance problems with your GasBurner wheels. The wider wheels will tend to cause the tires to contact the inner edge of the front fender lips. If you want to stay with stock-height and the discs and the GB wheels, you'll need stock Ghia spindles which have the holes for the disc brake backing plates.
If you decide on stock front ride height with the GBs, will you raise the rear suspension so that the car will have a level stance?
Posted: Sat Dec 03, 2016 6:48 pm Post subject: Re: Back To Stock????? |
Rome wrote: |
Thanks for your input. I'm thinking going back to stock as in wheels and all. Correct ride height, etc. Only thing I'd like to keep are the front disc brakes. Don't know, just kicking around the idea... _________________ Our 1968 Zenith Blue Beetle: http://www.thesamba.com/vw/forum/viewtopic.php?t=619501
My '74 SB Build On The Samba: http://www.thesamba.com/vw/forum/viewtopic.php?t=609943
Our Web Site: http://www.kentuckyhotwheels.com
1968 VW Beetle
2012 Turbo VW Beetle |
wcfvw69 Samba Purist
Posted: Sat Dec 03, 2016 7:17 pm Post subject: Re: Back To Stock????? |
You must be getting older. Back in the early 80's I had a lowered Cal-look bug. I shudder when I think about how rough that bug rode but I was young. Those 135 tires I had on it provided crap braking too.
Now, my bugs are bone stock and I appreciate the ride with the factory oil shocks, correct tire inflations and "meaty" 165's up front.
Yea, I'm getting older. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sat Dec 03, 2016 8:35 pm Post subject: Re: Back To Stock????? |
wcfvw69 wrote: |
Yea, I'm getting older. |
Yes, that's plays into the factor as well... _________________ Our 1968 Zenith Blue Beetle: http://www.thesamba.com/vw/forum/viewtopic.php?t=619501
1968 VW Beetle
Rome Samba Member
Posted: Sun Dec 04, 2016 8:24 am Post subject: Re: Back To Stock????? |
Unless you already have your stock wheels so that you need to find a set, be aware that there are at least 4 different versions of the 4-bolt hubcap wheel. They are all 15" but vary in width (4.0" vs 4.5") and the offset (deep dish effect). You can tell the relative offset by holding a yardstick across the rim edge diameter, then seeing how far down the highest part of the hub is. Wheels with a high offset number such as ET46 have the hub higher than the rim. Those with most offset (e.g. ET34 from a '72) have the hub about a half inch down/inwards from the edge. I've often seen Beetles and Ghias at VW shows which are nicely done, wheels are refinished, but offsets don't match.
ET stands for the German words for "press-in depth", Einpresstiefe. On many of the stock wheels the ET # is stamped into the flat sections adjacent to the lug bolt holes*. One of the in-between values is ET41 on the 4.5" rim.
Best combination IMO would be a set of 4.5" ET34, painted in the '68 style black and cream. Stock looking, but slightly wider stance than original '68 which had the 4.0" wide rims.
*From the gallery:
