Flatz Samba Member
Posted: Sat Dec 03, 2016 7:48 pm Post subject: Engine mounts |
New owner of a 2000 eurovan mv with 147,000 miles and in need of the engine and trans mounts changed. Taken it to a shop and was quoted $1000 just for the parts. I have seen the right engine mount and the pendulum trans mount for around $80 each unable to find the left engine mount online. My question to the folks here, Is changing the mounts an easy job and is the shop raping me on parts cost? Any help will be appreciated.
Got the van for cheap and it needs some work done, I've been looking through many a post here and have yet to see one on the engine mounts. The mechanic says the engine is sagging and rubbing on the steering rack.
thanks |
gakali Samba Member
Joined: August 19, 2007 Posts: 448 Location: Cambridge, Ontario, Canada
Posted: Sun Dec 04, 2016 8:31 am Post subject: Re: engine mounts |
Assuming they are quoting you full retail with mark-up and possibly shipping sadly the price may not be out of line.
Here is a mount set for reference but they may not ship to you due to weight.
http://europarts-sd.com/engineandtransmissionmountkit1997-2003.asp
The replacement job isn't bad for someone with the right equipment and right aptitude. _________________ Why do it? Because you can.
1999 Eurovan
2003 A4 Avant 1.8T Quattro
1992 W201 190e 2.3 Mercedes
2006 W220 S600 V12 Twin Turbo 5.5 Mercedes |
JMB3 Samba Member
Posted: Sun Dec 04, 2016 10:57 am Post subject: Re: engine mounts |
Flatz wrote: |
I started a wiki article when I did my 1997:
http://vweurovan.wikia.com/wiki/Engine/Transmission_mounts
I still need to get back under there and finish with the pendulum mount. I didn't have all my tools with me when I did the left and right ones, but now I don't have an excuse. |
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
Flatz Samba Member
Posted: Sun Dec 04, 2016 6:05 pm Post subject: Re: engine mounts |
thanks for the help and quick responses. I will give it a shot. The EV is going to be a project so anything I can do myself will be nice on the pocket book. I have a list of things to do it
thanks again |
Summers420us Samba Member
Joined: June 14, 2010 Posts: 759 Location: Amissville, Virginia
Posted: Mon Dec 05, 2016 8:38 pm Post subject: Re: engine mounts |
how do you know when bad? _________________ 1997 EVC
1988 2WD Westfalia with OE 2.1 (R.I.P.) |
JMB3 Samba Member
Posted: Wed Dec 07, 2016 11:50 am Post subject: Re: engine mounts |
Summers420us wrote: |
how do you know when bad? |
In the OP's original post, he or she said
Flatz wrote: |
The mechanic says the engine is sagging and rubbing on the steering rack. |
For a better understand of why this is bad bad bad, read the europarts-sd page dedicated to the engine mount kit. It describes the damage that can occur to the power steering pressure pipes. |
gakali Samba Member
Posted: Wed Dec 07, 2016 7:00 pm Post subject: Re: engine mounts |
There is also a bracket with a rubber snubber block that pushes up on the down-pipe to prevent contact with the rack. I bought a new rubber block for mine as it was long-gone. _________________ Why do it? Because you can.
1999 Eurovan
markcm2 Samba Member
Joined: September 02, 2015 Posts: 505 Location: Bellingham, Washington
Posted: Thu Dec 08, 2016 10:00 pm Post subject: Re: engine mounts |
I recall buying FEBI mounts for my 1993 (maybe different than the 2000), it was 2 uppers and a lower. I paid just over $100 shipped for the parts. The lower was a bit tricky but I managed to swap it out without any instruction, just looking, thinking, wrenching.
$1000 for parts seems knucking Futz to me. |
JMB3 Samba Member
JMB3 Samba Member
Posted: Sat Nov 11, 2017 10:14 am Post subject: Re: engine mounts |
I let my curiosity get the better of me and ordered a Febi 37099 bushing from an Ebay seller in the UK and had a machinist press it into my original pendulum arm for me. If I ever figure out an approach to the trans bushing and get back under there, I'm going to swap the original back in. That Febi bushing just looks more heavy duty to me. More photos in the wiki article. |
Abscate Samba Member
Posted: Sun Nov 12, 2017 4:57 am Post subject: Re: engine mounts |
gakali wrote: |
There is also a bracket with a rubber snubber block that pushes up on the down-pipe to prevent contact with the rack. I bought a new rubber block for mine as it was long-gone. |
I had to do this too. The symptom here is a sharp resonant vibration st about 2000 rpm _________________ .ssS! |
amyshannon Samba Member
Posted: Sun Dec 17, 2017 9:43 pm Post subject: Re: engine mounts |
hi everyone,
i am leaking power steering fluid bad I am certain it is from the lines on the rack i see the link to where to buy the engine and transmission mounts but i am hoping i only need to replace the rubber block that pushes up on the exhaust down pipe
where can i purchase that ?
i just had the exhaust replaced from the cat back and i dont here anything or feel anything unusual when i shift from reverse to neutral to drive
Thanks !!! |
mvaska Samba Member
Joined: February 26, 2015 Posts: 135 Location: United States
Posted: Mon Dec 18, 2017 1:09 pm Post subject: Re: engine mounts |
i seriously doubt that one little bumper will solve your problem if the main mounts are worn enough to contact the PS line. the engine mounts on these vans are beefy.
the damage/contact happens first when the engine is pulling hard at around 2k rpm. if you accelerate slowly enough it may not happen even if the mounts are really worn.
eventually the mounts get so worn that it happens under normal driving acceleration.
i drove mine some 10k miles with this issue just by being careful to back off immediately if i felt it contact. finally replaced the mounts last month and there really wasn't much damage to the PS line.
huge difference new vs old. |
mkscott2 Samba Member
Joined: February 16, 2017 Posts: 90 Location: Cincinnati
Posted: Thu Feb 01, 2018 5:56 am Post subject: Re: engine mounts |
Just had the left and right mounts done on my van (180k miles), and it made a dramatic difference in the way it drives. Like mvaska, I was nursing the van along by taking caution not to get to the point where I felt vibration in the steering column. I thought replacing the mounts would only impact this concern, but the van actually drives SO much more smoothly and I feel like we have lost power/acceleration back.
I was going to do the job myself, but I'm running short on time. Shop did it for $600 out the door. Worth every penny IMO. |
Michelson Samba Member
Posted: Mon Jan 28, 2019 1:10 pm Post subject: Re: engine mounts |
I need to get this done, and I need to buy the parts.
At Partsgeek, they list 4 engine mount parts:
Febi 7445-08053378 Engine Mount
Febi 7445-05817685 Engine Mount
Febi 7445-05817685 Engine Mount Right
DEA 7445-07199854 Engine Mount Front Right
Similar situation on Ebay.
Are left and right mounts identical (as first two items seem to indicate)?
If different, anyone know of a source for the Left one?
Many thanks. |
Joshwa Samba Member
le-coq Samba Member
Posted: Wed Dec 09, 2020 1:48 pm Post subject: Re: engine mounts |
Does anything need to be braced when replacing the pendulum mount? Doesn’t appear so but this could also be famous last words. |
Joshwa Samba Member
bcolins Samba Member
Joined: December 04, 2020 Posts: 729 Location: Austin, TX
Posted: Tue Dec 15, 2020 5:32 pm Post subject: Re: engine mounts |
Flatz wrote: |
thanks |
I just ordered the pendulum mount for $28 from AutohausAZ |
