hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Sun Dec 04, 2016 3:27 am Post subject: Weber 40 IDF missing plug? |
Hi guys,
been chasing this weird carb problem,
can anyone tell me if this plug is missing? or is it ment to be open?
_________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun Dec 04, 2016 4:03 am Post subject: Re: Weber 40 IDF missing plug? |
Yes, It's missing _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Sun Dec 04, 2016 4:04 am Post subject: Re: Weber 40 IDF missing plug? |
madmike wrote: |
Yes, It's missing |
d#mn,
how did that happen???
should i thread it and loctite it?
where does the hole lead? _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Posted: Sun Dec 04, 2016 4:38 am Post subject: Re: Weber 40 IDF missing plug? |
Thanx for the quick reply,
i made a plug out of an old 6mm stud,
put some red loctite on it,
i've also peened the other one over just to be safe.
SBD wrote: |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Sun Dec 04, 2016 8:42 am Post subject: Re: Weber 40 IDF missing plug? |
hobbybob517 wrote: |
i've also peened the other one over just to be safe. |
Good job. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Sounds ok to me,
what do you guys think? _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Posted: Sun Dec 04, 2016 8:43 am Post subject: Re: Weber 40 IDF missing plug? |
Cusser wrote: |
Good job. |
Thanx _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Dec 04, 2016 9:02 am Post subject: Re: Weber 40 IDF missing plug? |
Make your own carb sync/balance tool...
https://www.youtube.com/watch?v=Y_WDF6glD5k
Posted: Sun Dec 04, 2016 9:55 am Post subject: Re: Weber 40 IDF missing plug? |
Thanx , seen that one before ,
i actually made one a while back for a BMW R90.
SBD wrote: |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Wed Dec 07, 2016 3:24 pm Post subject: Re: Weber 40 IDF missing plug? |
Get yourself some JB Weld and mix enough up to do the other plugs or you'll end up losing them as well. Vibration & time are what work them loose. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Posted: Wed Dec 07, 2016 3:58 pm Post subject: Re: Weber 40 IDF missing plug? |
Thanx forum the advice , wil do that _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Posted: Wed Dec 07, 2016 5:08 pm Post subject: Re: Weber 40 IDF missing plug? |
Use some carb spray and Q-tips to clean the areas up before applying the JB Weld. This way it have adhesion. Then allow 16 hours min before your run it so the JB can cure fully. It holds up very well to fuel. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
Posted: Thu Dec 08, 2016 2:12 am Post subject: Re: Weber 40 IDF missing plug? |
WoW i just read up on that jbweld,
That stuff is awesome! _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
