jschwell2 Samba Member
Joined: December 04, 2016 Posts: 3 Location: santa monica, CA
Posted: Sun Dec 04, 2016 7:54 am Post subject: 2002 Eurovan roof leak through rack screws |
Has anyone had leaks through the screws that hold the roof rack rail to the fibergalss pop top? Drips are coming into the van at the black "buttons". Not much water but very annoying. Tried unscrewing but either too tight for me or rusted. Is there a topical solution - silicone, henrys or ?? Does anybody know of a shop in the L.A. area that would tackle either removing and replacing the rack or taking it off and sealing the holes. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Sun Dec 04, 2016 10:38 am Post subject: Re: 2002 Eurovan roof leak through rack screws |
I don't remember a roof rack option when i bought my 2002 - is it aftermarket? _________________ .ssS! |
Posted: Sun Dec 04, 2016 10:42 am Post subject: Re: 2002 Eurovan roof leak through rack screws |
Don't know. Bought mine used with the rack rails already installed. |
Posted: Sun Dec 04, 2016 12:10 pm Post subject: Re: 2002 Eurovan roof leak through rack screws |
I would guess someone used the bolt holes for an aftermarket and didn't seal well. A thin bead of RTV applied around each bolt head with a gloved finger would seal them nicely, though - and no one will know about the aesthetic. _________________ .ssS! |
lifsoncosby Samba Member
Joined: March 30, 2018 Posts: 2 Location: Washington Metro
Posted: Thu Jul 12, 2018 12:01 pm Post subject: Re: 2002 Eurovan roof leak through rack screws |
Yes, Gowesty encouraged the Yamaka racks. Don't do it. Use VBH tape instead. Stronger and wont result in leaks. |
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Fri Jul 13, 2018 12:04 pm Post subject: Re: 2002 Eurovan roof leak through rack screws |
jschwell2 wrote: |
Has anyone had leaks through the screws that hold the roof rack rail to the fiberglass pop top? Drips are coming into the van at the black "buttons". Not much water but very annoying. |
I've sprayed "FlexSeal" clear on areas on my roof that were suspect, after a good cleaning. Seems to be a success. (Same folks who make FlexTape, well known to late-night TV watchers-- like the boat sawed in half and taped back together. And Flex Glue etc.) |
grapedaddy Samba Member
Joined: July 07, 2009 Posts: 107 Location: Abingdon, VA USA
Posted: Fri Jul 30, 2021 4:32 pm Post subject: Re: 2002 Eurovan roof leak through rack screws |
I sprayed the roof area above my leaking poptop latch with clear flexseal out of the can. It didn't go on thin or clear at all. It spewed out pretty think and goopy whitish splotches. It probably stopped the leak (not tested yet), but it looks terrible. I think a careful application of clear silicone caulk touching only the bolt heads as suggested above could have turned out much nicer. Your mileage may vary. _________________ ----
grapedaddy
1971 Westfalia "Buttercup"
2003 Westfalia "Tourmaline" (sold)
2021 MB Metris Getaway “TheDarkSide” |
