Hello from the UK!
Page: Previous  1, 2, 3 ... , 9, 10, 11  Next
MorkC68
MorkC68 is offline
PostPosted: Sun Dec 15, 2019 2:48 pm    Post subject: Re: Hello from the UK! Reply with quote
Davydomes wrote:
Me too! Especially that colour combo.
I was sceptical at first but now we are getting somewhere its starting to look great!
Gusbus; 1973 Kombi
Major; 1977 Westfalia Campmobile
My blog: https://twolatebays.wordpress.com/
MorkC68
MorkC68 is offline
PostPosted: Sun Mar 01, 2020 2:25 pm    Post subject: Re: Hello from the UK! Reply with quote
I cant believe its almost three months since I last updated this thread. I've been busy beavering away getting stuff done.
Got the left hand / drivers cab door rebuilt fully:
When we bought Major, the spare wheel cupboard was missing its correct cover and after some thorough searching, I managed to source one with damaged veneer. This turned out okay after some hard work removing the old veneer:
I'm pleased with how it turned out.
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sun Mar 01, 2020 2:32 pm    Post subject: Re: Hello from the UK! Reply with quote
Next up was to refurbish the wheels. The Gasburners we run with had severely blistered laquer and the tyres needed replacing with van rated 195 / 70 / 15's. The did look nasty:
Some degreasing, sanding and laquering later, they look fine:
Next up, finish off refitting the Madmatz mat set, its only taken 7 years to fit the walkthrough and wheelarch mats!! No rush eh Surprised
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sun Mar 01, 2020 2:43 pm    Post subject: Re: Hello from the UK! Reply with quote
We like to be warm and cozy and the cold steel of the bed base was far from inviting so I added two layer of 6mm thick insulation sheet to cover it well and made a cover for the engine inspection hatch. Should be warm Smile
The plan is to fit solar panels to supply 12v for our fridge and phones / iPads along with the interior lighting so a start was made on the sockets.
Two USB sockets plus a 3-pin audio socket (capable of up to 50V DC) should be okay to start with. I have added a small in-line fuse box with two spare fuse bays for future expansion.
I did tidy the hook up power cable up and route via the correct gland to the incoming power socket
I found the portable storage compartment, which needs working on.
Until the next time....
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Fri May 22, 2020 2:09 pm    Post subject: Re: Hello from the UK! Reply with quote
Last update I had started refurbishing the storage box, which turned out good in the end!
New upholstery, laminate removed and varnished, new trim, sorted.
Whilst we had success upholstering, we did the armrest.
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Fri May 22, 2020 2:15 pm    Post subject: Re: Hello from the UK! Reply with quote
We figured additional storage would be more beneficial to us, I set to and made a little cupboard to fit up in the roof bed space as it probably will go unused.
Fits a treat.
Next up, engine bay.
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Fri May 22, 2020 2:30 pm    Post subject: Re: Hello from the UK! Reply with quote
Time to remove the engine and gearbox, clean everything up in the engine bay area, paint, tidy and sort the motor out.
The engine bay is ditched with 42 years of oil, grime, old underseal and surface rust.
Lots to do
With little effort, good progress was made.
Slow and steady...
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sat Jun 27, 2020 1:38 pm    Post subject: Re: Hello from the UK! Reply with quote
Well, after the last update I must admit to not wanting to attempt the engine bay or knowing where to start.
Start I did, after some hard graft in removing the old rust, underseal and grease / grime, I got there. It looks good!
Underneath the fuel tank
Chassis rail ends
Around the firewall / fuel tank aperture
Light clusters
Left hand battery tray / wheelarch
Gearbox degreased & painted
Gusbus; 1973 Kombi
WildIdea
WildIdea is offline
PostPosted: Sat Jun 27, 2020 9:55 pm    Post subject: Re: Hello from the UK! Reply with quote
Looks bomb proof! Looking nice and clean in there, you wonít regret investing your time in there.
1977 Sage Green Westy
https://www.thesamba.com/vw/forum/viewtopic.php?t=691987
1965 SWR Walk-Through Standard
1960 211 Panel American Camper Conversion
MorkC68
MorkC68 is offline
PostPosted: Sun Jun 28, 2020 3:21 am    Post subject: Re: Hello from the UK! Reply with quote
It was well worthwhile investing the time to do it right, itís paid off!
I will waxoyl or apply something similar to the chassis rail ends, both inside and out, add a bit more protection.
Hope you and the family are safe and well!
ATB Smile
Gusbus; 1973 Kombi
FredH17
FredH17 is offline
PostPosted: Mon Jun 29, 2020 6:02 am    Post subject: Re: Hello from the UK! Reply with quote
Great rebuild ! Once it's ready you will have a lot of fun with it !
MorkC68
MorkC68 is offline
PostPosted: Thu Jul 02, 2020 12:57 pm    Post subject: Re: Hello from the UK! Reply with quote
Thanks buddy Very Happy
We used the bus for four years solid, its seen some adventures. Never let us down either, great memories!
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Tue Jul 28, 2020 1:26 pm    Post subject: Re: Hello from the UK! Reply with quote
Lots of odds and ends done these past few weeks.
1. The gear linkage bushes replaced on the main shift rod.
2. Gear change fork link fitted with new rubber bushes and a solid / bored out centre shaft rather than a badly formed split tube.
3. New fuel flow and return hoses
4. All of the breather hoses replaced
The starter motor was a mess, that has been cleaned up, connections rejuvinated ready for use.
The gearbox is remounted in the bus with fresh oil
Both driveshafts had a good clean up, the rubber boots checked okay and some fresh grease.
The roofbars are under refurbishment now, I have the solar panel monitor to fit & wire in then its Scooby time Very Happy
Gusbus; 1973 Kombi
orwell84
orwell84 is offline
PostPosted: Tue Jul 28, 2020 3:58 pm    Post subject: Re: Hello from the UK! Reply with quote
I have been working in the same area after removing my engine and transmission. I redid my engine bay about 7 years ago but under the gas tank was a nightmare. Your pictures inspire me to keep going. Tired of getting grease in hair.
MorkC68
MorkC68 is offline
PostPosted: Wed Jul 29, 2020 2:10 pm    Post subject: Re: Hello from the UK! Reply with quote
Nice to hear that youve got some inspiration from me, when I say its worth it, it really is!
Good luck, stick with it and do it well, you will be pleased when its done. The area on your bus doesnt look too bad to be fair!
Gusbus; 1973 Kombi
orwell84
orwell84 is offline
PostPosted: Wed Jul 29, 2020 2:56 pm    Post subject: Re: Hello from the UK! Reply with quote
The photo was after the first cleaning. I was pleased with the lack of rust.
MorkC68
MorkC68 is offline
PostPosted: Thu Jul 30, 2020 1:43 pm    Post subject: Re: Hello from the UK! Reply with quote
Happy days! Thats good news, should be easier to sort out Smile
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sun Aug 09, 2020 1:52 pm    Post subject: Re: Hello from the UK! Reply with quote
In view of the Covid situation, past years have seen us grab lots of camping adventures in, Covid stopped all of that in its tracks.
That said, every year a group of us off thelatebay head down for an informal gathering in The Cotswolds for a weekend. This year went ahead, everyone respected social distancing, ensured friends remained safe and we even managed a beer or tow together.
Was a brilliant weekend, superb weather with a superb bunch of friends!
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sun Aug 09, 2020 1:54 pm    Post subject: Re: Hello from the UK! Reply with quote
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Fri Aug 21, 2020 2:24 pm    Post subject: Re: Hello from the UK! Reply with quote
More exploration whilst we have the opportunity.
Derbyshire this time, surrounded by superb scenery.
The location was next to a village called Biggin alongside an old limestone railway, The Tissington Trail. The views from the campsite was amazing, really picturesque.
Gusbus; 1973 Kombi
Page 10 of 11
