Hello from the UK!
chabanais
chabanais is offline
PostPosted: Fri Dec 09, 2016 2:54 pm    Post subject: Re: Hello from the UK! Reply with quote
Tidy motor.
"I spud therefore I yam."
MorkC68
MorkC68 is offline
PostPosted: Fri Dec 09, 2016 3:13 pm    Post subject: Re: Hello from the UK! Reply with quote
The motor started out as an AP series type 4, with a pair of 41 x 34 valve heads, a mate had it tucked away for a rainy day and after a change of plan, it was mine.
It needed a crank regrind and new bearings, which Coolair handled for us along with a new cam, followers and cam bearings.
The motor itself had been poorly maintained and the oil had burned and gummed itself to most of the moving parts:
Sadly both of the heads had seen poor repairs before we got them, they had lots of cracks in each combustion chamber and Stateside Tuning deemed them fit for scrap and returned them to us Sad
MorkC68
MorkC68 is offline
PostPosted: Fri Dec 09, 2016 3:24 pm    Post subject: Re: Hello from the UK! Reply with quote
Onwards and upwards; we made ourselves a cleaning bath at work and set to on soaking the case halves until them where clean, we succeeded!
We went for a set of AA Products 1915 piston and barrel kit, quality looked good, to compliment this, we also went for a pair of AMC heads from VW Heritage
Had the distributor rebuilt
Good to go for a mock up!
MorkC68
MorkC68 is offline
PostPosted: Fri Dec 09, 2016 3:33 pm    Post subject: Re: Hello from the UK! Reply with quote
We're lucky in the fact that we have a Bridgeport Milling Machine with lots of angle plates and tooling, we set to and did the VW oil spray mod to the conrods, as per the tech bulletin
The flywheel is a 228mm one which needed refacing on the clutch face as it had signs of chattering and galling, easily done on our lathe
all trued up using a DTI
MorkC68
MorkC68 is offline
PostPosted: Fri Dec 09, 2016 3:45 pm    Post subject: Re: Hello from the UK! Reply with quote
Before we started to rebuild the motor, we weighed the conrods - it turns out that they have all been weight matched to within 0.1 grams of one another. We used very accurate measuring equipment!
Time to build up:
End float set using a DTI
Deck height was set to 1.52mm on all cylinders, they measured up very good, we were pleased here (the measurement in the image was an example of how to measure for someone)!
Cylinder heads CC'd to 57cc's
MorkC68
MorkC68 is offline
PostPosted: Fri Dec 09, 2016 3:52 pm    Post subject: Re: Hello from the UK! Reply with quote
Heads, pushrods, rocker assemblies fitted
Thermostat fit and connected okay
Built and ready to fit
MorkC68
MorkC68 is offline
PostPosted: Fri Dec 09, 2016 4:09 pm    Post subject: Re: Hello from the UK! Reply with quote
So, the spec is:
1915 type 4
weight matched conrods to within 0.1 grams with the oil spray mod
con rods & pistons measured for length and mated until they measured 86.16mm for #1 and 3 and 86.04 for #2 and #4, as per what the Wilson book describes
Distributer is a Bosch 0231 168 005 SVDA, VW p/n 021-905-205/P
228mm 2.0 flywheel
Weber 34 ICT Carburettors
Vintage Speed Exhaust, twin side oulet
its been rolling road tuned here in the UK and outputs 96bhp at the flywheel!
Heres the full build thread:
http://www.thelatebay.com/index.php?threads/morks-type-4-1800-ap-engine-project.30925/
MorkC68
MorkC68 is offline
PostPosted: Fri Dec 09, 2016 4:35 pm    Post subject: Re: Hello from the UK! Reply with quote
And enjoy! We love getting out and about, lots of places to head to over here, we're fortunate that we are less than an hours drive from The Peak District
On the coast in North Yorkshire
Or camping with a group of friends!
Dans Bus
Dans Bus is offline
PostPosted: Sun Dec 11, 2016 2:59 pm    Post subject: Re: Hello from the UK! Reply with quote
That's a really good write up Mark, well done!!
Tony
MorkC68
MorkC68 is offline
PostPosted: Sun Dec 11, 2016 3:03 pm    Post subject: Re: Hello from the UK! Reply with quote
Tony
Thanks Tony; good to see another latebay.com'er on here!
Gusbus; 1973 Kombi
Major; 1977 Westfalia Campmobile
My blog: https://twolatebays.wordpress.com/
cliveawn
cliveawn is offline
PostPosted: Wed Dec 14, 2016 4:44 am    Post subject: Re: Hello from the UK! Reply with quote
Nice Busses and motor! Another TLB'er here...
Green 78 Westfalia Helsinki,
2056 with 41 x 34 valves,ported heads
Fully balanced
8,5:1CR
JPM Custom made cam
JPM 7075 dual taper pushrods
IDF 40's with 28mm venturi's
Python CSP 42mm exhaust.
115 HP
Daily driver 2012 Touran GT 170 tdi.
''Funny thing about common sense is that its not very common''
Seismic gun mechanic
'77 Westy
'77 Westy is offline
PostPosted: Wed Dec 14, 2016 6:22 am    Post subject: Re: Hello from the UK! Reply with quote
And another TLBer, good to see you here Mark.
MorkC68
MorkC68 is offline
PostPosted: Sat Dec 17, 2016 7:52 am    Post subject: Re: Hello from the UK! Reply with quote
Hiya Clive, good to hear from you!
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sat Dec 17, 2016 7:54 am    Post subject: Re: Hello from the UK! Reply with quote
Hi Geoff, good to see you on here too!
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sat Dec 17, 2016 8:05 am    Post subject: Re: Hello from the UK! Reply with quote
Moving on from our '73, we also own a 1977 Westfalia Campmobile which was imported into the UK from Santa Cruz back in 2011, we called him Major. He has a comprehensive service history, he has been used lots since we bought him.
Here he is when we first bought him home:
He was pretty much original - the upholstery, curtains, mosquito nets, storage box between the seats, table and hook up cable. Also there was a pair of roofbars which need refurbishing. He has never let us down so far which is a testament to being looked after by the previous owners
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sat Dec 17, 2016 8:21 am    Post subject: Re: Hello from the UK! Reply with quote
The original curtains, cab mats and steering wheel needed replacing, Michelle made some curtains up for us
We added an MCJ Products Steering Wheel
And Madmatz cab mats up front
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sat Dec 17, 2016 9:00 am    Post subject: Re: Hello from the UK! Reply with quote
The final additions are a towbar and Gasburner alloy wheels.
We have thoroughly enjoyed getting out and about in Major and have made some great friends too!
On show in Essex, Elemental Show, 2011
Tatton Park nr Manchester
North Yorkshire
Whitby
Charmouth Bay, Dorset
and many more places too
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sat Dec 17, 2016 9:14 am    Post subject: Re: Hello from the UK! Reply with quote
The years have taken a bit of a toll with signs of rust and rotten patches starting to come through, we did a survey of what we could see that needed work, doesn't look much but as we go round sorting the issues found, it could need more.
The areas so far are
Sliding Door
Drivers cab door
left hand battery tray
oil cooler needs sorting & relocating
new front panel
roof needs painting and new seals & canvas
new window seals
Upholstery
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sun Dec 18, 2016 2:14 pm    Post subject: Re: Hello from the UK! Reply with quote
The first place to start was the sliding door, this had a rotten piece at the bottom around six inches long, two inches tall.
We used pieces from the Klokkerholm inner repair panel to make good the inside, overall the rot didn't warrant a whole section.
The outer panel was an Autocraft repair panel, profile matches up with the original one very well.
Gentle skim of filler on the weld, sort the bonding on the inner frame as it had hardened losing the seal to the outer skin.
Time for paint
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Fri Dec 30, 2016 2:12 pm    Post subject: Re: Hello from the UK! Reply with quote
We finished painting the sliding door just before Christmas, the louvre window resealed, nothing much to do today so we refit it Very Happy
Quite pleased with the shut lines, all of the locks work as they should so we popped a new trim panel on and inserted the louvre window.
We're gonna MOT him in the new year so we can move him from the unit to home and back to work on him :thumbsup:
Gusbus; 1973 Kombi
Page 2 of 5
