Hello from the UK!
MorkC68
MorkC68 is offline
PostPosted: Thu Jan 12, 2017 4:18 pm    Post subject: Re: Hello from the UK! Reply with quote
Earlier this week we took the westy for his MOT test; passed okay, advisories include grumbling front wheel bearings, handbrake inefficient and he advised we change the fuel filter.
Next part for attention is the drivers door, the skin has cracked badly in several places:
Its had some form of repair around the mirror' bolt
The bonding on the door braces has gone brittle and broken away and one of the braces is loose inside the frame. It needs sorting!
The plan is to reskin the door, the frame is excellent so we're going to remove the old damaged one, clean up all of the Dinitrol and treat any rust, paint it up etc before welding the new skin on and paint!
Unpicking the spot welds is slow going Sad
Gusbus; 1973 Kombi
Major; 1977 Westfalia Campmobile
My blog: https://twolatebays.wordpress.com/
MorkC68
MorkC68 is offline
PostPosted: Sun Feb 19, 2017 3:11 pm    Post subject: Re: Hello from the UK! Reply with quote
So we started to take the spot welds off the lower half of the door to remove the skin only, we ended up taking the whole outer door skin off as the spot welds had gone all round the top of the window frame. It looks like its been welded before Sad
I think the door has had something happen to it in the past, the bracing inside the door frame was broken off, the hole where the mirror passes through was not how it should be and we need to make some new bits for the brace around the mirror nut Surprised
On a plus side, we got a small crack on the inside welded up, the outer skin fits okay and we treated some rust with Vactan. We just have to rebuild the bracing and get that cleaned and painted up. The door frame itself is mint, just surface rust, no real rot aside of some little bits where spot welds have broke.
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sun Feb 19, 2017 3:16 pm    Post subject: Re: Hello from the UK! Reply with quote
Progress has been slow this past week, been de-sealing, rubbing back, welding and painting the bracing on the door after fixing the mirror nut back into its recess, looks good!
But, so much for our "very good" rust free inner door, part of it is peppered with holes Sad
Luckily Schofields do a repair panel with the correct profile Smile
http://www.alanhschofield.com/ourparts/prod_252712...1105D.html
Whilst this was on order, we applied some more Vactan to the top door frame
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sun Feb 19, 2017 3:19 pm    Post subject: Re: Hello from the UK! Reply with quote
Had a few good sessions on the door and got all of the rotten underside cut out, the inner brace bar cleaned up, rust treated and a coat of paint applied. Progress is good Smile
The Schofield repair section is very good however, the profile on the inside slightly different to the old one, the edge on the new one is sharper, no bother it can be made good!
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sun Feb 19, 2017 3:25 pm    Post subject: Re: Hello from the UK! Reply with quote
The new bit is all welded in place, fits well, the steel didn't bow during welding, which is a plus, to correct the profile on the inside lip, we chopped it out, reshaped it and welded it back in.
I didn't get any photos before a layer of filler was applied to neaten it up, however, we did get carried away, good job its easy sand Very Happy
Whilst we waited for the filler to go off, we checked the fit of the door skin and marked it out for the brace bars
Gusbus; 1973 Kombi
lil-jinx Premium Member
lil-jinx is offline
PostPosted: Sun Feb 19, 2017 8:59 pm    Post subject: Re: Hello from the UK! Reply with quote
Did you just fill that long hole with filler?
1968 Dune Buggy
1974 parts bus
MorkC68
MorkC68 is offline
PostPosted: Sun Feb 19, 2017 11:46 pm    Post subject: Re: Hello from the UK! Reply with quote
No, I realised afterwards we didn't take a photo of the metal welded back in. We reshaped the bend to match the profile on the door and remade it good. The filler was added afterwards.
Ill grab some more images later today and do another update when we have made some more progress
Gusbus; 1973 Kombi
lil-jinx is offline
PostPosted: Mon Feb 20, 2017 8:21 am    Post subject: Re: Hello from the UK! Reply with quote
Great work! On your 73,what is that profile at the bottom of the front doors,I have not seen that before,It looks good.
I just got to get to the UK for a look around.
1968 Dune Buggy
1974 parts bus
cliveawn
cliveawn is offline
PostPosted: Mon Feb 20, 2017 8:28 am    Post subject: Re: Hello from the UK! Reply with quote
Hello mate! Cool busses...
Green 78 Westfalia Helsinki,
2056 with 41 x 34 valves,ported heads
Fully balanced
8,5:1CR
JPM Custom made cam
JPM 7075 dual taper pushrods
IDF 40's with 28mm venturi's
Python CSP 42mm exhaust.
115 HP
Daily driver 2012 Touran GT 170 tdi.
''Funny thing about common sense is that its not very common''
Seismic gun mechanic
notchboy
notchboy is offline
PostPosted: Mon Feb 20, 2017 9:54 am    Post subject: Re: Hello from the UK! Reply with quote
Great job mork! Major looking good aND sorted. Cool
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1974 Westfalia Hardtop Campmobile
1977 Westfalia Camper pop-top
MorkC68
MorkC68 is offline
PostPosted: Mon Feb 20, 2017 1:03 pm    Post subject: Re: Hello from the UK! Reply with quote
the doors are gen. VW ones for the Brazilian watercooled buses, the swage line looks okay as it connects with the lower lip on the front panel Smile
The UK has lots of places to explore in a bus, we love getting out and about Very Happy
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Mon Feb 20, 2017 1:04 pm    Post subject: Re: Hello from the UK! Reply with quote
Hiya Clive, hope alls well with you & the new job is going well!
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Mon Feb 20, 2017 1:08 pm    Post subject: Re: Hello from the UK! Reply with quote
Thanks Jason, we're a long way off being sorted, the front panel needs changing, new battery tray, left hand rear corner and a few more odds and ends!
Gusbus; 1973 Kombi
LazyLightning75
LazyLightning75 is offline
PostPosted: Mon Feb 20, 2017 2:12 pm    Post subject: Re: Hello from the UK! Reply with quote
Wow! That's an impressive amount of work going on. When you're done you really will know your bus inside and out. Looking forward to seeing it all come together.
1975 Riviera 1.8L FI
MorkC68
MorkC68 is offline
PostPosted: Mon Feb 20, 2017 2:15 pm    Post subject: Re: Hello from the UK! Reply with quote
Thanks buddy, we are using what we learned from the restoration of our '73 and putting it to good use here. Its all good fun (he says) Smile
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sat Mar 11, 2017 12:36 pm    Post subject: Re: Hello from the UK! Reply with quote
Bit more progress this past couple of weeks, mostly painting the inside of the door frame ready for welding back up.
cant beat a bit of red oxide
then a good coating of Rustoleum Smile
Finally, we got some bonding on the support brace which holds the mirror in place
fingers crossed we're reskinning the frame next week!
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Wed Apr 19, 2017 3:09 pm    Post subject: Re: Hello from the UK! Reply with quote
Well, the door is almost done. Finally welded back up, filled and a couple of coats of primer layed down, its taken a while but we have got there!
Door skin on and spot welded:
Window Frame welded back on:
Filled and flatted back:
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Wed Apr 19, 2017 3:13 pm    Post subject: Re: Hello from the UK! Reply with quote
And finally some paint!
Top coat Smile
Tomorrow we will pop one final finishing coat of paint on, leave the paint to harden over the weekend in readiness for clear coating.
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sun May 21, 2017 1:40 pm    Post subject: Re: Hello from the UK! Reply with quote
Its been a few weeks since I updated the project, work has got in the way and we have been busy as a result!
Anyway, we got the door finished and the results are good - one final coat of colour and a couple of light coats of clear coat, I'm happy with the outcome!
We have also moved Major from our unit up to the garage for the welding to take place, however, the roof had to be removed to get him inside! Smile
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sun Jun 04, 2017 12:29 pm    Post subject: Re: Hello from the UK! Reply with quote
With the westy moved up to the garage to do the bodywork, we started at the rear left hand corner and tackled the rust bubbles there:
We also found that the rear outer valance has lots of rust pinholes on the top lip:
Lucky for us the inner valance was in excellent condition.
The worst of the rot was confined to a 2" square section with slightly less on the inner d post.
Gusbus; 1973 Kombi
Page 3 of 6
