Hello from the UK!
MorkC68
MorkC68 is offline
PostPosted: Sun Jun 04, 2017 12:40 pm    Post subject: Re: Hello from the UK! Reply with quote
With all of the rotten metal cut away, we could Vactan rust treat any areas hidden away, sort out new metal, get that welded in nicely and painted up ready for the new rear valance.
New section welded into the edge of the rear corner
And finally the new rear valance.
We're pleased with how this has gone, all that remains is a few welds to dress, some etch primer and we're done Smile
Gusbus; 1973 Kombi
Major; 1977 Westfalia Campmobile
My blog: https://twolatebays.wordpress.com/
MorkC68
MorkC68 is offline
PostPosted: Sun Jul 16, 2017 1:49 pm    Post subject: Re: Hello from the UK! Reply with quote
We managed to get the rear valance etch primed followed by a coat of high build primer, that's another little job out of the way, I'm pleased to say!
Our attention is now focused on replacing the front panel, parts of the windscreen lip had bad corrosion, as did the bottom.
Removal of the lights and grill showed up some nasties:
the section where the airbox assembly had a large gap, tapering further apart as it went towards the drivers side
We had suspicions of accident damage.
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sun Jul 16, 2017 1:56 pm    Post subject: Re: Hello from the UK! Reply with quote
As we started to remove the front panel, it became more obvious that something was amiss
the inner windscreen panel was miss shaped and needed replacing but not only that, complete removal of the panel revealed a very badly damaged airbox
it was pushed back considerably, dented and again, we felt needed replacement.
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Sun Jul 16, 2017 2:03 pm    Post subject: Re: Hello from the UK! Reply with quote
The logical thing to do was to source a new airbox, FBI VW came up with one luckily. We stripped the front bare to check for further damage, none was found
The left and right hand A pillars are all good, luckily!
Inner screen panel replaced, the new front panel was used to get the alignment set correctly before it was welded up securely and painted
Front panel rechecked for fitting
hopefully we will be able to weld the airbox up next
Gusbus; 1973 Kombi
Wasted youth
Wasted youth is offline
PostPosted: Sun Jul 16, 2017 10:50 pm    Post subject: Re: Hello from the UK! Reply with quote
That's an impressive amount of work! Cool Are you happy with the way those panels are fitting up? What brand are they?
1968 Double Cab truck, 1973 Auto trans bus, 1978 Auto trans Sunroof bus with A/C and a 1987 Auto trans Westfalia.
MorkC68
MorkC68 is offline
PostPosted: Mon Jul 17, 2017 1:46 pm    Post subject: Re: Hello from the UK! Reply with quote
The rear valance was a superb fit, that was made by Autocraft here in the UK, the inner windscreen repair panel is Genuine VW, quite a good fit but not as good as the original.
The front panel is IGP, it looks good and offering it up, I think we will be fine - trial runs suggest this will be fine.
We know that measure, measure, measure and do one final measure is essential. We rebuilt our '73 kombi a couple of years ago and with the westy, we plan to use lessons learned to do a better, more sympathetic restoration.
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Wed Aug 09, 2017 1:45 pm    Post subject: Re: Hello from the UK! Reply with quote
Got quite a few odds and ends done this past couple of weeks, heated rear window switch replaced and sorted..working as it should now, the wiring had been hidden and the switch removed.
Whilst the Dashtop was off, we repainted it Satin Black, installed a Rev Clock and Oil Pressure gauge, ensured the wiring was nice and tidy in sleeving, nice and neat!
The replacement airbox is from an earlier bay, possibly up to 1975 - the steering column support plate was different, couple of holes drilled to line up with the ones on the airbox and we're sorted and the plate bolted up securely.
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Wed Aug 09, 2017 1:52 pm    Post subject: Re: Hello from the UK! Reply with quote
Got the new airbox mounted and lined up with the inner windscreen panel, couple of runs of weld once it was lined up okay & its looking something like reasonable again. We gave the out of sight areas a good coating of Rustoleum to keep any rusting to a minimum
Front panel is now on and spot welded on the airbox, windscreen lip and bottom lip, lining up very well!
The front panel is all welded up, etch primed, high build primed and the deformation panel has had a coat of Schultz Stone chip protection
We have some seam sealing to do followed by a final coat of high build primer before colour Smile
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Fri Sep 15, 2017 1:22 pm    Post subject: Re: Hello from the UK! Reply with quote
Made a huge amount of progress since I last updated this thread.
The front panel is seam sealed where necessary, painted and clear coated:
The indicators and headlights have been refitted and wired back up, working correctly
Radio aerial fitted and working
Wiper motor refitted and the associated seals fitted, washer jets reconnected.
Fresh air flaps refitted, linkage set up okay
Fly screen and front grill back on
Next up, refit the dashtop and windscreen/wipers.
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Wed Sep 27, 2017 1:36 pm    Post subject: Re: Hello from the UK! Reply with quote
Made some really good progress this past couple of weeks, the front end is pretty much complete aside of fitting a VW emblem and the front bumper (which can wait till its been resprayed).
The dashtop and vents have all been refitted along with wiring up an oil pressure gauge and rev counter. Grab handle and padded top cleaned up, refitted & tightened up snug Smile
The windscreen has been refitted successfully as have the wiper arms & blades
Our next section to work on is the left hand battery tray, which needs replacing as the PO cut a hole in it to allow a remote oil cooler to get air blown over it
Gusbus; 1973 Kombi
KentPS Premium Member
KentPS is offline
PostPosted: Wed Sep 27, 2017 4:32 pm    Post subject: Re: Hello from the UK! Reply with quote
That's quite a facelift you've accomplished in a relatively short amount of time. Your bus is looking great! Keep up the good work. And thanks for posting updates on the progress.
-Kent-
1976 Riviera, my 1.7l FI chrome yellow VAN - "Chloe"
--> Whatever you do, have fun doing it! Smile
WildIdea wrote:
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. Its.... like driving a celebration!"
Wasted youth
PostPosted: Wed Sep 27, 2017 7:10 pm    Post subject: Re: Hello from the UK! Reply with quote
That really is a lot of work! You should get many great years of service out of that. Very inspiring!
Question Did you replace the white plastic air vent hinges on the two fresh air flaps? Mine should be replaced, but I have not looked at a source yet.
Sloride
Sloride is offline
PostPosted: Thu Sep 28, 2017 4:16 am    Post subject: Re: Hello from the UK! Reply with quote
Looks good and all done in that small garage. I thought I was the only one working under those constraints.
1972 Westfalia - 1.8 VW in-line h2o conversion
Ottawa, Ontario, Canada
Link to the engine swap:
http://www.thesamba.com/vw/forum/viewtopic.php?t=565304&highlight=
MorkC68
MorkC68 is offline
PostPosted: Thu Sep 28, 2017 4:48 am    Post subject: Re: Hello from the UK! Reply with quote
Thanks Kent, we had worries when we revealed the damage to the front however, we took our time, measured everything several times over and luckily, have our '73 for reference.
We have quite a lot to do yet, work wise Smile
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Thu Sep 28, 2017 4:50 am    Post subject: Re: Hello from the UK! Reply with quote
Thanks dude, we are hoping for a good few years out of the bus, we've had him six to date & used it a heck of a lot! Notchboy's westy got me going on the restoration as the bus had been parked in the garage doing nothing for a couple of years. It was a shame it was sat!
The plastic air vent hinges where okay, just a smear of lube on them and all was well, no wear present.
I don't know who may have any, a breaker I guess
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Thu Sep 28, 2017 4:52 am    Post subject: Re: Hello from the UK! Reply with quote
I can be cramped in there, at times, we are in the process of moving house to one with a big garage (the one in the photo's is at my parents). We will have a bit more room to work with Smile
Gusbus; 1973 Kombi
tommu Premium Member
tommu is offline
PostPosted: Thu Sep 28, 2017 7:07 pm    Post subject: Re: Hello from the UK! Reply with quote
That drive looks pretty steep too. A worry when you're going for a test drive. Embarassed
'71 Ghia
'76 Bay
MorkC68
MorkC68 is offline
PostPosted: Fri Sep 29, 2017 4:43 am    Post subject: Re: Hello from the UK! Reply with quote
The steep drive is temporary, a flat drive beckons! But not till March 2018 Smile
We keep our fingers crossed and hope the brakes dont fail Laughing
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Fri Oct 27, 2017 1:54 pm    Post subject: Re: Hello from the UK! Reply with quote
The battery tray is now done, went really well I'm glad to say.
Tack welded in place to check alignment.
Welded up and seam sealed.
When the engine bay gets repainted, we will attend to the battery tray & paint in body colour.
Gusbus; 1973 Kombi
MorkC68
MorkC68 is offline
PostPosted: Fri Oct 27, 2017 1:59 pm    Post subject: Re: Hello from the UK! Reply with quote
With no particular order in how we are tacking the various sections of the bodywork etc, we moved back up front to tackle the cab floor.
The swivel base needed removing, degreasing and freeing up. We did find two little areas behind each seat belt mount which had rusted through, noting too big, 25mm x 25mm at most.
Left hand side
Right hand side
The cab floor is in great condition, surface rust only. This has been cleaned up, Vactan treated and red oxide painted
The cab floor has got colour on it, I'm just waiting for it drying Smile
Gusbus; 1973 Kombi
Page 4 of 5
