Jradical2006 Samba Member
Posted: Thu Dec 08, 2016 6:02 pm Post subject: Rubber floor for Vanagon |
Anybody know if there is a rubber floor available for a 91 vanagon that doesn't only fit models with the camper set up in the back? |
danfromsyr Samba Member
Posted: Thu Dec 08, 2016 6:53 pm Post subject: Re: Rubber floor for Vanagon |
Yes
for front or rear.
I presume rear
the last model year base models came with a full rubber rear mat.
uncommon this side of the pond but there are ones out there..
inquire directly to the big vanagon parts players.. and don't expect it to be cheap or easily shippable. _________________
Abscate wrote: |
getset Samba Member
Joined: March 07, 2005 Posts: 437 Location: PNW | OLY
Posted: Thu Dec 08, 2016 7:07 pm Post subject: Re: Rubber floor for Vanagon |
The L series had nice mats in the rear. Two pieces of rubber which overlapped each other. I preferred it to the carpet. Recently saw a fellow with this in his van.
https://www.amazon.com/IncStores-Premium-Durable-C...r+roll+mat
It was pretty nice,and it comes in a variety of colors. _________________ 87 Syncro sunroof w/ 2.5 Subaru.
2015 VW golf TDI
Bikes, KTM motorcycles, sailboats, and busted knuckles. |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4536 Location: Arizona Highways
the short answer is no.
the long answer is that some euro-spec (base and/or commercial models, i'm guessing) came with rubber mats throughout the van.
i guess it was on some US base models but they are hard to find, expensive and have all different manners of cut outs for the different seating arrangements.
so finding the one that fits your van is like looking for sasquatch.
i thought about sourcing some kind of industrial rubber and using the carpet as a pattern for the cut outs.
i've seen horse mats and truck bed mats used: they off-gas and smell like shit.
good luck and let us know if you come up with something.
i hate the carpet too. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
E1 Samba Member
Joined: January 21, 2013 Posts: 6543 Location: Westfalia, Earth
Posted: Thu Dec 08, 2016 7:24 pm Post subject: Re: Rubber floor for Vanagon |
Hey, that's pretty cool -- Thanks for the link! |
Posted: Thu Dec 08, 2016 7:44 pm Post subject: Re: Rubber floor for Vanagon |
Thanks for the replies! I will prob use that link to order a floor not looking to search and overpay just to have the factory euro floor. It's all good I think I can make a nice floor out of the black rubber in that link. Thanks! |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Thu Dec 08, 2016 8:20 pm Post subject: Re: Rubber floor for Vanagon |
I was in a rush to get rid of some old house carpet and put some kind of flooring down in mine, so I bought this commercial floor mat at home depot:
http://www.homedepot.com/p/TrafficMASTER-Black-48-...498901-_-N
When that link eventually dies - it's a 48"x72" recycled rubber mat by Traffic MASTER
It could be about an inch wider (49-50") but it's fine for now. I trimmed about 10" off one end.
It's recycled rubber, so there's a little bit of a smell, but it's not bad and I don't notice it very often. I went around a corner too quick and my small cooler tipped over and all the water spilled out, but cleanup was easy. I like the padded feel of the rubber too - it's a good compromise between hard plastic / wood laminate and carpet.
Here's a poor photo, and one to show the texture.
alijonny Samba Member
Joined: November 01, 2007 Posts: 328 Location: Des Plaines, IL
Posted: Fri Dec 09, 2016 7:38 am Post subject: Re: Rubber floor for Vanagon |
Don't rake me over the coals for this, it was before I knew their value...
I cut my rear two piece rubber mat down to fit Westy parts into my syncro...While we are admitting things, I also cut down a weekender foam to fit with the rear cabinet. _________________ 1965 Beetle
1990 Syncro Westfalia
1983 Westfalia |
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Fri Dec 09, 2016 9:26 am Post subject: Re: Rubber floor for Vanagon |
Made my own. Cut to fit. It does not actually come with the wheel well cutouts shown in the photo. One side is smooth and the other has raised bumps, which I put "down" for better air circulation under the mat.
https://www.summitracing.com/parts/lrv-6898d
That's my review in the ad. _________________ Cheers!
-Karl
'84 GL with 2001/2004 Subaru 2.5L |
bluebus86 Banned
Posted: Fri Dec 09, 2016 11:39 pm Post subject: Re: Rubber floor for Vanagon |
yes air circulation is important under a rubber matt. spilled drinks, window leaks, wet shoes etc... can lead to water being trapped under a rubber matt, where it wont dry out for a long long time, potentially causing floor rust. if you use a solid rubber matt, lift them out ever now and then and check for moisture. if you have moisture build up, tkae steps to prevent its reoccuranace. the old microbusses had rubber matts and many got floor rust when water was allowed to get under them, left open windows or failed weather stripping can add to this issue. use care. |
Posted: Sat Dec 10, 2016 4:58 pm Post subject: Re: Rubber floor for Vanagon |
Forthwithtx wrote: |
That's my review in the ad. |
Here's a remnant piece:
-Karl
SteveVanB Samba Member
Joined: June 01, 2008 Posts: 1645 Location: This side of Daytona
Posted: Sat Dec 10, 2016 6:51 pm Post subject: Re: Rubber floor for Vanagon |
Fwiw, the 91 i just picked up has the full rubber "carpet". Its a base model with jump seats. The fabric used on the seats is quite different than what im used to. It has ac and the z-bed too. No opening quarter windows in the doors though. _________________ 91 CARAT |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Sat Dec 10, 2016 7:37 pm Post subject: Re: Rubber floor for Vanagon |
SteveVanB wrote: |
Fwiw, the 91 i just picked up has the full rubber "carpet". Its a base model with jump seats. The fabric used on the seats is quite different than what im used to. It has ac and the z-bed too. No opening quarter windows in the doors though. |
That is an "L" model, an unusual kind of base model with european style fabric. Most people prefer the carpet versions with more plush fabrics while the utilitarian interior is very easy to clean. |
Posted: Fri Dec 16, 2016 5:07 pm Post subject: Re: Rubber floor for Vanagon |
After starting this thread I took a look at the two piece rubber floor that came with my van. It was all cracked and splayed open where all the bolt up holes are and where it had been cut to accommodate the heater. I decided to try to fix it up with tech bond which is essentially super glue on steroids. This stuff is incredible I highly recommend it. Well I'm stoked with the results I think the floor looks almost like new. I fixed up my front floor mat with the same stuff and got the same results even though that was badly damaged and the repair seams were on multiple curves. Can't speak highly enough of tech bond!
[/img] |
E1 Samba Member
Posted: Fri Dec 16, 2016 5:50 pm Post subject: Re: Rubber floor for Vanagon |
Jrad, what does that weigh? |
Posted: Fri Dec 16, 2016 6:33 pm Post subject: Re: Rubber floor for Vanagon |
Both pieces together Are probably about 25-30lbs |
vanagon1991 Samba Member
Joined: August 18, 2007 Posts: 152 Location: Spring Grove, IL
Posted: Sat Dec 17, 2016 9:52 am Post subject: Re: Rubber floor for Vanagon |
yea, I used gym mat that i bought at local home depot. I laid lath below first to level floor (cheap and perfect thickness). Spot siliconed in place in case I wanted to remove in future. Ran mat up under seat to quite engine noise as well. I have a subaru conversion so figured I could afford the extra weight. But probably pretty close to stock mat.
[/img] _________________ 1991 Tornado Red Vanagon Carat
(2003 Subaru 2.5 conversion/Smallcar kit) |
vanonimous Samba Member
Joined: October 19, 2013 Posts: 362 Location: Burien, Center of the Universe
Posted: Tue Dec 27, 2016 5:13 pm Post subject: Re: Rubber floor for Vanagon |
I am curious if US market base model 1991 Vanagon that came with rubber floor/jump seats is considered GL model or does it have different designation? _________________ If happiness is being a mechanic, owning a Vanagon is nirvana.
Lighting upgrades: https://www.thesamba.com/vw/forum/viewtopic.php?t=578291 |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Tue Dec 27, 2016 7:12 pm Post subject: Re: Rubber floor for Vanagon |
vanonimous wrote: |
I am curious if US market base model 1991 Vanagon that came with rubber floor/jump seats is considered GL model or does it have different designation? |
They were the end of production, assembled in Graz.
Check out this thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=339351&highlight=graz++rubber _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Posted: Tue Dec 27, 2016 9:58 pm Post subject: Re: Rubber floor for Vanagon |
vanonimous wrote: |
L model.
The GL is pretty nice while the L is a base model. |
