Hand Crank Nut
Page: Previous  1, 2, 3
ldj1002
ldj1002 is offline
PostPosted: Sat Mar 18, 2017 3:08 pm    Post subject: Re: Hand Crank Nut Reply with quote
I have the nut modified and setting on the bolt. I have another bolt ordered and when it comes I'll weld the nut to that bolt. I'll make video cranking it.
ldj1002
ldj1002 is offline
PostPosted: Mon Mar 20, 2017 1:26 pm    Post subject: Re: Hand Crank Nut Reply with quote
I have the hand crank finished. See video at youtube link below.
Is there a way to post video here like a image?
https://www.youtube.com/watch?v=uFEVNL9Je7w
Al Capulco Premium Member
Al Capulco is offline
PostPosted: Mon Mar 20, 2017 1:49 pm    Post subject: Re: Hand Crank Nut Reply with quote
Good job, great looking bib overalls. You may want to tighten your fan belt.
sam_w
sam_w is online now
PostPosted: Tue Mar 28, 2017 8:34 pm    Post subject: Re: Hand Crank Nut Reply with quote
What is the correct torque for the crankshaft nut?
63 singlecab
73 thingster
PostPosted: Tue Mar 28, 2017 8:45 pm    Post subject: Re: Hand Crank Nut Reply with quote
29-36 ft lb for the crank shaft pulley bolt
PostPosted: Fri Mar 31, 2017 4:08 pm    Post subject: Re: Hand Crank Nut Reply with quote
Happen to find an original spring washer and "starting Claw" in the garage today. Inside diameter is about 25mm.
Page 3 of 3
