Trevor P Samba Member
Joined: January 21, 2004 Posts: 863 Location: Saskatoon, SK, Canada
Posted: Fri Dec 09, 2016 11:48 am Post subject: 40hp and FI exhaust valves |
Can't locate a set of new 40hp exhaust valves at the moment due the suppliers I normally use being out of stock right now
Has anyone run the later FI 1600 30mm exhaust valves in a 40hp head? Other than reaming the guides for the 9mm stems; will they work? _________________ 53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Fri Dec 09, 2016 12:17 pm Post subject: Re: 40hp and FI exhaust valves |
wolfsburg west has them in stock. i think you can run the FI one's ? just replace the guides. more work to ream them ? _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Fri Dec 09, 2016 12:34 pm Post subject: Re: 40hp and FI exhaust valves |
Hold up the 40 hp valves and compare them with the 9mm valves- do you think they would flow the same- _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
diablosandwich Samba Member
Joined: January 15, 2012 Posts: 469 Location: Illinois
Posted: Fri Dec 09, 2016 5:22 pm Post subject: Re: 40hp and FI exhaust valves |
williamM wrote: |
Hold up the 40 hp valves and compare them with the 9mm valves- do you think they would flow the same- |
I don't have any FI ones here to compare to. _________________ 53 Canadian standard oval
56 Wolfsburg PG/SG
70 911T
91 Westy |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
Posted: Sat Dec 10, 2016 8:12 am Post subject: Re: 40hp and FI exhaust valves |
Trevor P wrote: |
williamM wrote: |
I don't have any FI ones here to compare to. |
at the time those were invented(read- used by vw)- VW was trying to meet emissions in the US that was going to put them out of the air cooled business.
SO they needed to run lean -which raised temps- all good for emissions- but the valve heads kept falling off.
in an effort to solve this they combined all the best technology- that is sodium filled stelite heads on big stems.
While they worked for the most part- they sure fill the hole. _________________ some days I get up and just sit and think. Some days I just sit.
