vw moses Samba Member
Joined: April 17, 2012 Posts: 213 Location: independance,louisiana
Posted: Fri Dec 09, 2016 8:50 pm Post subject: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
wondering what the diffrence accross the case (valve cover to valve cover)
would be, as compared to my stock 1600 width now. _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
convertable-beetle-w/bugspray & screamer dist.(019) gone
"Where There's a Will There's a Way"
63 one of a kind beetle. 57 dash,double rear window--sweet! |
SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Fri Dec 09, 2016 9:12 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
my math says about .8" wider is a good guess. Assuming B stroke Pistons. _________________ Rides:
300HP 900lb turbo VW rail 18/15 travel
Never ending jeep/rzr hybrid build!
http://www.thesamba.com/vw/forum/viewtopic.php?t=546712 |
Posted: Fri Dec 09, 2016 9:26 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
is that about a 1/4 "or 1/8"?
i will use the b pc's
that seems not too much. which is good. _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Fri Dec 09, 2016 9:41 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
vw moses wrote: |
that seems not too much. which is good. |
.8" would be a strong 3/4" |
maui Samba Member
Posted: Fri Dec 09, 2016 9:52 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
Almost 1/2inch each. side. |
Posted: Sat Dec 10, 2016 9:31 am Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
very good, should of known that measurement.
good info. if i build that combo it won't be "that" bad fitting in mtr. compartment. Thanks! _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Sat Dec 10, 2016 9:48 am Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
There are always C height pistons if you need closer to standard width. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Sat Dec 10, 2016 10:06 am Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
Sweeet! Build it!!
Let us know the progress! _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Sat Dec 10, 2016 11:04 am Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
Just completed one. 1/2" per side.
Longer cyl's.
Longest Scat PR tubes
Longest everything.
Cyl tins need spacers.
Fan shroud needs widening.
It seemed like it would never end.... |
Posted: Sat Dec 10, 2016 12:20 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
i was looking at the Rod Ratios for different rod length w/crank strokes(page 34 in keith seume engine interchange manuel)
and with the 86mm crank. w/5.7"rods was 1.68.
within the reconized range of 1.65-1.70 according to some performance builders.
that sastic swayed me from 78mm w 5.7 witch is in 1.85 range
so i'm entertaining a 86x94 w/5.7 mtr. _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Sat Dec 10, 2016 1:38 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
crank center to piston top
half stroke plus rod plus pin height
stock34.5+137+39.5 =211
you43+146.5+35=223.5
223.5-211=12.5 more
so, "width" piston top to piston top
12.5x2=25mm aka .98 inches
86 stroke you need extra long cylinders
but you might use stock cylinders if you can get a "c-piston"
if your just doing a rod ratio experiment why not
80 and 5.325 rod?
82 and 5.4 rod?
84 and 5.5 rod? |
mark tucker Samba Member
Posted: Sat Dec 10, 2016 1:48 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
go with shorter pin hight. my 86 with 5.6 is short so... those 5.6 rods will probably go in to my 84 stroke and 5.7's in the 86. there are many diferent pistons with many diferent hights and diferent dishes or ft these days.and when you buy them for a v8 instead of a vw....there cheep. manley, diamond, dss,mahle motorsports and more. |
jpaull Samba Member
Posted: Sat Dec 10, 2016 2:04 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
vw moses wrote: |
so i'm entertaining a 86x94 w/5.7 mtr. |
This is very cool your looking into all of this. Both of these engine sizes are gonna work and The engine size difference will make more power simply cause its so much bigger 86 VS 78.
Picking what Rod Ratio is "ideal" or "better" is like picking who has the best Rifle Caliber. Everyone has there favorite.
Also keep in mind, Every other engine in the word has limits how far they can go, as they have engine blocks that don't have removable cylinders. So all them V8 engines have to move the piston pin so far up the piston its about to pop out the top as they scrape the bottom of the barrel of their tricks to get a slightly better rod ratio.
But with VW's, we have more freedom.
I would chose 1.85 over 1.65 anyday. Slower Piston speed, longer dwell time at top dead center to me is more horsepower and longer engine life, etc.
But I definitely build my sniper rifle much different then everyone else. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Posted: Sat Dec 10, 2016 2:16 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
as I recall my old v8 with 84mm stroke had...6.123 rod length...worked pretty good. my 4.5" stroke v8 has a 6.535" crower billet rod ( as my old brain recals) ...it works pretty good too.the biger the engine the less it matters for a power stand point. more of a on the shelf thing and piston combo/weight thing. but that was big motors...these arnt big motors. even though I like the longest rod I can stuff in there....withen reason. |
jpaull Samba Member
Posted: Sat Dec 10, 2016 2:57 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
mark tucker wrote: |
That's Cause your a Mopar guy, they have killer Rod Ratios to start with _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
DeathBySnuSnu Samba Member
Posted: Sat Dec 10, 2016 3:50 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
I was a mopar guy back in the day and usta swear by the long rod theory. But now a days I dont find a lot of difference. Yes there is a difference but it is hard to quantify.
I will say this. A short rod motor seems to be less picky about being over cammed. Where a long rod is more specific and less forgiving on the cam grind. |
modok Samba Member
Posted: Sat Dec 10, 2016 5:07 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
Bingo
long rods will give you less side load on the piston,
and better if headflow is limited BUT
Today oil is better, pistons are better, and cnc heads that flow huge are affordable. Not much holding you back |
Posted: Sat Dec 10, 2016 7:07 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
i'm thinking jaycee cut to length cylinders w/wisco pistons
set the deck that way. not quite sure of how to measure barrel length.
during mock up i'd need a 94 barrel to see how much the piston would stick out @t.d.c.
my goal is a high torque low rev. beast. of a motor. _________________ Youtube@vw moses
73 thing-gone
66 beetle-gone
62 beetle-gone
57 beetle-gone
modok Samba Member
Posted: Sat Dec 10, 2016 10:27 pm Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
No need to assemble it, just measure the parts and use math.
That's how the whole rest of the wold does it, seems to work |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Sun Dec 11, 2016 9:18 am Post subject: Re: how wide will mtr. grow with 86mm crank-5.7rods compared to 1600 |
1/2" wide per side doesn't seem like much to fit in until you try to fit it in there.
I have a 2387 with 5.7 rods in my sandrail. The tins fit so bad, the extra width is huge. There are half inch spacers between the shroud and the cylinder tins.
To fit this engine into a full bodied car, I could see valve cover clearance to the body being a huge deal, after trying to figure out how to get the cylinder tins to fit within the body and engine seal.
It can be done, and people have done it. Just be ready for some real time spent making it work _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
