Duncan67KG Samba Member
Joined: August 09, 2015 Posts: 33 Location: Southern California
Posted: Mon Dec 04, 2017 9:31 pm Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
I had problems with the spring hitting the stack on my 48 IDAs with tall manifolds and opted to remove the springs and go with the gas struts.
Duncan |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Sat Dec 09, 2017 7:18 pm Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
Thanks Duncan, I was wondering if I might need to go that route as well since I have the dual carbs. Can you tell me the length and pound pressure on the struts, and where you ordered them?
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Posted: Sat Dec 09, 2017 7:26 pm Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
Since a few regulars are checking my page, I wanted to throw these pics up looking to see if anyone can identify this part. Found it in my box of pieces, but have no idea what it is. Posted to the "what part is this" section, but no answers, any help? Looks like some type of cable brace but not sure.
2012 Passat-Sold
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13957 Location: Southampton U.K.
Posted: Sun Dec 10, 2017 12:03 pm Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
rbsurfguy wrote: |
Jeff |
Hi Jeff, I ordered the parts from McMaster-Carr the part numbers are listed below. I initially used the 20lb struts but when we added an aluminum panel to the inside of the lid, I had to upgrade to 30lb struts which work great.
I borrowed the idea from Shrrock in the "How to" section of the stickies, he has great installation instructions. (Sorry I can't figure out how to attach the link)
_________________ Duncan
1967 Ghia Coupe |
Posted: Sun Dec 10, 2017 8:23 pm Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
John Moxon wrote: |
rbsurfguy wrote: |
Since a few regulars are checking my page, I wanted to throw these pics up looking to see if anyone can identify this part. Found it in my box of pieces, but have no idea what it is. Posted to the "what part is this" section, but no answers, any help? Looks like some type of cable brace but not sure. |
Looks like the top end of the fuel cap release cable.
https://www.karmannghia.com/Release-Cable-Fuel-Filler-Flap/item/141-809-939 |
Thank you Mr. John, that looks exactly to be the part that mounts up near the fuel flap for the cable. The knowledge here is outstanding!!!! _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
Posted: Sun Dec 10, 2017 8:36 pm Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
Duncan67KG wrote: |
rbsurfguy wrote: |
Jeff |
I borrowed the idea from "Shorrock" in the "How to" section of the stickies, he has great installation instructions. (Sorry I can't figure out how to attach the link) Moderator edit: Shorrock's Gas Strut Solution |
Thank you again Duncan, appreciate you posting the part numbers. I believe that is the same company I was looking at for these parts. No worries about the Strut stickie, I've read through it a couple of times, and will surely read through it again so I can get it right if I go this route. Your ride looks sweet and the engine area is nice and clean.....of course that's probably before you've driven 1000's of miles on it! Thanks again. _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
74 Thing Samba Member
Posted: Thu Dec 14, 2017 7:24 pm Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
Thank you Sir, I like this idea as well, simple and low profile. Will definitely consider going this route should I have the clearance problem with my springs. So many choices of things, but glad this forum exists to learn from the experiences of others! _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
Posted: Tue Dec 19, 2017 3:00 pm Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
What happened to the engine? |
Posted: Mon Mar 26, 2018 12:53 pm Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
Fixing stuff
Adding stuff
Trying to identify stuff
Keeping busy getting everything shiny so I can reassemble. Come on Painters, I need my GHIA home!! _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
Posted: Fri May 18, 2018 6:19 am Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
For those following my build, just got these photos from my painter...looks awesome so far:
The actual color is a dark Burgundy. Since we haven't had sun lately in VA, these were taken inside out of the rain, so the color looks dark.
A few more days to wait for undercoating and attaching all the opening/closing parts, and I should have it back in a couple weeks.....Can't wait!! _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
xzener Samba Member
Posted: Fri May 18, 2018 7:12 am Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
Looking great Jeff! _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Fri May 18, 2018 7:31 am Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
rbsurfguy wrote: |
dark, ... and shiny as heck!
Looking great so far. |
Posted: Sat May 19, 2018 3:30 am Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
Thanks guys, chomping at the bit to get it home and start to reassemble after 11 years! Trying to go through my mind where to start.
I think soundproofing, Fatmat/Dynamat first, and then running the wiring, that should take me several days and allow me to introduce myself again. _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
Posted: Tue May 22, 2018 5:17 am Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
Received my Headlight Relay and Hard Start Relays made by Jay Brown, advertises in the classified ads, thatvwbusguy. He was very cool to work with and will design the relays with the length of wire you want and the connectors you need at no additional price. Very solid looking and professionally done. You can buy each relay separate, or he has a combination price for both together.
I also received my electronic Fuel Pump Controller from Revolution Electronics. According to their site, this will help regulate the fuel and when connected to the Tach or directly to the coil, will shut off fuel if in an accident or when the motor is not running, a definite safety feature.
Can't wait to install and upgrade my rebuild and bring it up to date electronically. _________________ 1971 Ghia convertible (Body off rebuild)
2012 Passat-Sold
Cliff@BrownBags Samba Member
Joined: June 14, 2007 Posts: 649 Location: glen burnie maryland
Posted: Wed May 23, 2018 5:40 am Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
Looks awesome _________________ its not about what you say you will do oneday, its what you do today that actualy means something. |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Wed May 23, 2018 6:47 am Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
NOVA Airhead wrote: |
Not sure if you have seen these links but some good information here for the engine lid: |
I have and thank you Sir. I have read all the threads and even chatted with those who have gone through the strut installation process and will consider going this route when I get the engine back in, or just the clips that lock in place. Appreciate the links as always.
2012 Passat-Sold
Posted: Mon Jun 25, 2018 5:16 am Post subject: Re: Jeff's 71 Vert Restoration/Reassembly |
Finally safely home, thinking of where to start, lots of boxes of parts, all clean, separated, and waiting to be put into their proper place.
2012 Passat-Sold
