ClareSutton Samba Member
Joined: December 05, 2004 Posts: 466 Location: Sarnia Ontario
Posted: Mon Dec 12, 2016 3:51 pm Post subject: Vanagon rims VS Bay Window rims |
Does anyone know if bay window van rims (5 stud) would fit on an '84 Vanagon? I'm driving 3.5 hours to pick them up so I need to be sure. I'm not quite 100% on this. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Dec 12, 2016 4:12 pm Post subject: Re: Vanagon rims VS Bay Window rims |
Identical rims from about '69 to '91...
_________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Mon Dec 12, 2016 4:34 pm Post subject: Re: Vanagon rims VS Bay Window rims |
When I needed a spare on the road the bay I looked at had steelies with 5" wide rims and the Vanagon steelies are 5.5". Bolt circle and diameter are right but they are narrower. _________________ '87 Westy in Wolfram Grey Metallic |
danfromsyr Samba Member
Posted: Tue Dec 13, 2016 7:14 am Post subject: Re: Vanagon rims VS Bay Window rims |
from 1971-1991 were 5x112 (small 5) pattern.
1970 and down were wide 5.
dhaavers wrote: |
Abscate wrote: |
Posted: Tue Dec 13, 2016 7:18 am Post subject: Re: Vanagon rims VS Bay Window rims |
Thanks for the information, guys. Really appreciate it. |
kamzcab86 Samba Moderator
Posted: Tue Dec 13, 2016 9:05 am Post subject: Re: Vanagon rims VS Bay Window rims |
1980-1991 Vanagon, steel:
5.5J x 14
ET39 offset
5x112 bolt pattern
(Ball seat front lug bolts, M14x1.5x19)
1986-1991 Vanagon, alloy:
6J x 14
ET30 offset
5x112 bolt pattern
(Conical seat front lug bolts, M14x1.5x32)
Vanagon Syncro, steel with 205/70 tires
6J x 14
ET30 offset
5x112 bolt pattern
Vanagon Syncro 16, steel
5.5J x 16
ET35 offset
5x112 bolt pattern
Vanagon, South Africa "Rhein" alloy
6.5J x 15
ET30 offset
5x112 bolt pattern
1971-1979 Bay Window:
5.5J x 14
ET39 offset
5x112 bolt pattern
1968-1970 Bay Window:
5J x 14
ET39 offset
5/205 bolt pattern _________________ ~Kamz
2016 Golf GTI S
Posted: Tue Dec 13, 2016 10:44 am Post subject: Re: Vanagon rims VS Bay Window rims |
Excellent!! Thank you kamzcab86. |
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Tue Dec 13, 2016 6:32 pm Post subject: Re: Vanagon rims VS Bay Window rims |
kamzcab86 wrote: |
5.5J x 14
ET39 offset
5x112 bolt pattern
(Ball seat front lug bolts, M14x1.5x19) |
Wheel fitment rule of thumb is 30ET. Coming from someone that's has not run stock steelies on my van. _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer |
fredybear Samba Member
Posted: Sun Jun 04, 2023 11:44 am Post subject: Re: Vanagon rims VS Bay Window rims |
Bringing this back up. I found no pics of rims for differences.
Bus on Left. Vanagon on Right. Correct? Is there a name for that pattern?
I did not know I had 4 vanagon rims. The bus rim was in the spare tire hole. The search started and this topic popped up with no pics.. _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
tjet Samba Member
Posted: Sun Jun 04, 2023 12:07 pm Post subject: Re: Vanagon rims VS Bay Window rims |
Those are '71 only 14x5.5 rims. Slightly thicker then later wheels. I put a set on my '85 before I sold it.
markswagen Samba Member
Joined: January 28, 2018 Posts: 1039 Location: san diego
Posted: Sun Jun 04, 2023 4:55 pm Post subject: Re: Vanagon rims VS Bay Window rims |
l always thought with the round center hole, they were syncro wheels.
l had a bunch of bays in england, they ALL had the centers the same as the wheel on the right of fredybears picture, _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Sun Jun 04, 2023 10:35 pm Post subject: Re: Vanagon rims VS Bay Window rims |
markswagen wrote: |
l always thought with the round center hole, they were syncro wheels. IF they are 6" wide.
l had a bunch of bays in england, they ALL had the centers the same as the wheel on the right of fredybears picture, |
_________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Mon Jun 05, 2023 8:48 am Post subject: Re: Vanagon rims VS Bay Window rims |
I found the stamp date.
4/77 1977 Bus?
Since Vanagons were born in 1980. Correct? _________________ 1955 Beetle
1960/63 Beetle
1968 Beetle
1971 Beetle
1973 Beetle
1971 Bus |
GoEverywhere Samba Member
Joined: December 13, 2020 Posts: 516 Location: Portland, OR
Posted: Mon Jun 05, 2023 8:55 am Post subject: Re: Vanagon rims VS Bay Window rims |
fredybear wrote: |
4/77 1977 Bus?
Since Vanagons were born in 1980. Correct? |
Technically you could find Vanagon and Vanagon parts with 1979 production dates if they were an early 1980 Vanagon(My '80 has a '79 production date) but yeah, 1980 was the first MODEL YEAR for the Vanagon.
Either way, if its dated '77 its a bus wheel, not Vanagon. |
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Wed Jun 07, 2023 2:24 pm Post subject: Re: Vanagon rims VS Bay Window rims |
I have a very original 86 Syncro tin top 7 passenger. Factory window sticker says 205/70 tires and steel wheels with wheel covers. I am the second owner. When I purchased it had 6 wheels. All are 5.5x14. Does anyone know the source of the 6 inch wide Syncro wheel information? _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
tjet Samba Member
dart330 Samba Member
Joined: July 19, 2004 Posts: 454 Location: Houston, TX
Posted: Thu Jun 08, 2023 6:47 am Post subject: Re: Vanagon rims VS Bay Window rims |
That’s interesting, I had never heard of these. My 87 syncro had 5.5” from the factory. _________________ Driving a 90 Carat since 2014
Previous Buses: 59 Westy, 60 Westy, 74 Bus, 82 Westy, 85 Westy, 87 Syncro
Checkout my Syncro Video: https://www.youtube.com/watch?v=0JSWhLS7jLY |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 674 Location: Santa Cruz, CA
Posted: Thu Jun 08, 2023 12:11 pm Post subject: Re: Vanagon rims VS Bay Window rims |
Mini pet peeve, only spoked wheels have rims. There is the rim, the spokes and the hub. All together it is a wheel. Cars have only wheels. There was a small amount of spoked car wheels in existence but that was a long time ago and anyone who bought them have buried their heads or are dead by now. _________________ 1991 tin top GL
Some BMWs. |
