BryanM Samba Member
Joined: June 14, 2002 Posts: 4212 Location: Concord/Charlotte NC
Posted: Wed Dec 14, 2016 9:50 am Post subject: Re: Fire damaged engine bay? Found at local auction |
aeromech wrote: |
If I recall Gary threw an estimate range of 1500-10,000.
That was Steve. I said I could do the repairs for $750.
The OP asked for estimates over the computer using pictures. |
Can you provide the OP a written guaranteed estimate that you can repair the bus for $750? Please do. _________________ -Bryan
Motorwagen LLC
Concord NC |
BryanM Samba Member
Posted: Wed Dec 14, 2016 9:56 am Post subject: Re: Fire damaged engine bay? Found at local auction |
dirt4dinner wrote: |
Howdy! I came across something today at the local auction yard that caught my attention. I own a classic mini and have always liked the VW buses, but this might be a bit more than I can handle.
Anyways, what are your thoughts on this little green guy?
Is this worth salvaging, it appears that all of the damage was contained to the engine bay. The paint didn't even look damaged on the outside of the engine bay door. So let's assume that everything in that engine bay is toast.
Your best bet is to assume that the engine is junk, not just because of the fire but just because it is an old vehicle at an auction, and most Baywindows on the road are under-maintained. Hope for the best and prepare for the worst type thing.
As others have said it's could cost between $1000 - $10000 to get it back on the road, you don't know the condition of the transmission, front end or brakes either so those could be on the repair list. If you can do the work yourself it could be a fun project. Good luck _________________ -Bryan
Motorwagen LLC
Concord NC |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Wed Dec 14, 2016 12:00 pm Post subject: Re: Fire damaged engine bay? Found at local auction |
BryanM wrote: |
aeromech wrote: |
Can you provide the OP a written guaranteed estimate that you can repair the bus for $750? Please do. |
You misunderstood what I was telling the OP. This estimate of $750 was only for parts and materials. It assumes that the OP does the labor. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Wed Dec 14, 2016 5:08 pm Post subject: Re: Fire damaged engine bay? Found at local auction |
For Fook sake, I cannot belive the whiny shyte being thrown around here about a hypothetical auction. If the bus is not a bondowagen and it goes for a few thousand at auction, it can be back on the road for a reasonable cost to the new owner, if they have any skills at it.
Even if the engine is complete crap, they can toss in a cheap rebuild and flip it to the east coast after driving it for a season and no one will know the difference.
Of course, now with this tempest in a tin cup here, the likely hood of that is less. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Wed Dec 14, 2016 5:19 pm Post subject: Re: Fire damaged engine bay? Found at local auction |
BryanM wrote: |
aeromech wrote: |
estimate- you keep using that word. I don't think it means what you think it means. |
tolstoy Samba Member
Posted: Wed Dec 14, 2016 7:00 pm Post subject: Re: Fire damaged engine bay? Found at local auction |
Pull the engine. Strip everything you can off it. Send the long block to Headflow Masters as a core and buy a rebuilt 2000cc with new heads, that will run you about $3000, but you'll have a great engine. If you can salvage the FI, do it. You could be anywhere between $300 to $1000 get the FI up. Have the cooling tins sandblasted and powder coated. Make sure it is all there including thermostat and flaps, prob around $400 or so to get that all sorted. If the FI is toast, there is nothing wrong with putting a set of Weber 40idf's on there. About $800 for carbs and linkage.....order them from Aircooled.net and pay the extra to have them jet and setup the carbs for your engine. While the engine is out, remove the gas tank and have it cleaned out. Replace all the fuel lines, including the filler neck and all the vent lined, use Gates Barricade line wherever you can. If all the brakes need refreshed, about $800 would buy all the parts including new soft lines, rear shoes and cylinders, new front pads and rebuilt calipers, master cylinder and various hardware.
Tolstoy _________________ The sun is the same in a relative way, but you're older. Shorter of breath and one day closer to death.
'70 Westy |
cmonSTART Samba Member
Posted: Wed Dec 14, 2016 7:23 pm Post subject: Re: Fire damaged engine bay? Found at local auction |
Worst thing about that bus is the color!
Looks really solid from an east coaster's perspective! Heck, I can do an engine.. _________________ '78 Bus 2.0FI
de K1IGS |
Posted: Wed Dec 14, 2016 9:23 pm Post subject: Re: Fire damaged engine bay? Found at local auction |
Back around 1987 I was driving home from work at 2am in my 1971 bus. The engine sputtered and I thought maybe it was burned points. Then the gas pedal went to the floor. The glow in my mirror told me I had an engine fire. I coasted to a stop and confirmed the worst. No wait, the worst was finding out that my fire extinguisher was flat. I started seeing my coworkers stopping until one showed up and had a good extinguisher. I put the fire out.
Once I got towed home I was able to see the damage. It wasn't that bad. New ceiling panels and a couple hundred bucks in parts. I was back on the road. Engine fires don't always mean that it's terrible. I'm here to tell you that this ugly green bus could be repaired and it wouldn't require major engine work. That's it. I'm done here so go and do whatever you want. I don't care. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
rickman74 Samba Member
Joined: August 09, 2009 Posts: 58 Location: Toronto Canada
Posted: Thu Dec 15, 2016 3:18 am Post subject: Re: Fire damaged engine bay? Found at local auction |
Here's a thought; why didn't the original owner fix the damage? Maybe they were happy to be rid of a big problem. If I had an engine fire like that, I would take the insurance money, fix it myself and put it back on the road. |
Posted: Thu Dec 15, 2016 6:05 am Post subject: Re: Fire damaged engine bay? Found at local auction |
I was posting what I posted as a worse case scenario. It doesn't look like the fire was too bad, could just be what aeromech said. I'm talking the unknown. What if the engine was a POS and the fire just put it out of its misery? I to had an engine fire in a Mustang several years ago. New plug wires, cap, air filter, belts and heat shield and I was on my way.
'70 Westy |
CarlosZ Samba Member
Joined: April 23, 2016 Posts: 319 Location: Los Angeles
Posted: Thu Dec 15, 2016 7:23 am Post subject: Re: Fire damaged engine bay? Found at local auction |
$10k for the engine? Seems a bit far fetched IMO. OP wasn't looking for a HAM/Raby special. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Thu Dec 15, 2016 10:39 am Post subject: Re: Fire damaged engine bay? Found at local auction |
CarlosZ wrote: |
That's about 1/3 of a Raby _________________ .ssS! |
timvw7476 Samba Member
Posted: Thu Dec 15, 2016 11:43 am Post subject: Re: Fire damaged engine bay? Found at local auction |
rickman74 wrote: |
People unfamiliar with engines like the insurance check instead of the
project, also, the VW engine wiring harness is simple compared to modern
automotive layouts, so many write the bus off when it isn't a "total loss" by
any means. Then there's the insurance industry unspoken agenda of
getting every vehicle more than seven years old/more than 60,000 miles
scrapped-gotta funnel people through the car dealerships... |
dirt4dinner Samba Member
Posted: Thu Dec 15, 2016 10:47 pm Post subject: Re: Fire damaged engine bay? Found at local auction |
rickman74 wrote: |
It was an insurance right off, so I suppose that's why. |
BryanM Samba Member
Posted: Tue Dec 20, 2016 3:31 pm Post subject: Re: Fire damaged engine bay? Found at local auction |
CarlosZ wrote: |
You should probably look into what it cost for a quality built 2L type 4.
What shape is the case in? The heads? the pistons and Cylinders?
What about the condition of all the existing or missing cooling tin, new parts like an oil cooler, clutch rubber and hoses. What shape are the exhaust and heater boxes in?
How much of the existing FI is usable? How much does a complete, properly functioning FI system cost?
Would the owner want to reuse the burnt rusty components as is or have them blasted and painted/powder coated?
Now what about the labor to do all this, the labor to clean the engine compartment, repair fire damage to the wire harness?
How much should all of this cost?
It is easy to get to 10K. If the OP wants to do the work themselves then they will obviously save a ton of money. _________________ -Bryan
Motorwagen LLC
Concord NC |
SGKent Samba Member
Posted: Tue Dec 20, 2016 3:51 pm Post subject: Re: Fire damaged engine bay? Found at local auction |
Reading the overbearing and caustic comments in this thread by a couple folks who have called others full of BS leads me to understand why the next thread down in the forum right now is "TCash" "Did he leave because he got tired of caustic comments and attacks."
Bryan - this was not because of your post right above this.
If Gary thinks he can fix it for $750, maybe he can. That said, maybe this guy got tired of engine and other problems, rolled it onto the street, tossed gasoline, and a match on it, then collected insurance to get his money out of it. No one knows except the guy who owned it and he hasn't commented here unless he is one of you hoping to get a better price at the auction for the salvage rights he took on it. I was in finance enough years to know people actually do that kind of thing. Fires also happen accidentally to nice cars. I set a fire once by simply dropping a socket in the wrong place - bridged a fuel line to a starter wire for just a split second but enough to melt a hole in the metal fuel line and ignite the gasoline that spilled out. Fortunately a good fire bottle was only a foot away so the damage was really minor. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Dec 22, 2016 10:26 am Post subject: Re: Fire damaged engine bay? Found at local auction |
From the pictures I've seen I still say that the owner loved this bus. The reason it's up for auction might never be known because the original owner is now out of the picture. One possibility is that a towing company may have racked up a very high storage bill. Maybe the owner was military and had to report before he could deal with this? Maybe he died in the fire? Just kidding about that but the point is we can only look at the pictures and speculate. That bus would be a great project for me. I'll bet I could flip it in about 2 months and make over $5k profit. I just worked on a $9k bus last night, sorry no pictures, but these vehicles are drawing high prices right now. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Thu Dec 22, 2016 11:40 am Post subject: Re: Fire damaged engine bay? Found at local auction |
if it has a salvage title from the write off would it be an issue to re license for the road? _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
Posted: Thu Dec 22, 2016 11:45 am Post subject: Re: Fire damaged engine bay? Found at local auction |
pioneer1 wrote: |
if it has a salvage title from the write off would it be an issue to re license for the road? |
Nope
http://sandiego.craigslist.org/search/cto?query=salvage+title _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Cap10323 Samba Member
Posted: Thu Dec 22, 2016 12:46 pm Post subject: Re: Fire damaged engine bay? Found at local auction |
Salvage titles are no big deal, my bus currently has a Salvage title from the previous owner's little accident. Will just go get it re-inspected this spring once the body work is finished. |
